Hello! I’m working on a vise assembly in Isaac Sim and would like to only enable collision between the opposing vise plates and nothing else. The whole structure is grouped under an Articulation Root with self collision turned off. Is there a way to selectively enable collision for just the two opposing vice plates? I’ve explored using Collision Groups but didn’t have much luck. If you have any ideas or better ways to structure things lmk!
Related topics
| Excluding joint from articulation causes simulation instability | 3 | 954 | March 10, 2023 | |
| Unity Flex Particles Disable Collision | 0 | 519 | February 16, 2019 | |
| Collision filter | 4 | 2388 | April 5, 2024 | |
| Bug report? Two non-colliding objects collide with each other in 3ds max 2012 | 4 | 1231 | May 24, 2013 | |
| Disable/Ignore collisions calculations between Controller and Object? | 1 | 1524 | November 20, 2014 | |
| static mesh actor and cloth mesh collision.(Physx 3.3.1) | 0 | 719 | October 8, 2014 | |
| Self-Collision avoiding parent links or links higher in the kinematic chain | 14 | 3621 | May 11, 2023 | |
| How to detect self collision in articulation like robotic arm? | 4 | 1135 | March 6, 2023 | |
| Flex two containers collider | 0 | 567 | November 16, 2017 | |
| Is it possible to disable collision response but keep have the onContact ? | 1 | 672 | March 28, 2017 |
