Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
I’m trying to test the OpenDDS (Open Data Distribution Package) that comes along with DRIVE OS, by following this piece of documentation: https://docs.nvidia.com/drive/drive-os-5.2.6.0L/drive-os/index.html#page/DRIVE_OS_Linux_SDK_NGC_Development_Guide/opendds_user_guide_linux.html#
The problem is that I can’t find any of the libraries or sample binaries. I’ve been searching in both the flashed board and the docker containers that Nvidia provides, but still can’t find any.
Could you please point out where exactly the libraries and samples can be found?
Dear @AlejandroSolis-RidgeRun,
Could you confirm if you have select openDDS in sdkmanager GUI while installing DRIVE OS 5.2.6?
Hi @SivaRamaKrishnaNV , yes I confirm having selected the openDDS option.
I could see the dds binaries at /path/to/DRIVEOS/drive-t186ref-linux/samples/dds on host and ~/drive-t186ref-linux/samples/dds on target.
On target, I could see libraries at /usr/lib/
nvidia@tegra-ubuntu:/usr/lib$ ls -la *DDS*
lrwxrwxrwx 1 root root 25 Sep 13 09:01 libOpenDDS_Dcps.so -> libOpenDDS_Dcps.so.3.13.0
-rwxr-xr-x 1 root root 49733232 Sep 13 09:01 libOpenDDS_Dcps.so.3.13.0
lrwxrwxrwx 1 root root 25 Sep 13 09:01 libOpenDDS_FACE.so -> libOpenDDS_FACE.so.3.13.0
-rwxr-xr-x 1 root root 2581336 Sep 13 09:01 libOpenDDS_FACE.so.3.13.0
lrwxrwxrwx 1 root root 30 Sep 13 09:01 libOpenDDS_Federator.so -> libOpenDDS_Federator.so.3.13.0
-rwxr-xr-x 1 root root 13696984 Sep 13 09:01 libOpenDDS_Federator.so.3.13.0
lrwxrwxrwx 1 root root 38 Sep 13 09:01 libOpenDDS_InfoRepoDiscovery.so -> libOpenDDS_InfoRepoDiscovery.so.3.13.0
-rwxr-xr-x 1 root root 3369984 Sep 13 09:01 libOpenDDS_InfoRepoDiscovery.so.3.13.0
lrwxrwxrwx 1 root root 32 Sep 13 09:01 libOpenDDS_InfoRepoLib.so -> libOpenDDS_InfoRepoLib.so.3.13.0
-rwxr-xr-x 1 root root 5574512 Sep 13 09:01 libOpenDDS_InfoRepoLib.so.3.13.0
lrwxrwxrwx 1 root root 33 Sep 13 09:01 libOpenDDS_InfoRepoServ.so -> libOpenDDS_InfoRepoServ.so.3.13.0
-rwxr-xr-x 1 root root 846432 Sep 13 09:01 libOpenDDS_InfoRepoServ.so.3.13.0
lrwxrwxrwx 1 root root 30 Sep 13 09:01 libOpenDDS_Multicast.so -> libOpenDDS_Multicast.so.3.13.0
-rwxr-xr-x 1 root root 4179664 Sep 13 09:01 libOpenDDS_Multicast.so.3.13.0
lrwxrwxrwx 1 root root 40 Sep 13 09:01 libOpenDDS_QOS_XML_XSC_Handler.so -> libOpenDDS_QOS_XML_XSC_Handler.so.3.13.0
-rwxr-xr-x 1 root root 3518008 Sep 13 09:01 libOpenDDS_QOS_XML_XSC_Handler.so.3.13.0
lrwxrwxrwx 1 root root 25 Sep 13 09:01 libOpenDDS_Rtps.so -> libOpenDDS_Rtps.so.3.13.0
-rwxr-xr-x 1 root root 10995784 Sep 13 09:01 libOpenDDS_Rtps.so.3.13.0
lrwxrwxrwx 1 root root 29 Sep 13 09:01 libOpenDDS_Rtps_Udp.so -> libOpenDDS_Rtps_Udp.so.3.13.0
-rwxr-xr-x 1 root root 6581720 Sep 13 09:01 libOpenDDS_Rtps_Udp.so.3.13.0
lrwxrwxrwx 1 root root 29 Sep 13 09:01 libOpenDDS_Security.so -> libOpenDDS_Security.so.3.13.0
-rwxr-xr-x 1 root root 6355080 Sep 13 09:01 libOpenDDS_Security.so.3.13.0
lrwxrwxrwx 1 root root 26 Sep 13 09:01 libOpenDDS_Shmem.so -> libOpenDDS_Shmem.so.3.13.0
-rwxr-xr-x 1 root root 1872984 Sep 13 09:01 libOpenDDS_Shmem.so.3.13.0
lrwxrwxrwx 1 root root 24 Sep 13 09:01 libOpenDDS_Tcp.so -> libOpenDDS_Tcp.so.3.13.0
-rwxr-xr-x 1 root root 3148760 Sep 13 09:01 libOpenDDS_Tcp.so.3.13.0
lrwxrwxrwx 1 root root 24 Sep 13 09:01 libOpenDDS_Udp.so -> libOpenDDS_Udp.so.3.13.0
-rwxr-xr-x 1 root root 2498088 Sep 13 09:01 libOpenDDS_Udp.so.3.13.0
lrwxrwxrwx 1 root root 28 Sep 13 09:01 libOpenDDS_monitor.so -> libOpenDDS_monitor.so.3.13.0
-rwxr-xr-x 1 root root 20188232 Sep 13 09:01 libOpenDDS_monitor.so.3.13.0
Do you see NV_DDS_TARGET_COMP.log log under ~/.nvsdkm/logs/DRIVE_OS_5.2.6_SDK_Linux_OSWithSamples/ ?
Thank you! Yes, I see the libraries on both filesystems, and somehow the samples were deleted from one of the SoC, but I can see them inside the second SoC so it was probably my fault. Thank you!
