Hi when I launch A2F with the GUI or in Headless mode the app hangs for a good 3 minutes, this is very bothering.
please find below my logs if anyone could help :
Loading user config located at: ‘C:/Users/Shadow/AppData/Local/ov/data/Kit/Audio2Face/2023.2/user.config.json’
[Info] [carb] Logging to file: C:/Users/Shadow/.nvidia-omniverse/logs/Kit/Audio2Face/2023.2/kit_20240123_115641.log
[4.819s] [ext: omni.kit.async_engine-0.0.0] startup
[10.678s] [ext: omni.assets.plugins-0.0.0] startup
[10.820s] [ext: omni.stats-0.0.0] startup
[10.838s] [ext: omni.client-1.0.1] startup
[11.123s] [ext: omni.gpu_foundation-0.0.0] startup
[11.320s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[11.338s] [ext: omni.rtx.shadercache.d3d12-1.0.0] startup
[11.356s] [ext: carb.windowing.plugins-1.0.0] startup
[11.577s] [ext: omni.kit.renderer.init-0.0.0] startup
[11.685s] [ext: omni.kit.window.splash-1.0.1] startup
[11.875s] [ext: omni.kit.agent-0.1.7] startup
[11.897s] [ext: omni.kit.splash-0.4.2] startup
[11.922s] [ext: omni.kit.pipapi-0.0.0] startup
[11.942s] [ext: omni.kit.pip_archive-0.0.0] startup
[11.952s] [ext: omni.mtlx-0.1.0] startup
[11.980s] [ext: omni.usd.config-1.0.3] startup
[13.029s] [ext: omni.gpucompute.plugins-0.0.0] startup
[13.085s] [ext: omni.usd.libs-1.0.0] startup
| Driver Version: 528.49 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA RTX A4500 | Yes: 0 | | 20264 MB | 10de | 31fd0800… |
| | | | | | 2232 | 0 |
| | | | | | 1 | |
| OS: Windows 10 Home, Version: 10.0 (22H2), Build: 19045, Kernel: 10.0.19041.3803
| Processor: AMD EPYC 7543P 32-Core Processor | Cores: 4 | Logical: 8
| Total Memory (MB): 28652 | Free Memory: 25220
| Total Page/Swap (MB): 33004 | Free Page/Swap: 27872
[16.433s] [ext: omni.services.pip_archive-0.7.0] startup
[16.445s] [ext: omni.kit.loop-default-0.2.0] startup
[16.455s] [ext: omni.kit.test-0.0.0] startup
[17.310s] [ext: omni.usd.schema.semantics-0.0.0] startup
[17.853s] [ext: omni.usd.schema.audio-0.0.0] startup
[17.883s] [ext: omni.usd_resolver-1.0.1] startup
[17.955s] [ext: omni.iray.libs-0.0.0] startup
[18.486s] [ext: omni.volume-0.4.0] startup
[18.520s] [ext: omni.usd.core-1.1.8] startup
[18.541s] [ext: omni.mdl.neuraylib-0.2.0] startup
[18.565s] [ext: omni.hydra.rtx-0.1.0] startup
[18.712s] [ext: omni.hydra.iray-0.1.0] startup
[18.729s] [ext: omni.kit.telemetry-0.5.0] startup
[18.850s] [ext: omni.appwindow-1.1.5] startup
[18.889s] [ext: omni.kit.renderer.core-0.0.0] startup
[18.952s] [ext: omni.kit.renderer.capture-0.0.0] startup
[18.994s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[19.096s] [ext: carb.audio-0.1.0] startup
[19.111s] [ext: omni.ui-2.18.3] startup
[19.216s] [ext: omni.uiaudio-1.0.0] startup
[19.247s] [ext: omni.kit.mainwindow-1.0.1] startup
[19.300s] [ext: omni.kit.uiapp-0.0.0] startup
[19.303s] [ext: omni.usd.schema.physics-0.0.0] startup
[19.424s] [ext: omni.usd.schema.anim-0.0.0] startup
[19.543s] [ext: omni.usd.schema.physx-0.0.0] startup
[19.723s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[19.757s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[19.822s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[19.906s] [ext: omni.resourcemonitor-105.0.0] startup
[20.001s] [ext: omni.kit.actions.core-1.0.0] startup
[20.048s] [ext: omni.graph.exec-0.3.0] startup
[20.059s] [ext: omni.kit.commands-1.4.6] startup
