How to find number of points generated per scan by RTX LiDAR
I am using Isaac Sim 4.5 and working with an RTX LiDAR sensor. I would like to know how to calculate the number of points generated per scan by the RTX LiDAR. The configuration of LiDAR , I have posted here. I am rotated LiDAR from 0 to 180 deg by angular increment of 1.5 deg.
    "class": "sensor",
    "type": "lidar",
    "name": "Example Rotary",
    "driveWorksId": "GENERIC",
    "profile":
      "scanType": "rotary",
      "intensityProcessing": "normalization",
      "rotationDirection": "CW",
      "rayType": "IDEALIZED",
      "nearRangeM": 0.1,
      "farRangeM": 200.0,
      "startAzimuthOffsetDeg": 0.0,
      "rangeResolutionM": 0.004,
      "rangeAccuracyM": 0.02,
      "avgPowerW": 0.002,
      "minReflectance": 0.1,
      "minReflectanceRange": 120.0,
      "wavelengthNm": 903.0,
      "pulseTimeNs": 6,
      "azimuthErrorMean": 0.0,
      "azimuthErrorStd": 0.015,
      "elevationErrorMean": 0.0,
      "elevationErrorStd": 0.0000,
      "maxReturns": 2,
      "scanRateBaseHz": 50.0,
      "reportRateBaseHz": 36000,
      "numberOfEmitters": 1,
      "emitterStateCount": 1,
      "emitterStates": [
        "azimuthDeg": [0.0],
        "elevationDeg": [0.0],
        "fireTimeNs": [0]
      "intensityMappingType": "LINEAR"
You can calculate the number of points per scan using a simple formula based on your configuration:
(Scanning Angle/Angular Increment)xnumberOfEmitters = (180/1.5)x1
In the above case, I am getting 28 million points, where the scanning angle is 180° and the angular increment is 0.009°. The number of emitters is 1. However, according to the suggested formula, it should be (180 / 0.009) × 1 = 20,000, which does not match.
How do you get 28 million points? Can you share the details for how you’re getting that number so we can reproduce it?
Hello!
Best regards,
