when I install omniverse in another partition of my PC it does not start all the applications,
I would need more information to help better. I would need details.
- Where is your launcher installed
- What apps do you have installed
- What apps are not loading
- Can you uninstall and clean and then reinstall back to the default location
- Can you send logs over
Hi thank you for the answer
1-launcher installed in C:\Users*****\AppData\Local\Programs\omniverse-launcher
2-apps installed usd viewer and usd composer and some connectors
3-apps not loading are; usd viewer and usd composer
4- 1. Can you uninstall and clean and then reinstall back to the default location, haven’t yet i wiill try
5-how can i send the logs
Thank you
Hmm strange. Why is your launcher installed in the wrong path ? It should not be “C:\Users*****\AppData\Local\Programs\omniverse-launcher”
It should be in “C:\Users\user\AppData\roaming\omniverse-launcher
I would uninstall everything and then run the cleanup tool. Reinstall and do not change the default paths.
