Cannot Flask Jetson Xavier NX from WSL2 Host
I have been trying to flash Jetson Xavier NX from WSL2 using Ubuntu 18.04 and it constantly failed. I have been searched this forum for similar problem, but I still failed. For reference I followed:
Attached error log from SDK Manager.
7:16:45 INFO: VPI on Target - target: Found file /home/ilhamfadhil/Downloads/nvidia/sdkm_downloads/vpi-demos-2.4.8-aarch64-l4t.deb with correct checksum, skip downloading.
17:16:45 INFO: TensorRT on Target - target: Found file /home/ilhamfadhil/Downloads/nvidia/sdkm_downloads/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb with correct checksum, skip downloading.
17:16:46 INFO: cuDNN on Target - target: Found file /home/ilhamfadhil/Downloads/nvidia/sdkm_downloads/cudnn-local-tegra-repo-ubuntu2004-8.6.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
17:16:47 INFO: DeepStream - target: Found file /home/ilhamfadhil/Downloads/nvidia/sdkm_downloads/deepstream-6.3_6.3.0-1_arm64.deb with correct checksum, skip downloading.
17:16:48 INFO: CUDA Toolkit for L4T - target: Found file /home/ilhamfadhil/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb with correct checksum, skip downloading.
17:20:54 ERROR: File System and OS - target_image: sudo: ./tools/l4t_flash_prerequisites.sh: command not found
17:20:54 ERROR: File System and OS - target_image: [exec_command]: /bin/bash -c /home/ilhamfadhil/.nvsdkm/replays/scripts/JetPack_5.1.4_Linux/NV_L4T_FILE_SYSTEM_AND_OS_COMP.sh; [error]: sudo: ./tools/l4t_flash_prerequisites.sh: command not found
17:20:54 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
17:20:54 INFO: File System and OS - target_image: [host] [ 1.55 MB released. Disk Avail on Partition /dev/sdd: 941.60 GB ]
17:20:54 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 4m10s ]
17:20:54 ERROR: command error code: 11
17:20:54 ERROR: File System and OS - target_image: command terminated with error
17:20:54 SUMMARY: File System and OS - target_image: First Error: Installation failed.
SDKM_logs_JetPack_5.1.4_Linux_for_Jetson_Xavier_NX_2024-12-27_17-16-30.zip (34.5 KB)
The solution is easy. Just use a real bare-metal Ubuntu system. ANY kind of virtualisation will make things unreliable.
Yes, but I see WSL2 documentation in NVIDIA SDK Manager. Therefore, it should be works right?
After 7 years of NVida Jetson experrience: just stick with pure bare metal if you want to play safe. Other ways may work sometimes … until they don’t.