[20.195s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[20.257s] [ext: omni.activity.core-1.0.1] startup
[20.277s] [ext: omni.kit.window.popup_dialog-2.0.23] startup
[20.339s] [ext: omni.hydra.usdrt_delegate-7.2.33] startup
[20.471s] [ext: omni.kit.widget.nucleus_connector-1.1.4] startup
[20.553s] [ext: omni.timeline-1.0.9] startup
[20.591s] [ext: omni.kit.exec.core-0.5.0] startup
[20.645s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[20.668s] [ext: omni.usd-1.10.18] startup
[21.023s] [ext: omni.kit.asset_converter-2.1.1] startup
[21.173s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[21.191s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[21.221s] [ext: omni.ui.scene-1.6.16] startup
[21.286s] [ext: omni.kit.usd.layers-2.1.26] startup
[21.450s] [ext: omni.kit.widget.options_menu-1.0.5] startup
[21.490s] [ext: omni.kit.widget.versioning-1.4.5] startup
[21.577s] [ext: omni.kit.widget.filter-1.1.2] startup
[21.603s] [ext: omni.kit.hotkeys.core-1.3.0] startup
[21.728s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[21.752s] [ext: omni.kit.helper.file_utils-0.1.6] startup
[22.005s] [ext: omni.kit.search_core-1.0.5] startup
[22.029s] [ext: omni.kit.widget.filebrowser-2.3.35] startup
[22.168s] [ext: omni.kit.widget.path_field-2.0.8] startup
[22.226s] [ext: omni.kit.menu.utils-1.5.6] startup
[22.312s] [ext: omni.kit.notification_manager-1.0.6] startup
[22.408s] [ext: omni.kit.widget.search_delegate-1.0.4] startup
[22.457s] [ext: omni.kit.widget.browser_bar-2.0.8] startup
[22.494s] [ext: omni.kit.clipboard-1.0.3] startup
[22.534s] [ext: omni.kit.primitive.mesh-1.0.15] startup
[22.659s] [ext: omni.kit.window.filepicker-2.10.9] startup
[23.046s] [ext: omni.kit.stage_templates-1.1.20] startup
[23.093s] [ext: omni.kit.window.file_importer-1.0.21] startup
[23.124s] [ext: omni.kit.window.file_exporter-1.0.22] startup
[23.170s] [ext: omni.kit.window.drop_support-1.0.1] startup
[23.184s] [ext: omni.kit.menu.create-1.0.11] startup
[23.233s] [ext: omni.kit.window.file-1.3.44] startup
[23.286s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[23.311s] [ext: omni.kit.context_menu-1.6.8] startup
[23.355s] [ext: omni.kit.window.content_browser-2.7.17] startup
2024-01-23 10:57:04 [23,146ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Content *********************
2024-01-23 10:57:04 [23,147ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Content” from omni.kit.window.content_browser.extension uses onclick_fn
[24.388s] [ext: omni.kit.widget.stage-2.9.5] startup
[24.629s] [ext: omni.kit.widget.prompt-1.0.6] startup
[24.661s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[24.685s] [ext: omni.kit.widget.searchfield-1.1.3] startup
[24.712s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[24.730s] [ext: omni.kit.widget.settings-1.0.6] startup
[24.765s] [ext: omni.kit.collaboration.presence_layer-1.0.8] startup
[24.805s] [ext: omni.kit.window.property-1.9.6] startup
[24.877s] [ext: omni.kit.window.preferences-1.3.23] startup
[24.999s] [ext: omni.kit.widget.live_session_management-1.2.22] startup
[25.099s] [ext: omni.kit.property.usd-3.21.15] startup
[25.226s] [ext: omni.hydra.engine.stats-1.0.1] startup
[25.246s] [ext: omni.graph.tools-1.41.3] startup
[25.818s] [ext: omni.inspect-1.0.1] startup
[25.861s] [ext: omni.hydra.pxr-1.1.5] startup
