Your issue looks pretty similar to this post ISAAC ROS Docker package zed_wrapper not found - #10 by jim.fabian
If following the same procedure doesn’t fix the issue, please let me know.
Best,
Raffaello
Best,
Raffaello
| ISAAC ROS Docker package zed_wrapper not found | 9 | 1393 | April 19, 2024 | |
| Issue Running Isaac VSLAM with ZED Wrapper on Isaac ROS 3.1 | 8 | 449 | July 2, 2025 | |
| Zed ROS2 wrapper build fail | 6 | 742 | December 14, 2024 | |
| In Regard to Integrating ZED M Camera into Isaac ROS VSLAM | 1 | 947 | February 13, 2023 | |
| Isaac ros visual slam isn't starting subscribers for stereo camera | 13 | 1537 | May 2, 2024 | |
| ZED_wrapper not compiling inside isaac ros dev container | 2 | 410 | March 9, 2024 | |
| Compilation Error with ZED ROS2 Wrapper in Isaac ROS Visual SLAM on Jetson Orin Nano (JetPack 6.0, ROS 2 Humble) | 0 | 146 | June 24, 2025 | |
| Unable to Perform Isaac ROS ZED Setup | 5 | 183 | July 1, 2025 | |
| Isaac ROS ZED Setup — Isaac ROS | 6 | 264 | December 1, 2025 | |
| Can't launch isaac_ros_h264_encoder ZED example | 4 | 191 | December 5, 2024 |
