I am trying to use the TX2 module with the Orbitty Carrier. I followed the instruction from the Connect Tech website and successfully flashed the TX2. However, I never got video signal from the TX2. Does anyone in the forum make it work?
I know nothing about the Orbitty, but is your monitor purely HDMI without adapters? If it has any kind of adapter, what is the arrangement? What do you get from this:
If you still aren’t getting video after following Linuxdev’s suggestions, and confirmed that you get video from TX2 on the devkit reference carrier board, reach out to ConnectTech’s support hotline, as it should be working with that model unit.