[25.910s] [ext: omni.graph.core-2.139.12] startup
[25.987s] [ext: omni.kit.hydra_texture-1.1.11] startup
[26.028s] [ext: omni.kit.viewport.legacy_gizmos-1.0.14] startup
[26.051s] [ext: omni.mdl-0.1.2] startup
[26.184s] [ext: omni.kit.widget.viewport-105.1.6] startup
[26.317s] [ext: omni.kit.viewport.registry-104.0.5] startup
[26.348s] [ext: omni.kit.material.library-1.3.41] startup
[26.628s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[26.649s] [ext: omni.kit.viewport.window-105.1.9] startup
[26.961s] [ext: usdrt.scenegraph-7.2.33] startup
[27.576s] [ext: omni.kit.usd_undo-0.1.2] startup
[27.629s] [ext: omni.kit.viewport.utility-1.0.16] startup
[27.639s] [ext: omni.graph-1.106.1] startup
[29.474s] [ext: omni.kit.widget.graph-1.8.4] startup
[29.650s] [ext: omni.ui_query-1.1.1] startup
[29.703s] [ext: omni.kit.window.extensions-1.3.0] startup
[30.161s] [ext: omni.debugdraw-0.1.2] startup
[30.242s] [ext: omni.graph.ui-1.48.0] startup
[30.854s] [ext: omni.services.facilities.base-1.0.4] startup
[30.873s] [ext: omni.graph.action-1.55.1] startup
[31.341s] [ext: omni.graph.nodes-1.106.3] startup
[34.081s] [ext: omni.services.core-1.7.0] startup
[35.003s] [ext: omni.graph.io-1.5.1] startup
2024-01-23 10:57:16 [34,775ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [omni::fabric::IFabricUsd v0.2] (plugin: ), by client: omni.graph.io.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[35.126s] [ext: omni.anim.shared.core-105.9.1] startup
[35.319s] [ext: omni.graph.ui_nodes-1.5.10] startup
[36.322s] [ext: omni.audio2face.utility-105.1.0] startup
[36.367s] [ext: omni.deform.shared-105.9.2] startup
[36.578s] [ext: omni.graph.bundle.action-2.0.6] startup
[36.582s] [ext: omni.kit.usd.collect-2.2.6] startup
[36.653s] [ext: omni.audio2face.common-105.3.1] startup
[36.707s] [ext: omni.audio2face.player_deps-105.1.1] startup
[36.734s] [ext: omni.kit.tool.collect-2.2.3] startup
[36.803s] [ext: omni.kit.collaboration.selection_outline-1.0.5] startup
[36.867s] [ext: omni.rtx.window.settings-0.6.9] startup
[36.954s] [ext: omni.kit.ui_test-1.2.13] startup
[36.999s] [ext: omni.anim.shared.ui-105.0.2] startup
[37.010s] [ext: omni.iray.settings.core-0.6.4] startup
[37.080s] [ext: omni.deform.ui-105.3.6] startup
[37.128s] [ext: omni.kit.widget.layers-1.6.30] startup
[37.389s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[37.418s] [ext: omni.kit.menu.file-1.1.7] startup
[37.869s] [ext: omni.kit.property.layer-1.1.5] startup
[37.913s] [ext: omni.kit.multinode-0.1.1] startup
[37.935s] [ext: omni.kit.manipulator.transform-104.6.15] startup
[37.970s] [ext: omni.kit.property.audio-1.0.9] startup
[38.004s] [ext: omni.kit.property.camera-1.0.5] startup
[38.037s] [ext: omni.kit.property.geometry-1.2.11] startup
[38.104s] [ext: omni.hydra.scene_api-0.1.2] startup
[38.158s] [ext: omni.kit.property.light-1.0.8] startup
[38.224s] [ext: omni.kit.property.render-1.1.1] startup
[38.270s] [ext: omni.kit.property.transform-1.3.10] startup
[38.353s] [ext: omni.kit.property.skel-1.0.4] startup
[38.415s] [ext: omni.kit.property.material-1.8.36] startup
[38.512s] [ext: omni.kit.raycast.query-1.0.0] startup
[38.537s] [ext: omni.kit.widget.toolbar-1.5.6] startup
[38.698s] [ext: omni.kit.property.bundle-1.2.9] startup
[38.732s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[38.770s] [ext: omni.kit.manipulator.tool.snap-1.4.2] startup
