Hello everyone.
I’m having a problem when scaling objects in Isaac sim.
Previously, when I reduced an object by 1/100 and saved it as a USD, I could use this file in this way. However, I can no longer do this. Would you help me with this topic?
I can elaborate a little more.
You pick up an object and it is 100 times larger than its normal size. You took this object and resized it to 0.01 in x y z dimensions. and saved it in USD format using the save selected option on the stage tab. However, when you use the object again, you see it 100 times larger.
