for example, if I save .png file into the localhost omniverse drive folder from Photoshop,
it appears in the folder at content browser
then I edit and save again, the file is gone, material used this .png will not be updated.
but the file does exist at the folder and be seen in Windows file explorer.
I felt the issue was caused on the Cache side.
All apps are in latest version, the OS is windows 11
Hello @asuralhp! Welcome to the community! I need to report this error to the development team. Can you provide me with a bit more information to help troubleshoot?
Omniverse Drive logs: C:\Users\<USERNANE>\AppData\Local\NVIDIA Corporation\Omniverse\logs\Drive
Cache Output Logs: C:\Users\<USERNAME>\AppData\Local\ov\pkg\<CACHE_VERSION>
- Find and run the
omni-cache-service.exe
inside your cache folder
- Run the capture Cache Output (or take a screenshot)
Also, what GPU(s) / Driver are you currently using?
