Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
[-] 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
[-] Windows 11
Windows 10
GPU Information
- Model: NVIDIA GeForce RTX 4060 Laptop and Intel(R) Arc™ Graphics
- Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
Can’t run isaac-sim.bat, crashed at the end.
How to set ISAAC use only RTX4060 and jump over Intel Graphic.
Steps to Reproduce
- run isaac-sim.bat
(Add more steps as needed)
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
(Describe any troubleshooting steps you’ve already taken)
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
(Add any other context about the problem here)
crash_isaac-sim.bat.txt (91.2 KB)
2025-04-27 03:44:12 [29,610ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osDistro = '24H2'
2025-04-27 03:44:12 [29,611ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osName = 'Windows 11 Home China'
2025-04-27 03:44:12 [29,611ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osVersion = '10.00.26100'
2025-04-27 03:44:12 [29,612ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] portableMode = '0'
2025-04-27 03:44:12 [29,613ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = '3072x1920x32bit@120Hz'
2025-04-27 03:44:12 [29,613ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = 'Individual'
2025-04-27 03:44:12 [29,614ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runningInContainer = '0'
2025-04-27 03:44:12 [29,615ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = '
| Driver Version: 561.03 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4060 Laptop.. | | | 7957 MB | 10de | ff310100.. |
| | | | | | 28a0 | d498242c.. |
| | | | | | 6 | |
| 1 | Intel(R) Arc(TM) Graphics | | | 16186 MB | 8086 | d22c0100.. |
| | | | | | 7d55 | 8680557d.. |
| | | | | | N/A | |
| 2 | Intel(R) Arc(TM) Graphics | | | 16186 MB | 8086 | fef50100.. |
| | | | | | 7d55 | 8680557d.. |
| | | | | | N/A | |
| OS: Windows 11 Home China, Version: 10.0 (24H2), Build: 26100, Kernel: 10.0.26100.3912
| Processor: Intel(R) Core(TM) Ultra 5 125H
| Cores: 14 | Logical Cores: 18
| Total Memory (MB): 32373 | Free Memory: 7831
| Total Page/Swap (MB): 35829 | Free Page/Swap: 7746
2025-04-27 03:39:34 [47,341ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = '6387913704384096973'
2025-04-27 03:39:34 [47,342ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = '0'
2025-04-27 03:39:34 [47,343ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamBareMetalMB = '32373'
2025-04-27 03:39:34 [47,344ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamLimitedMB = '32373'
2025-04-27 03:39:34 [47,345ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapBareMetalMB = '35829'
2025-04-27 03:39:34 [47,347ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapLimitedMB = '35829'
2025-04-27 03:39:34 [47,348ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] userId = 'default'
2025-04-27 03:39:34 [47,350ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = 'D:\isaacsim'
2025-04-27 03:39:34 [47,352ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 6964 backtrace follows:
2025-04-27 03:39:34 [47,356ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: omni.kit.renderer.plugin.dll!carbOnPluginStartup+0xaa2d
2025-04-27 03:39:34 [47,358ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: omni.kit.renderer.plugin.dll!carbOnPluginStartup+0x137d4
2025-04-27 03:39:34 [47,360ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: omni.ui.dll!omni::ui::ByteImageProvider::_releaseImage+0x28a
2025-04-27 03:39:34 [47,363ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: omni.ui.dll!omni::ui::ByteImageProvider::setBytesData+0xa6
2025-04-27 03:39:34 [47,363ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: omni.ui.dll!omni::ui::FloatSlider::onModelUpdated+0xbd3
