My Nucleus keeps displaying my local host is not available. It keeps stopping with an error message every time I try to start it on localhost:3080
We need a lot more info. Let’s start with at least a screenshot of your issue. A video is better. Please also send us the logs from Launcher.
Secondly Nuclues is not required to use Omniverse. May I ask why you are installing it ?
Finally have you actually installed your local nucleus ?
It worked just fine earlier, now all of a sudden its not acting properly. I installed my local nucleus. I am on a GPU rendering system and I had to update my Omniverse and now it’s not letting the logo go away
Also don’t I need Nucleus to connect to IClone and CC4?
As I asked earlier, I need to understand your workflow. You are trying to connect CC4 and iClone to what OV APP ? USD composer ?
I need much more details. What is your system ? Windows or Linux ? What is your GPU ? What are your drivers ?
You would only need Nucleus if you wanted to connect USD Composer “LIVE” to another app with one of our supported live connect plugins.
If you just wanted to export files from CC4 or iClone and load them into USD Composer, then no, you do not need Nucleus.
USD Composer I tried doing a live link to IClone and it would not display my project, so I closed out and reopened the program that’s when I saw the RTX Loading sign
What other app should I use to connect to that has a plug in?
In this case it sounds like a temporary “out of memory” issue where you can multiple GPU intensive apps open. You would simply log off windows and log back on to refresh your GPU services.
When you say “connect” do you need it to be completely live and realtime for changes or you are just trying to get a model from one app to the other ? If it’s the second, just export your work and import into Composer.
Log off windows??
I restarted my computer and everything
Yes correct.
So after restarting the RTX Loading is still there
What specific drivers should I have installed for it to work proerly?
I have all of that
The Audio to Face came up okay
Is the Beta version of the USD Composer still good or is that oudated?
I am using Windows
I am GPU
I want to connect to USD Composer live
It still won’t go away should I uninstall and reinstall?
How would I get you logs from Launcer?
I installed my local Nucleus
What GPU ? It matters.
AMD Rayzen GPU
Like I said it was working fine earlier without that RTX Loading on the screen I’ve been using it for the past week without issue
