"can0" is not working in Drive AGX Xavier
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.1.10844
other
Host Machine Version
native Ubuntu 18.04
other
As per the following CAN mapping understanding of Drive AGX Xavier,
  • Physical CAN 2 → Logical can0
  • Physical CAN 4 → Logical can1
I connected,
  1. CAN 4&6 to can-RTC module.
  2. CAN 1&2 to a laptop which generates can messages(can2.0A, 500kbit/s) from can-oe software. Also, connected 120ohm termination to this CAN.
Enabled can0 and can1 in both xavier using,
$ sudo ip link set can0 type can bitrate 500000 && sudo ip link set up can0
$ sudo ip link set can1 type can bitrate 500000 && sudo ip link set up can1
I opened both xavier-A and xavier-B terminals and did the loopback testing. Loopback testing of can1 was success.
# Xavier-A
$ cansend can1 120#1122334455667788
# Xavier-B
$ candump can1
can1 120 [8] 11 22 33 44 55 66 77 88
But loopback testing on can0 puts can0 to ERROR_PASSIVE state.
All CAN related drivers (can_raw, can, mttcan, can_dev) are installed except mttcan_ivc. Is that the problem?
Dear @nvBalaji
Did you check https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/Interfaces/sys_components_tegra_can.html#wwpID0E0BD0HA and Setting up CAN loopback?
