I cant find a resolution to the “FetchError: request to https://messages.launcher.omniverse.nvidia.com/en/eula.json failed, reason: self signed certificate in certificate chain” Error.
I’m trying to put a case together for using Omniverse in our college, however I’ve hit a brick wall on install with the error above, from what i can tell its an authentication issue.
Web filtering is via Smoothwall via kerberos, Most educational institutions will be configured this way so I guess you will have come across this problem before. I don’t see an offline installer so what is the fix?
