Hi Meng,
Thank you for the reply.
Initially, the device configuration parameter PCI_ATOMIC_MODE
was set to PCI_ATOMIC_DISABLED_EXT_ATOMIC_ENABLED(0)
. Then I changed it to PCI_ATOMICS_ENABLED_EXT_ATOMICS_ENABLED_SERIALIZED(1)
. Rebooted the machine and the DPU. Still I am facing same issue.
Here is the PCI tree focused to DPU:
+-[0000:16]-+-00.0 Intel Corporation Ice Lake Memory Map/VT-d
| +-00.1 Intel Corporation Ice Lake Mesh 2 PCIe
| +-00.2 Intel Corporation Ice Lake RAS
| +-00.4 Intel Corporation Ice Lake IEH
| \-02.0-[17]--+-00.0 Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller
| +-00.1 Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller
| \-00.2 Mellanox Technologies MT42822 BlueField-2 SoC Management Interface
So, it looks like BF2 is connected through pcie bridge 0000:16:02.0. Here is lspci -vvv -s 0000:16:02.0
[Printing out full output just to make sure I am not missing anything]
16:02.0 PCI bridge: Intel Corporation Device 347a (rev 04) (prog-if 00 [Normal decode])
DeviceName: SLOT 2
Physical Slot: 2
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 133
NUMA node: 0
Region 0: Memory at 207ffe000000 (64-bit, non-prefetchable) [size=128K]
Bus: primary=16, secondary=17, subordinate=17, sec-latency=0
I/O behind bridge: 0000f000-00000fff [disabled]
Memory behind bridge: 9b800000-9b8fffff [size=1M]
Prefetchable memory behind bridge: 0000207ffa000000-0000207ffdffffff [size=64M]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity+ SERR+ NoISA- VGA- VGA16- MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Capabilities: [40] Express (v2) Root Port (Slot+), MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0
ExtTag+ RBE+
DevCtl: CorrErr- NonFatalErr- FatalErr+ UnsupReq-
RlxdOrd- ExtTag+ PhantFunc- AuxPwr- NoSnoop-
MaxPayload 512 bytes, MaxReadReq 4096 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #1, Speed 16GT/s, Width x16, ASPM not supported
ClockPM- Surprise+ LLActRep+ BwNot+ ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 16GT/s (ok), Width x16 (ok)
TrErr- Train- SlotClk+ DLActive+ BWMgmt- ABWMgmt-
SltCap: AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
Slot #2, PowerLimit 75.000W; Interlock- NoCompl-
SltCtl: Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
Control: AttnInd Off, PwrInd Off, Power- Interlock-
SltSta: Status: AttnBtn- PowerFlt- MRL- CmdCplt- PresDet+ Interlock-
Changed: MRL- PresDet+ LinkState+
RootCap: CRSVisible+
RootCtl: ErrCorrectable- ErrNon-Fatal+ ErrFatal+ PMEIntEna+ CRSVisible+
RootSta: PME ReqID 0000, PMEStatus- PMEPending-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+, NROPrPrP+, LTR-
10BitTagComp+, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS-, LN System CLS Not Supported, TPHComp+, ExtTPHComp-, ARIFwd+
AtomicOpsCap: Routing+ 32bit+ 64bit+ 128bitCAS+
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd+
AtomicOpsCtl: ReqEn+ EgressBlck-
LnkCtl2: Target Link Speed: 16GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [80] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [88] Subsystem: Intel Corporation Device 0000
Capabilities: [90] MSI: Enable+ Count=1/1 Maskable- 64bit-
Address: fee00018 Data: 0000
Capabilities: [100 v1] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol+
UESvrt: DLP+ SDES+ TLP+ FCP+ CmpltTO+ CmpltAbrt+ UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ AdvNonFatalErr+
AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn+ ECRCChkCap+ ECRCChkEn+
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap+
HeaderLog: 4a000002 17020008 fc300048 00000000
RootCmd: CERptEn- NFERptEn- FERptEn-