[38.919s] [ext: omni.kit.widget.spinner-1.0.6] startup
[38.987s] [ext: omni.kit.manipulator.viewport-104.0.9] startup
[39.039s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[39.169s] [ext: omni.kit.viewport.menubar.core-105.0.19] startup
[39.793s] [ext: omni.kit.manipulator.prim-105.0.11] startup
[39.935s] [ext: omni.kit.manipulator.selection-104.0.8] startup
[39.987s] [ext: omni.kit.viewport.menubar.camera-105.1.9] startup
[40.117s] [ext: omni.kit.viewport.actions-105.1.6] startup
[40.165s] [ext: omni.kit.viewport.menubar.render-105.1.0] startup
[40.236s] [ext: omni.hydra.pxr.settings-1.0.5] startup
[40.261s] [ext: omni.kit.viewport.menubar.settings-105.0.9] startup
[40.366s] [ext: omni.kit.viewport.menubar.display-105.0.6] startup
[40.409s] [ext: omni.kit.widget.live-2.1.6] startup
[40.461s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[40.465s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[40.470s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
[41.450s] [ext: omni.kit.collaboration.viewport.camera-2.0.17] startup
[41.558s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[41.562s] [ext: omni.command.usd-1.0.2] startup
[41.616s] [ext: omni.kit.selection-0.1.3] startup
[41.652s] [ext: omni.kit.window.about-1.2.4] startup
[41.725s] [ext: omni.kit.window.console-0.2.10] startup
2024-01-23 10:57:23 [41,533ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Console *********************
2024-01-23 10:57:23 [41,534ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Console” from omni.kit.window.console.scripts.console_extension uses onclick_fn
[41.812s] [ext: omni.kit.window.privacy-0.1.0] startup
[41.850s] [ext: omni.kit.menu.edit-1.1.14] startup
[41.890s] [ext: omni.kit.window.script_editor-1.7.4] startup
[41.976s] [ext: omni.kit.widget.stage_icons-1.0.4] startup
[42.023s] [ext: omni.kit.window.status_bar-0.1.6] startup
[42.078s] [ext: omni.kit.window.tests-0.3.2] startup
[42.116s] [ext: omni.kit.window.title-1.1.3] startup
[42.268s] [ext: omni.kit.window.toolbar-1.5.4] startup
[42.316s] [ext: omni.rtx.settings.core-0.5.12] startup
[42.438s] [ext: omni.kit.window.stage-2.4.4] startup
2024-01-23 10:57:24 [42,309ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Stage *********************
2024-01-23 10:57:24 [42,343ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Stage” from omni.kit.window.stage.stage_extension uses onclick_fn
[42.623s] [ext: omni.kit.menu.common-1.1.4] startup
[42.772s] [ext: omni.kit.menu.aov-1.1.3] startup
[42.855s] [ext: omni.kit.collaboration.stage_columns-1.0.4] startup
[43.057s] [ext: omni.kit.window.stats-0.1.4] startup
[43.108s] [ext: omni.app.dev-1.0.0] startup
[43.111s] [ext: omni.avatar.livelink-105.11.1] startup
[49.720s] [ext: omni.kit.browser.core-2.3.10] startup
[49.895s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[50.152s] [ext: omni.audio2face.inference_deps-105.1.1] startup
[50.174s] [ext: omni.audio2face.emotion_deps-105.0.3] startup
[50.211s] [ext: omni.audio2face.inference-105.1.2] startup
[50.253s] [ext: omni.kit.graph.delegate.modern-1.9.2] startup
[50.314s] [ext: omni.kit.graph.delegate.default-1.1.2] startup
[50.329s] [ext: omni.audio2face.emotion-105.0.6] startup
[52.390s] [ext: omni.audio2face.core_deps-105.5.1] startup
