Hi, I have a problem. Omniverse has lost or deleted my files in the localhost directory. When I try save files using Unreal Engine 4.26.2, it says that’s it’s read only. Then I tried again, then I was getting weird error messages.
Plus, I can’t seem to access localhost:3009 on my web browser, saying can’t connect to it. Has anyone had this problem? I seem to have notice this when I updated it a week ago.
What?! Oh no! Let me get some help here.
Let me take a shot at this…
- With the Unreal Connector, don’t use the Omniverse Drive, the Connector can access your
localhostdirectly. You add yourlocalhostserver through the Omniverse button and access it through theContent/Omniversefolder. - To access your localhost files, try this link in your browser: http://localhost:8080/
- If you’re having stability issues with Omniverse Drive I’d recommend shutting it down (and restarting it if you require)
- If you still cannot access your
localhostserver, try restarting it by going to the System Monitor - http://localhost:3080/ - and restarting it
Yeah I knew that you didn’t have to have Drive on for saving USD files on Unreal, I just saved directly to localhost anyway. The problem is I can’t save anything in the localhost directory. Even when I try to just make a folder in the localhost directory, it disappears.
For now, I just now go to File->export all and save the files as USD anyway.
When I access localhost:8080 on the browser, it says ‘It failed to connect to server’ to connect to localhost.
Question, how do you restart Omniverse drive?
Ok, just went on the System monitor, I can’t see it on the application list. What is it under?
