Please confirm with Arducam if the driver support JP6.0
jetpac 6.0 is supported arducam
Yes, I still get the same error. I wrote Ubuntu 22.04 wrong by the way.
Doesn’t looks like Arducam support JP6.
You can check with Arducam if needs driver.
If I call a random person passing by, they will give me clearer information. I sent an e-mail about this and it says the driver is not supported. However, it seems to be supported on the site you sent. I wish you would check the site before you respond. None of the responses you have given are helpful. It has been 3 or 4 weeks.
The driver is developer by Arducam. Sorry to tell we can’t help on it.
However suppose if the sensor is compatible with RP IMX477 you can try don’t install arducam driver but just run the jetson-io to enable.
Dear ShaneCCC
I am experiencing a problem when attempting to run the Jetson IO script on my Nvidia Jetson Orin Nano Developer Kit, which is currently using JetPack 6 (version 36.3). After executing the command sudo /opt/nvidia/jetson-io/jetson-io.py, the panel does not open as expected.
I am trying to set up the ArduCam IMX477 camera, and this setup is crucial for my installation process. I have attached an image that illustrates the issue I am encountering for your reference.
I would appreciate your guidance on how to resolve this problem. Please advise on any steps I can take to troubleshoot or fix this issue. Your prompt assistance would be greatly appreciated, as I am eager to continue with my project.
Thank you for your support.
Best regards,
Yasin Körüs
Do you install the JP6.0 by sdkmanager?
Hi ShaneCCC,
I’m writing from my friend’s account; this is Yasin Körüs. I installed JP6.0 using the SDK Manager. The installation went smoothly, and all necessary components were successfully loaded.
If you have any further questions, I’d be happy to help.
Best regards,
Yasin Körüs
