Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
Hello again.
Issue on NVSIPL exit operation, it’s easy to stuck when trying exit NVSIPL sample (camera is on) from default fullscreen mode.
Is that any safe measure to force the exit? (I don’t want to take risk to poweroff the board)
BTW, I am still wanting for the answer to the HW/Software version mapping to the entron camera, please provide if possible, thanks!
BRs
Tingguang
Does that mean, even after pressing “q” , the display window is not exited?
yes, it’s easy to reproduce when bring up the 8MP camera, now my solution is to let the app count seconds and exit. it helps tests
But still I can’t find a way to try write the custom video to file
Dear @tingguang.wang1,
-r <sec> used to run application for r seconds.
-f <prefix> is used to generate output files with prefix. Did you check it?
My idea is to record camera stream as H.264 file to test with drivenet and lightnet, it seems that -f can only record image raw frames
Were you able to feed input video recorded using nvsipl_camera?
I guess it may not directly works with DW. Please share your feedback
Sure, I have been out for a week.
I will do a combination of test summarize this week in order to provide systematic feedbacks,
Thanks in advance!
Any update can be provided for this topic? or we can close it?
Still waiting for roadtest, please close this, I will update from other topic
