we tried to flash tx2 several times(modify pcie lane-mapping config),but when we tried to reflash tx2,we can not detect usb in recover mode. lsusb on the host machine won’t show the Nvidia Corp as we ve seen it before. We’ve done the reflashing several times before and this happened on the very last time. Is there any way to solve this?
Lots of thank!
Is the host a VM, or native install? If a VM, then this is an issue of VMs seen a lot. However, VMs do tend to see the device in the beginning, and only later fail to see the device.
Is this a dev kit? Dev kits come with a known high quality micro-B USB cable. Charger cables, and many cables out in the wild, were designed to be cheap and tend to fail for data. Try a different cable if you can.
Is this the dev kit carrier board, or some other carrier board? I would expect either to be somewhat reliable at achieving recovery mode, but if you have different carrier boards, then I would suggest swapping the module to another carrier board to see if the issue follows board or module.
It isn’t high on the list, but you might also try a different power supply in case it is power related.
If there is a signal quality issue, then consider trying (a) directly to the host PC port, and then again using a HUB (the HUB may work with signals of lower quality). Note that if you use a HUB, then be sure only the Jetson is on that HUB.
ok,thank you,maybe we need to change another high quelity micro-B usb cable.
