Failure while flashing Drive AGX Xavier via SDK Manager
We have been encountering an error while flashing the DRIVE AGX connected to a Ubuntu Host. Below is a screenshot of the error and also the relevant software details. Please advise on what the problem could be and how we can proceed in this case. Thank you!
Software Version
[✓] DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
[✓] Linux
QNX
other
Hardware Platform
[✓] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.9.1.10844
[✓] other - 2.0.0.11402
Host Machine Version
[✓] native Ubuntu 18.04
other
Dear @niveditha.bhat,
The log indicates, target could not set to recovery mode. Could you share lsusb output on host. Do you see difference in lsusb when target is connected/disconnected?
Hi @SivaRamaKrishnaNV ,
Thank you for the response.
The first is with USB connected and second is without.
There is definitely a difference when the target is connected or disconnected.
–Linux Foundation 3.0 root hub
–Linux Foundation 2.0 root hub
These entries appear only on connecting.
After connecting the target, please check connecting to aurix console via minicom and run tegrarecovery x1 on and tegrareset x1 to set Tegra A in recovery mode. After setting Tegra A into recovery mode, I would expect to see an additional NVIDIA device entry in lsusb log.
