Clarification regarding OTA Updates of Jetpack 5.1.2 R35.4.1 on Jetson Xavier NX eMMC A205 carrier board
I am currently using a Jetson Xavier NX eMMC 16 GB SoC on a A205 Seed Studio carrier board running a Jetpack 5.1. I just wanted to know if I am able to run OTA updates to update the system to Jetpack 5.1.2 using the current documentation listed here - Software Packages and the Update Mechanism — Jetson Linux<br/>Developer Guide 34.1 documentation.
Its mentioned here that it supports jetson xavier nx dev kit eMMC. My system doesn’t have any external hard drive. It runs just based of the 16 GB available on chip. Would my current setup qualify for these updates? If not, how do I perform OTA updates on my system?
Hi surajgampa95,
Since you are using a custom carrier board, I would suggest confirming this with your vendor. The link you shared is called image-based OTA, it would need to generate OTA package from your custom BSP package. If there’s JP5.1.2 custom BSP package ready for your board, it should work with this method.
