Hello.
I am struggling with something I think should be very basic. I would like to make a visual cuboid with side lengths of 0.4, 1 and 0.3. But it ends up as a cube with all sides equal to 0.05
What am I doing wrong with this simple task? Here is my code. I am using Isaac Sim 2022.1
import json
import numpy as np
import sys
from omni.isaac.kit import SimulationApp
app_config = {
"width": 780,
"height": 440,
"window_width": 1320,
"window_height": 760,
"headless": True,
"renderer": "RayTracedLighting",
"display_options": 3220,
simulation_app = SimulationApp(app_config)
simulation_app.set_setting("/app/window/drawMouse", True)
simulation_app.set_setting("/app/livestream/proto", "ws")
simulation_app.set_setting("/app/livestream/websocket/framerate_limit", 30)
simulation_app.set_setting("/ngx/enabled", False)
from omni.isaac.core.prims.xform_prim import XFormPrim
from omni.isaac.core.objects import DynamicCuboid, VisualCuboid
from omni.isaac.core.utils.extensions import enable_extension
import omni.kit
from omni.isaac.core import World
enable_extension("omni.services.streamclient.websocket")
world = World()
ground_plane = world.scene.add_default_ground_plane()
XFormPrim(ground_plane.prim_path + "/SphereLight").set_visibility(False)
world.scene.add(VisualCuboid(
prim_path="/World/spawn_region",
position=[0.7, 0, 0.45],
scale=np.array([0.4, 1.0, 0.3]),
color=np.array([1, 0, 1]),
world.reset()
prim = XFormPrim("/World/spawn_region")
print("Spawn region", prim.get_local_pose(), prim.get_local_scale(), prim.get_world_scale())
while simulation_app._app.is_running() and not simulation_app.is_exiting():
simulation_app.update()
simulation_app.close()
