Failure in isaac_ros_gxf during build of isaac_ros_nitros
Isaac Sim Version: 4.5.0
Ubuntu 22.04
hello.
When building the following four in a local environment, I get a failure on isaac_ros_gxf for isaac_ros_nitros.
Build target:
Command:
colcon build --symlink-install
Error message:
--- stderr: isaac_ros_gxf
CMake Error at CMakeLists.txt:61 (set_property):
 Error evaluating generator expression:
 $<INSTALL_PREFIX>
  INSTALL_PREFIX is a marker for install(EXPORT) only.  It should never be
 evaluated.
Is this an Isaac Sim topic? If it’s related to Isaac ROS, please create your topic in Isaac ROS - NVIDIA Developer Forums. Thanks.
