Error after flashing XAVIER NX 16GB with Jetpack 4.6.3 on auvidea JNX33 carrier board
hello all,
This is two days i’m trying to start my xavier nx 16GB on auvidea JNX33 carrier board, i followed the auvidea user guide as well as the method i read from the forum at this page Error flashing Xavier NX 16GB on SD Card on Auvidea Carrier Board
But after a successful flashing, my jetson can’t boot normally. i can see errors like failed to start nvpmodel, failed to start docker container.
Can someone please provide me with a solution? it’s my very first real experience with jetson. Can i easily make it work using jetpack 5. for example? please help me
You should contact with the board vendor first. I can guide you how to dump log to check if your board is booting up or not.
But my guidance is only for NV devkit. Not for your Auvidea board. The pin may not be the same location. I don’t know.
Sorry for your issue it was exhausting for me but I hope you too also will able to solve.
Is it booting after errors? There is a solution for “failed to start nvpmodel” error at:
Also could you share screenshots of errors or more information?
thank for your answer @WayneWWW
on my carrier board, i have buttons to switch from recovery mode to reset or boot mode. I think pin is not needed on it.
No, I didn’t share any solution yet.
I was tryin to say you need get a usb-ttl cable and connect it between your jetson and host machine. Dump the log and share it here.
My previous point was I don’t know if your board has this pin out or not. I guess it would have. But you need to check with the board vendor’s document.
Thanks, it is not booting after those errors, i read the solution on "failed to start nvpmodel but i dont really know where to find /etc/nvpmodel.com,
is it on my host pc?
Some other points here before you dump the log out…
I don’t think you should care about that “failed to start nvpmodel, failed to start docker container.” error at this moment.
→ Your “boot failed” actually means the GUI does not show up and spew you some logs.
The point you should worry about is why the GUI does not show up. Those nvmpmodel error or docker error does not matter to the GUI. So not something you need to worry at this moment.
hello guys,
I don’t yet get usb-ttl cable, i just ordered it.
The first error i’m getting above all is ''failed to start load kernel module" does anyone have any idea about a solution?
I can answer all of your questions after you get the cable.
But just in case, multiple reflash is still needed after you got the cable.