2025-04-27 03:39:34 [47,364ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: omni.ui.dll!omni::ui::FloatSlider::onModelUpdated+0x135f
2025-04-27 03:39:34 [47,365ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: omni.ui.dll!omni::ui::FontAtlasTextureRegistry::getAtlas+0x3b5
2025-04-27 03:39:34 [47,367ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: omni.ui.dll!omni::ui::FontHelper::_pushFont+0x31f
2025-04-27 03:39:34 [47,368ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: omni.ui.dll!omni::ui::FontHelper::_pushFont+0x219
2025-04-27 03:39:34 [47,370ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: omni.ui.dll!omni::ui::AbstractField::onStyleUpdated+0x24
2025-04-27 03:39:34 [47,372ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: omni.ui.dll!omni::ui::Widget::updateStyle+0x15f
2025-04-27 03:39:34 [47,374ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: omni.ui.dll!omni::ui::AbstractField::setComputedContentWidth+0x1349
2025-04-27 03:39:34 [47,378ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: _ui.cp310-win_amd64.pyd!omni::ui::StyleStore<char const * __ptr64>::~StyleStore<char const * __ptr64>+0x7813d
2025-04-27 03:39:34 [47,388ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: _ui.cp310-win_amd64.pyd!+0x380a1
2025-04-27 03:39:34 [47,390ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: _ui.cp310-win_amd64.pyd!omni::ui::StyleStore<char const * __ptr64>::~StyleStore<char const * __ptr64>+0xb210
2025-04-27 03:39:34 [47,393ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: _ui.cp310-win_amd64.pyd!+0x1ede6
2025-04-27 03:39:34 [47,393ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: _ui.cp310-win_amd64.pyd!+0x1487c
2025-04-27 03:39:34 [47,394ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: python310.dll!PyCFunction_GetFlags+0xf16
2025-04-27 03:39:34 [47,395ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: python310.dll!PyObject_MakeTpCall+0x13b
2025-04-27 03:39:34 [47,397ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: python310.dll!PyMethod_Self+0x109
2025-04-27 03:39:34 [47,398ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: python310.dll!PyVectorcall_Call+0xbd
2025-04-27 03:39:34 [47,400ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: python310.dll!PyType_Ready+0x43e8
2025-04-27 03:39:34 [47,402ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: python310.dll!PyType_Name+0x164b
2025-04-27 03:39:34 [47,406ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: carb.scripting-python.plugin.dll!carbOnPluginStartupEx+0x11b9
2025-04-27 03:39:34 [47,408ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: python310.dll!PyObject_MakeTpCall+0x13b
2025-04-27 03:39:34 [47,410ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,412ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,413ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: python310.dll!PyEval_EvalFrameDefault+0x396b
2025-04-27 03:39:34 [47,414ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,415ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,417ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: python310.dll!PyVectorcall_Call+0xbd
2025-04-27 03:39:34 [47,418ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: python310.dll!PyEval_GetFuncDesc+0x602
2025-04-27 03:39:34 [47,420ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: python310.dll!PyEval_EvalFrameDefault+0x25b2
2025-04-27 03:39:34 [47,422ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,425ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,429ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: python310.dll!PyOS_URandomNonblock+0x59
2025-04-27 03:39:34 [47,431ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,433ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,435ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: python310.dll!PyEval_EvalFrameDefault+0x390f