[52.408s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[52.508s] [ext: omni.audio2face.ui.common-105.2.1] startup
[52.593s] [ext: omni.audio2face.player-105.1.1] startup
[53.157s] [ext: omni.audio2face.core-105.5.1] startup
[53.414s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[53.479s] [ext: omni.kit.graph.usd.commands-1.3.0] startup
[53.504s] [ext: omni.audio2face.ui.player-105.1.1] startup
[53.563s] [ext: omni.audio2face.ui.core-105.1.1] startup
[53.622s] [ext: omni.graph.window.core-1.84.0] startup
[53.821s] [ext: omni.audio2face.tool-105.4.1] startup
[53.926s] [ext: omni.graph.window.action-1.11.2] startup
2024-01-23 10:57:35 [53,704ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Action Graph *********************
2024-01-23 10:57:35 [53,705ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Action Graph” from functools uses onclick_fn
[53.982s] [ext: omni.audio2face.exporter-105.20.4] startup
[54.276s] [ext: omni.kit.browser.folder.core-1.9.9] startup
[54.402s] [ext: omni.anim.toolbox-105.7.0] startup
[54.480s] [ext: omni.kit.browser.sample-1.4.6] startup
2024-01-23 10:57:35 [54,254ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Examples *********************
2024-01-23 10:57:35 [54,256ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Examples” from omni.kit.browser.sample.extension uses onclick_fn
[54.528s] [ext: omni.warp.core-1.0.0-beta.4] startup
Warp 1.0.0-beta.4 initialized:
CUDA Toolkit: 11.5, Driver: 12.0
Devices:
“cpu” | AMD64 Family 25 Model 1 Stepping 1, AuthenticAMD
“cuda:0” | NVIDIA RTX A4500 (sm_86)
Kernel cache: C:\Users\Shadow\AppData\Local\NVIDIA Corporation\warp\Cache\1.0.0-beta.4
[55.204s] [ext: omni.deform.deltaMush-105.5.4] startup
[55.352s] [ext: omni.deform.deltaBlend-105.5.3] startup
[55.464s] [ext: omni.kit.mesh_separate-105.2.1] startup
[55.529s] [ext: omni.kit.viewportDraw-105.2.1] startup
[55.652s] [ext: omni.warp-1.0.0-beta.4] startup
[56.340s] [ext: omni.kit.mesh.raycast-105.3.1] startup
[56.374s] [ext: omni.deform.prox-105.6.5] startup
[56.519s] [ext: omni.kit.ngsearch-0.3.3] startup
[56.557s] [ext: omni.graph.window.generic-1.9.3] startup
2024-01-23 10:57:38 [56,349ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Push Graph *********************
2024-01-23 10:57:38 [56,350ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Push Graph” from functools uses onclick_fn
2024-01-23 10:57:38 [56,351ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] ********************* MenuItemDescription Lazy Graph *********************
2024-01-23 10:57:38 [56,351ms] [Warning] [omni.kit.menu.utils.scripts.builder_utils] Menu item “Lazy Graph” from functools uses onclick_fn
[56.628s] [ext: omni.kit.charTransfer-105.16.1] startup
[56.948s] [ext: omni.audio2face.wizard-105.9.0] startup
[57.010s] [ext: omni.kit.search.service-0.1.12] startup
[57.523s] [ext: omni.kit.freezeTransformations-105.2.1] startup
[57.565s] [ext: omni.kit.thumbnails.usd-1.0.4] startup
[58.336s] [ext: omni.kit.tool.asset_exporter-1.3.0] startup
[58.404s] [ext: omni.kit.tool.asset_importer-2.5.0] startup
[58.512s] [ext: omni.kit.window.modifier.titlebar-105.1.15] startup
[58.562s] [ext: omni.services.transport.server.base-1.1.1] startup
[58.586s] [ext: omni.kit.window.provide_feedback-1.0.2] startup
[58.601s] [ext: omni.kit.window.usd_paths-1.0.5] startup
[58.649s] [ext: omni.anim.curve-105.23.0] startup
