Can't connect to local host during setup
Check this post
I’ve just had the same issue and discussed on the forum and discord.
Basically don’t use the log in details you entered when setting up the server, it might be bugged or lots of people are making a similar mistake either way follow the post and use these log in details you should be sorted
Server name: localhost Username: admin Password: admin
