I’m trying to use an image sequence as a texture using the UDIM method. I have 24 images total, but they don’t loop as expected and green frames show up randomly, any ideas how to fix this? I looked into the code in the mdl file to see if there is an override but I figured I’d check here first.
I inputted a number image sequence to see what was happening, it only repeats image 21,22, 23, and 24, just wanted to share in case it helps.
Computer Specs (OS, GPU, GPU Driver)
Windows 10 Home
RTX 3080 Ti GPU
Studio Driver - Version 472.47 -
Applications and Versions
Omniverse Create 2021.3.8
Hi @edstudios! Welcome to the Community! I sent this over to our OmniPBR team to take a look. I’ll let you know when I have more information to share with you.
Hello @edstudios! The developers would like a bit more clarification on what you are trying to do. Are you offsetting and animating the UVs? If so, it could by a sync issue where the image isn’t loaded in sync with the timeline.
Set the project frame rate to 24, is it possible?
No, I just took an example project file from the Nvidia support forum that included this animated OmniPBR .mdl file (see attached) and all I did was switch out the albedo image path to another image sequence - using the proper naming convention image..jpg
OmniPBR_Animated.mdl (31.3 KB)
The project is set to 24 FPS - I even played around with 30, 60, and 120FPS but it didn’t fix the error. I also tried compressing my images down to a few kb’s each in case it was a VRAM issue - but also no luck
I’m trying to use it on another project - with the latest version 2022 of Omniverse Create. It’s still glitching out and not playing back the image sequence properly.
