groot
May 16, 2017, 6:02am
1
Hello, Nvidia’s experts.
I tried to run the sample_lidar_replay with Velodyne 32E lidar in real time.
I connected the power on lidar and connected lidar to blue ethernet cable of drivepx2.
And, I entered this.
$ ./sample_lidar_replay --ip=192.168.xx.xxx --device=VELO_HDL32E
Then, the following log was output.
INVALID PARAMETERS.
How can I verify each parameters?
I don’t know whether the connection is right or not.
Hello groot,
Velodyne Lidar will be supported from next DriveWorks version. Thanks.
groot
May 17, 2017, 2:23am
3
Thanks for your answer
But, I read the Driveworks SDK Release Note(0.2.1).
On the Note, Veloyne(HDL32E) was supported.
Is it just hardware connection?
And, in next DriveWorks version, Could you tell me what the next version of DriveWorks will support?
Hello groot,
Oh sorry, yes we support Veloyne(HDL32E) on DriveWorks 0.2.1.
I think you missed --port=[lidar port] in the command line.
Could you please see “/usr/local/driveworks-0.2.1/doc/nvdwx_html/dwx_lidar_replay_sample.html”? Thanks.
groot
May 18, 2017, 12:39pm
5
I had read the document and tried to enter several ports.
But, It didn’t work.
So I want to know if the lider is well connected.
Is there a way to check connect of the lidar device?
Hello groot,
Yes, I would expect that… as if you look into the code it needs that
if (strcmp(arguments.get(“ip”).c_str(), “”) != 0) {
if (strcmp(arguments.get(“port”).c_str(), “”) != 0) {
if (strcmp(arguments.get("device").c_str(), "") != 0) {
if (strcmp(arguments.get("scan-frequency").c_str(), "") != 0) {
protocolString = "lidar.socket";
parameterString = "ip=" + arguments.get("ip");
parameterString += ",port=" + arguments.get("port");
parameterString += ",device=" + arguments.get("device");
parameterString += ",scan-frequency=" + arguments.get("scan-frequency");
gRecordedLidar = false;
validParameters = true;
Default argument of scan-frequency if nothing is provided is “” and if scan-frequency is “” you don’t get to build the parameterString to initialize the sensor. Thanks.
