3ds Max converts meshes into triangles during export
When exporting meshes from 3ds Max toUSDA format, the geometry is automatically converted into triangles.
Is there a way to preserve the original quad-based topology during the export process?
Thank you.
Véronique
Are you using our 3dsmax Connector or the built in Autodesk USD exporter? Either way try both and see if there is a difference. Generally, though, I would think the answer would be no, because ALL meshes, in all “collapsed formats” result in triangles, not quads. That is just a common theme with exporting meshes. But put in this way… does it matter? Are you seeing the difference when not in wireframe mode?
