arturo
December 21, 2020, 5:53pm
1
I’ve upgraded my OS to CentOS 8.3 in order to reinstall MOFED (5.1-2.5.8.0). However, I’m getting this error message:
Current operation system is not supported!
I’m guessing that it refers to the OS but I had never seen this message before. The command is:
sudo ./mlnxofedinstall --kernel $KERNEL --kernel-sources /usr/src/kernels/${KERNEL} --add-kernel-support
where KERNEL is 4.18.0-240.1.1.el8_3.x86_64 , and the kernels are located at /usr/src/kernels/4.18.0-240.1.1.el8_3.x86_64 with the following structure:
arch crypto fs ipc lib mm samples sound usr
block drivers include Kconfig Makefile Module.symvers scripts System.map virt
certs firmware init kernel Makefile.rhelver net security tools vmlinux.id
I really don’t see anything wrong here so I’m unsure why of the error message.
samerka
December 22, 2020, 2:45pm
2
Hi Arturo,
Could you please try the below command:
./mlnxofedinstall --add-kernel-support --force --skip-distro-check
Thanks,
Samer
arturo
December 22, 2020, 4:45pm
3
Hello Samer,
It’s still producing the same error.
Arturo
samerka
December 23, 2020, 9:00am
4
Hi Arturo,
Please provide the below outputs :
uname -r
cat /etc/redhat-release
OFED installation log
full command and error
For further investigation, i suggest to open support ticket networking-support@nvidia.com
Thanks,
Samer
arturo
December 23, 2020, 12:56pm
5
Hi Samer,
The requested info:
1 - 4.18.0-240.1.1.el8_3.x86_64
2 - CentOS Linux release 8.3.2011
3 - I double checked (because it was my recollection) but there’s no log as nothing has happened. The installation stops right after calling mlxnofedinstall.
Arturo
