Is there audio in and audio out on the developer board for the tx1? I saw audio in and out on the dev board for the tk1 but it seems to be missing from the tx1.
The only directly wired audio on JTX1 is the HDMI stereo. The breakout area contains i2s which could be used to create a breakout panel for audio (not a trivial task). If you really need audio immediately though, most USB audio cards for breakout will work (you could check up on the chipset before purchasing). For example, USB headphones work.