2025-04-27 03:39:34 [47,436ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,436ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,438ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: python310.dll!PyOS_URandomNonblock+0x59
2025-04-27 03:39:34 [47,439ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,441ms] [Fatal] [carb.crashreporter-breakpad.plugin] 043: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,443ms] [Fatal] [carb.crashreporter-breakpad.plugin] 044: python310.dll!PyEval_EvalFrameDefault+0x390f
2025-04-27 03:39:34 [47,445ms] [Fatal] [carb.crashreporter-breakpad.plugin] 045: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,447ms] [Fatal] [carb.crashreporter-breakpad.plugin] 046: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,451ms] [Fatal] [carb.crashreporter-breakpad.plugin] 047: python310.dll!PyObject_FastCallDictTstate+0xd4
2025-04-27 03:39:34 [47,453ms] [Fatal] [carb.crashreporter-breakpad.plugin] 048: python310.dll!PyObject_Call_Prepend+0xa2
2025-04-27 03:39:34 [47,455ms] [Fatal] [carb.crashreporter-breakpad.plugin] 049: python310.dll!PyType_Ready+0x43db
2025-04-27 03:39:34 [47,457ms] [Fatal] [carb.crashreporter-breakpad.plugin] 050: python310.dll!PyType_Name+0x164b
2025-04-27 03:39:34 [47,458ms] [Fatal] [carb.crashreporter-breakpad.plugin] 051: python310.dll!PyObject_Call+0xf7
2025-04-27 03:39:34 [47,460ms] [Fatal] [carb.crashreporter-breakpad.plugin] 052: python310.dll!PyEval_GetFuncDesc+0x602
2025-04-27 03:39:34 [47,461ms] [Fatal] [carb.crashreporter-breakpad.plugin] 053: python310.dll!PyEval_EvalFrameDefault+0x25b2
2025-04-27 03:39:34 [47,462ms] [Fatal] [carb.crashreporter-breakpad.plugin] 054: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,463ms] [Fatal] [carb.crashreporter-breakpad.plugin] 055: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,465ms] [Fatal] [carb.crashreporter-breakpad.plugin] 056: python310.dll!PyOS_URandomNonblock+0x59
2025-04-27 03:39:34 [47,467ms] [Fatal] [carb.crashreporter-breakpad.plugin] 057: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,469ms] [Fatal] [carb.crashreporter-breakpad.plugin] 058: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,473ms] [Fatal] [carb.crashreporter-breakpad.plugin] 059: python310.dll!PyEval_EvalFrameDefault+0x32c3
2025-04-27 03:39:34 [47,475ms] [Fatal] [carb.crashreporter-breakpad.plugin] 060: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,477ms] [Fatal] [carb.crashreporter-breakpad.plugin] 061: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,479ms] [Fatal] [carb.crashreporter-breakpad.plugin] 062: python310.dll!PyOS_URandomNonblock+0x59
2025-04-27 03:39:34 [47,480ms] [Fatal] [carb.crashreporter-breakpad.plugin] 063: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,481ms] [Fatal] [carb.crashreporter-breakpad.plugin] 064: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,482ms] [Fatal] [carb.crashreporter-breakpad.plugin] 065: python310.dll!PyEval_EvalFrameDefault+0x390f
2025-04-27 03:39:34 [47,483ms] [Fatal] [carb.crashreporter-breakpad.plugin] 066: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,485ms] [Fatal] [carb.crashreporter-breakpad.plugin] 067: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,486ms] [Fatal] [carb.crashreporter-breakpad.plugin] 068: python310.dll!PyEval_GetFuncDesc+0x602
2025-04-27 03:39:34 [47,488ms] [Fatal] [carb.crashreporter-breakpad.plugin] 069: python310.dll!PyEval_EvalFrameDefault+0x25b2
2025-04-27 03:39:34 [47,490ms] [Fatal] [carb.crashreporter-breakpad.plugin] 070: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,494ms] [Fatal] [carb.crashreporter-breakpad.plugin] 071: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,496ms] [Fatal] [carb.crashreporter-breakpad.plugin] 072: python310.dll!PyOS_URandomNonblock+0x59