[58.873s] [ext: omni.anim.retarget.core-105.1.8] startup
[58.989s] [ext: omni.services.transport.server.http-1.3.0] startup
[59.366s] [ext: omni.kit.profiler.window-2.2.0] startup
2024-01-23 10:57:40 [59,195ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.lt and use insort ‘key’ arg instead
[59.496s] [ext: omni.deform.ssd-105.2.1] startup
[59.593s] [ext: omni.anim.window.timeline-105.11.14] startup
[59.762s] [ext: omni.anim.skelJoint-105.1.17] startup
[59.869s] [ext: audio2face-2023.0.0] startup
2024-01-23 10:57:50 [68,733ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2024-01-23 10:57:50 [68,735ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[69.417s] app ready
2024-01-23 10:57:53 [71,460ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2024-01-23 10:57:53 [71,635ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
2024-01-23 10:58:11 [89,781ms] [Warning] [omni.audio2face.wizard.scripts.extension] Removing a hotkey: “P” Global [omni.kit.menu.utils] omni.kit.menu.edit::parent_prims.P
2024-01-23 10:58:11 [89,792ms] [Warning] [omni.audio2face.wizard.scripts.extension] Removing a hotkey: “R” Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::scale.R
[A2F SDK] [INFO] ProcessorFullface: Using CUDA device: [0] NVIDIA RTX A4500
[A2F SDK] [INFO] AnimatorSkinV2: Using CUDA device: [0] NVIDIA RTX A4500
[A2F SDK] [INFO] AnimatorTongue: Using CUDA device: [0] NVIDIA RTX A4500
2024-01-23 10:59:57 [195,566ms] [Warning] [omni.graph.core.plugin] Node.registerPathChangedCallback is deprecated - use USD notice handling instead
2024-01-23 10:59:57 [195,942ms] [Warning] [omni.fabric.plugin] No source has valid data array=000001D7617F3C58 usdValid=0 cpuValid=0
2024-01-23 10:59:57 [195,942ms] [Warning] [omni.fabric.plugin] No source has valid data array=000001D7B397EB20 usdValid=0 cpuValid=0
[TRT INFERENCE] [INFO] TensorRT Processor: Using CUDA device: [0] NVIDIA RTX A4500
[A2F SDK] [INFO] Reading data file: c:\users\shadow\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.core_deps\deps\audio2face-nets\nets_fullface\mark_v2\implicit_emo_db.bin
[A2F SDK] [INFO] Emotion Database: Using CUDA device: [0] NVIDIA RTX A4500
[A2F SDK] [INFO] Setting default implicit emotion: (g1a_neutral, 0)
[A2F SDK] [INFO] Getting emotion vector for (g1a_neutral, 0)
[A2F SDK] [INFO] Reading data file: C:\Users\Shadow\AppData\Local\ov\cache\Kit\105.1\c677816d\audio2face-nets\mark_v2\network_device0_fp32.trt
[A2F SDK] [INFO] Inference Engine: Using CUDA device: [0] NVIDIA RTX A4500
[A2F SDK] [INFO] [TensorRT] Loaded engine size: 70 MiB
[A2F SDK] [INFO] [TensorRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 12832, GPU 4111 (MiB)
[A2F SDK] [INFO] [TensorRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +67, now: CPU 0, GPU 67 (MiB)
[A2F SDK] [INFO] [TensorRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 12834, GPU 4111 (MiB)
[A2F SDK] [INFO] [TensorRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +7, now: CPU 0, GPU 74 (MiB)
[A2F SDK] [INFO] [TensorRT] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
[Audio Player] Using default output device: Haut-parleurs (Virtual Audio De
2024-01-23 11:00:01 [199,333ms] [Warning] [omni.hydra] Mesh ‘/World/mark_head_model_hi_published/c_headWatertight_hi’ update topology/point without updating normal, fallback to smooth normal.
