AGX Module Not Turning On and Overheating
I need your help with an issue I’ve encountered with my NVIDIA Jetson AGX Xavier module. It was working perfectly on a custom carrier board, but suddenly, it stopped turning on and began overheating. I’ve tested the same carrier board with other AGX modules and it works flawlessly, indicating that the issue is specific to this module.
The module failed to function properly, accompanied by unusual behavior such as fluctuating voltage The
module failed to function properly, accompanied by unusual behavior such as fluctuating voltage. The less are not turning one neither
Fluctuating voltage sounds like some hardware issues, and I don’t feel like you can fix it with software updates.
Maybe you should consider RMA the module.
what should I do then to do the RMA process?
Please refer to Jetson FAQ | NVIDIA Developer