RootSta: CERcvd- MultCERcvd- UERcvd- MultUERcvd-
FirstFatal- NonFatalMsg- FatalMsg- IntMsg 0
ErrorSrc: ERR_COR: 0000 ERR_FATAL/NONFATAL: 0000
Capabilities: [148 v1] Access Control Services
ACSCap: SrcValid+ TransBlk+ ReqRedir+ CmpltRedir+ UpstreamFwd+ EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [180 v1] Vendor Specific Information: ID=0003 Rev=0 Len=00a <?>
Capabilities: [190 v1] Downstream Port Containment
DpcCap: INT Msg #0, RPExt+ PoisonedTLP+ SwTrigger+ RP PIO Log 4, DL_ActiveErr+
DpcCtl: Trigger:0 Cmpl- INT- ErrCor- PoisonedTLP- SwTrigger- DL_ActiveErr-
DpcSta: Trigger- Reason:00 INT- RPBusy- TriggerExt:00 RP PIO ErrPtr:10
Source: 0000
Capabilities: [200 v1] Secondary PCI Express
LnkCtl3: LnkEquIntrruptEn-, PerformEqu-
LaneErrStat: 0
Capabilities: [400 v1] Data Link Feature <?>
Capabilities: [410 v1] Physical Layer 16.0 GT/s <?>
Capabilities: [450 v1] Lane Margining at the Receiver <?>
Kernel driver in use: pcieport
I couldn’t find anything like “AtomicOp completer”. But following capabilities are there in the context of AtomicOp:
Does that mean the PCIe bridge doesn’t support AtomicOp completer?
Here is lspic output for the BF2 device after setting PCI_ATOMIC_MODE
lspci -vvv -s 0000:17:0.0
17:00.0 Ethernet controller: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller (rev 01)
Subsystem: Mellanox Technologies MT42822 BlueField-2 integrated ConnectX-6 Dx network controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 18
NUMA node: 0
Region 0: Memory at 207ffc000000 (64-bit, prefetchable) [size=32M]
Expansion ROM at <ignored> [disabled]
Capabilities: [60] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 75.000W
DevCtl: CorrErr- NonFatalErr+ FatalErr+ UnsupReq+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 16GT/s, Width x16, ASPM not supported
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABC, TimeoutDis+, NROPrPrP-, LTR-
FRS-, TPHComp-, ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
Capabilities: [48] Vital Product Data
Product Name: BlueField-2 DPU 100GbE Dual-Port QSFP56, Crypto Disabled, 16GB on-board DDR, 1GbE OOB management, Tall Bracket
Read-only fields:
[PN] Part number: MBF2M516A-CENOT
[EC] Engineering changes: B2
[V2] Vendor specific: MBF2M516A-CENOT
[SN] Serial number: MT2125X06705
[V3] Vendor specific: aae27201e8d3eb118000b8cef6d21326
[VA] Vendor specific: MLX:MN=MLNX:CSKU=V2:UUID=V3:PCI=V0:MODL=BF2M516A
[V0] Vendor specific: PCIeGen4 x16
[VU] Vendor specific: MT2125X06705MLNXS0D0F0
[RV] Reserved: checksum good, 1 byte(s) reserved
End
Capabilities: [9c] MSI-X: Enable+ Count=64 Masked-
Vector table: BAR=0 offset=00002000
PBA: BAR=0 offset=00003000
Capabilities: [c0] Vendor Specific Information: Len=18 <?>
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=375mA PME(D0-,D1-,D2-,D3hot-,D3cold+)
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES- TLP+ FCP+ CmpltTO+ CmpltAbrt+ UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
AERCap: First Error Pointer: 04, ECRCGenCap+ ECRCGenEn+ ECRCChkCap+ ECRCChkEn+
MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
HeaderLog: 00000000 00000000 00000000 00000000
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [1c0 v1] Secondary PCI Express
LaneErrStat: 0
Capabilities: [230 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [320 v1] Lane Margining at the Receiver <?>
Capabilities: [370 v1] Physical Layer 16.0 GT/s <?>
Capabilities: [420 v1] Data Link Feature <?>
Kernel driver in use: mlx5_core
Kernel modules: mlx5_core
In the context of PCIe AtomicOp following capabilities can be noted:
Let me know what you think. Thank you.
