Currently, the texture maps for materials in the Omniverse project are linked from my computer. Can you please guide me on how I can export the project or compile it into a single file to share with other people? Currently, I am using Omniverse Create and View.
I believe there is an option called “File<Save Flattened As”
This packages referenced assets as you described.
See here: Save all the imported stuff into one single "package"?
Thanks a lot for sharing the info. But I am still not able to resolve my issue. The texture maps in OmniPBR materials are still being linked from my computer. I read the link you shared and tried doing the same, but it doesn’t work for the texture maps for me.
HI @user126100! @LMTraina99 is correct. Save as Flattened should save the current USD file while merging all components to one mesh. I’m not sure why your texture maps / OmniPBR materials aren’t exporting.
I have informed the dev team about this issue and I will report back when I have more information.
hello @user126100 -
From the content pane, right lick on the asset (usd) and select “collect asset”, make sure you check the box for flattened. When it finishes, you will have a folder created that you can download and move to another PC. All refs/materials should be collected such that no back refs to your orig PC.
Thanks a lot for sharing the information. I did as you suggested. It created a new folder in which all assets were collected. But I faced two issues, 1) Some of my textures map filenames were the same, so they were not collected in the folder. 2) In the USD file in Omniverse Create, the paths of the texture maps are still from my PC.
hello @user126100
Since you have the same “name” for several texture maps, this will be a problem for the collection mode i gave you. Do the same collection method, but do no check the “flat connection” checkbox. This will allow you to have the same named files.
once this is done, please open the usd main asset in the collected folder.
