Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other (940-63710-0010-300)
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
I had been trying to ssh but it gives the response connection refused.
devgan@ES:/$ ssh nvidia@192.168.10.186
ssh: connect to host 192.168.10.186 port 22: Connection refused
I tried to do that, i am getting destination port unreachable.
ping 192.168.10.186
PING 192.168.10.186 (192.168.10.186) 56(84) bytes of data.
From 192.168.9.1 icmp_seq=1 Destination Port Unreachable
From 192.168.9.1 icmp_seq=2 Destination Port Unreachable
So i even tried to ping to 192.168.9.1 and i received the same response Destination Port Unreachable.
the response of traceroute 192.168.10.186 :
traceroute -n 192.168.10.186
traceroute to 192.168.10.186 (192.168.10.186), 30 hops max, 60 byte packets
1 192.168.9.1 1.025 ms 1.328 ms 1.385 ms
2 192.168.9.1 1.913 ms 1.958 ms 2.332 ms
It seems like there might be an issue with the network connection or configuration. You could try resetting the network settings or check if the IP address of the device you’re trying to connect to is correct. If the issue persists, you may want to reach out to your network administrator or IT support for further assistance.