2024-01-23 11:00:01 [199,949ms] [Warning] [omni.fabric.plugin] getAttributeCount called on non-existent path /World/audio2face/__runtime_data/c_headWatertight_hi_SetPoints_outputs_deformable
2024-01-23 11:00:01 [199,950ms] [Warning] [omni.fabric.plugin] getTypes called on non-existent path /World/audio2face/__runtime_data/c_headWatertight_hi_SetPoints_outputs_deformable
2024-01-23 11:00:01 [199,951ms] [Warning] [omni.fabric.plugin] removePath called on non-existent path /World/audio2face/__runtime_data/c_headWatertight_hi_SetPoints_outputs_deformable
[A2F SDK] [INFO] Setting implicit emotion: (g2a_neutral, 0)
[A2F SDK] [INFO] Getting emotion vector for (g2a_neutral, 0)
[A2F SDK] [INFO] Setting implicit emotion: (g2a_neutral, 33)
[A2F SDK] [INFO] Getting emotion vector for (g2a_neutral, 33)
2024-01-23 11:00:02 [200,722ms] [Warning] [omni.audio2face.utility.scripts.utils] Unable to read TRT info: c:\users\shadow\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.emotion_deps\deps\audio2emotion-nets/nets\a2e_v1.4.2\trt_info.json ; Details: [Errno 2] No such file or directory: ‘c:\users\shadow\appdata\local\ov\pkg\audio2face-2023.2.0\exts\omni.audio2face.emotion_deps\deps\audio2emotion-nets/nets\a2e_v1.4.2\trt_info.json’
[TRT INFERENCE] [INFO] Reading data file: C:\Users\Shadow\AppData\Local\ov\cache\Kit\105.1\c677816d\audio2emotion-nets\a2e_v1.4.2\network_device0_fp32.trt
[TRT INFERENCE] [INFO] Inference Engine: Using CUDA device: [0] NVIDIA RTX A4500
[TRT INFERENCE] [INFO] [TensorRT] The logger passed into createInferRuntime differs from one already provided for an existing builder, runtime, or refitter. Uses of the global logger, returned by nvinfer1::getLogger(), will return the existing value.
[TRT INFERENCE] [INFO] [TensorRT] Loaded engine size: 361 MiB
[TRT INFERENCE] [INFO] [TensorRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 13938, GPU 5113 (MiB)
[TRT INFERENCE] [INFO] [TensorRT] [MemUsageChange] TensorRT-managed allocation in engine deserialization: CPU +0, GPU +360, now: CPU 0, GPU 434 (MiB)
[TRT INFERENCE] [INFO] [TensorRT] [MemUsageChange] Init cuBLAS/cuBLASLt: CPU +0, GPU +8, now: CPU 13939, GPU 5113 (MiB)
[TRT INFERENCE] [INFO] [TensorRT] [MemUsageChange] TensorRT-managed allocation in IExecutionContext creation: CPU +0, GPU +24, now: CPU 0, GPU 458 (MiB)
[TRT INFERENCE] [INFO] [TensorRT] CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See CUDA_MODULE_LOADING in CUDA C++ Programming Guide
thanks