2025-04-27 03:39:34 [47,499ms] [Fatal] [carb.crashreporter-breakpad.plugin] 073: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,499ms] [Fatal] [carb.crashreporter-breakpad.plugin] 074: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,500ms] [Fatal] [carb.crashreporter-breakpad.plugin] 075: python310.dll!PyEval_EvalFrameDefault+0x390f
2025-04-27 03:39:34 [47,501ms] [Fatal] [carb.crashreporter-breakpad.plugin] 076: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,503ms] [Fatal] [carb.crashreporter-breakpad.plugin] 077: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,504ms] [Fatal] [carb.crashreporter-breakpad.plugin] 078: python310.dll!PyOS_URandomNonblock+0x59
2025-04-27 03:39:34 [47,506ms] [Fatal] [carb.crashreporter-breakpad.plugin] 079: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,508ms] [Fatal] [carb.crashreporter-breakpad.plugin] 080: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,511ms] [Fatal] [carb.crashreporter-breakpad.plugin] 081: python310.dll!PyEval_EvalFrameDefault+0x390f
2025-04-27 03:39:34 [47,513ms] [Fatal] [carb.crashreporter-breakpad.plugin] 082: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,515ms] [Fatal] [carb.crashreporter-breakpad.plugin] 083: python310.dll!PyFunction_Vectorcall+0x3e
2025-04-27 03:39:34 [47,516ms] [Fatal] [carb.crashreporter-breakpad.plugin] 084: python310.dll!PyOS_URandomNonblock+0x59
2025-04-27 03:39:34 [47,516ms] [Fatal] [carb.crashreporter-breakpad.plugin] 085: python310.dll!PyEval_GetFuncDesc+0x23f
2025-04-27 03:39:34 [47,517ms] [Fatal] [carb.crashreporter-breakpad.plugin] 086: python310.dll!PyEval_GetFuncDesc+0x3d7
2025-04-27 03:39:34 [47,519ms] [Fatal] [carb.crashreporter-breakpad.plugin] 087: python310.dll!PyEval_EvalFrameDefault+0x38f9
2025-04-27 03:39:34 [47,520ms] [Fatal] [carb.crashreporter-breakpad.plugin] 088: python310.dll!PyEval_EvalFrameDefault+0x599b
2025-04-27 03:39:34 [47,521ms] [Fatal] [carb.crashreporter-breakpad.plugin] 089: python310.dll!PyEval_EvalCode+0x82
2025-04-27 03:39:34 [47,533ms] [Fatal] [carb.crashreporter-breakpad.plugin] 090: carb.scripting-python.plugin.dll!+0x12207
2025-04-27 03:39:34 [47,536ms] [Fatal] [carb.crashreporter-breakpad.plugin] 091: carb.scripting-python.plugin.dll!+0x11654
2025-04-27 03:39:34 [47,539ms] [Fatal] [carb.crashreporter-breakpad.plugin] 092: carb.scripting-python.plugin.dll!+0x11f0a
2025-04-27 03:39:34 [47,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] 093: omni.ext.plugin.dll!carbOnPluginShutdown+0x38703
2025-04-27 03:39:34 [47,543ms] [Fatal] [carb.crashreporter-breakpad.plugin] 094: omni.ext.plugin.dll!carbOnPluginShutdown+0x22615
2025-04-27 03:39:34 [47,546ms] [Fatal] [carb.crashreporter-breakpad.plugin] 095: omni.ext.plugin.dll!carbOnPluginShutdown+0x528b8
2025-04-27 03:39:34 [47,547ms] [Fatal] [carb.crashreporter-breakpad.plugin] 096: omni.ext.plugin.dll!carbOnPluginShutdown+0x4f885
2025-04-27 03:39:34 [47,548ms] [Fatal] [carb.crashreporter-breakpad.plugin] 097: omni.ext.plugin.dll!carbOnPluginShutdown+0x5ba72
2025-04-27 03:39:34 [47,558ms] [Fatal] [carb.crashreporter-breakpad.plugin] 098: omni.kit.app.plugin.dll!+0x25469
2025-04-27 03:39:34 [47,559ms] [Fatal] [carb.crashreporter-breakpad.plugin] 099: omni.kit.app.plugin.dll!+0x275e1
2025-04-27 03:39:34 [47,561ms] [Fatal] [carb.crashreporter-breakpad.plugin] 100: omni.kit.app.plugin.dll!+0x20677
2025-04-27 03:39:34 [47,571ms] [Fatal] [carb.crashreporter-breakpad.plugin] 101: kit.exe!+0x62b5
2025-04-27 03:39:34 [47,573ms] [Fatal] [carb.crashreporter-breakpad.plugin] 102: kit.exe!+0x696f
2025-04-27 03:39:34 [47,575ms] [Fatal] [carb.crashreporter-breakpad.plugin] 103: kit.exe!+0x7060
2025-04-27 03:39:34 [47,579ms] [Fatal] [carb.crashreporter-breakpad.plugin] 104: KERNEL32.DLL!BaseThreadInitThunk+0x17
2025-04-27 03:39:34 [47,581ms] [Fatal] [carb.crashreporter-breakpad.plugin] 105: ntdll.dll!RtlUserThreadStart+0x2c
