We tried flashing the same SOM on a different carrier board, that we had earlier used for flashing and it was successful but this specific SOM kept failing during flashing.
Can you suggest any other method.
I have tried flashing using other carrier boards but the issue still persists.
I have followed the same steps as mentioned in the SDK manager.
Will try out once again, meanwhile I have shared new logs, please check.
@hitesh.pant21 , are you coworking with @anand.rude ? I just want to make sure we are all talking about same error on same devices. But not something different.
Can you just flash it with jp4.6.1 and share me the log but not just keep telling me “it failed, that failed”.
Seriously, I cannot approve anything just from your unclear description. We need logs. Not just these comments.
I don’t know what goes wrong here. I already said many times, only version >= jp4.6.1 can flash NX 16GB by default. You don’t need to try any previous version and tell me it cannot work. That was expected.
Please share me both host side log and uart log during flash error happens.
