Import "omni" coudnt be resolved
I’m trying to implement my first simulation Environment using Python and I dont get why the Packages can’t be found.
Can someone please explain me, how to work (workflow) in VS-Code using the Methods provided by the packages?
the Path of the file is:
/home/oem/.local/share/ov/pkg/isaac_sim-2021.1.1/python_samples/labor_roboter/labor_roboter.py
thank you and kindly regards,
Emilio
Hey to solve that issue I changed my config file for vs-code.
In linux its located under .config/Code/User/settings.json
Then I changed that file to the following. Note that it does not always provide auto-completion.
    "python.defaultInterpreterPath": "/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/python.sh",
    "python.analysis.extraPaths": [
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.robot_engine_bridge",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.motion_planning",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.dynamic_control",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.dr",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.robot_engine_bridge_ui",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.ros2_bridge",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.step_importer",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.usd.schema.isaac",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.ros_bridge",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.synthetic_utils",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.window.about",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.range_sensor",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.shapenet",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.kit.property.isaac",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.utils_manager",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.setup",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.splash",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.urdf",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.occupancy_map",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.onshape",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.tests",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.python_app",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.manip",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.samples",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.kit.loop-isaac",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.app.launcher",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.contact_sensor",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.utils",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/exts/omni.isaac.ros_bridge_ui",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.filebrowser_column.tags",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.file",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.procedural.mesh",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.primitive.mesh",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.audio",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.thumbnails.usd",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.greet",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.filebrowser_column.acl",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.transport.server.http",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.console",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.usd",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.versioning",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.tool.collect",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.flowusd",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.etm",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.ansel",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.geometry",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.multi_app_window",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.material_swap",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.usd_paths",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.quicklayout",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.thumbnails.images",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.usd",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.rtx.window.settings",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.editor-full",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.menu.edit",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.tools",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.streamclient-mini",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.hydra_viewport",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.images",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.transform",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.provide_feedback",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.title",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.content",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.popup_dialog",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.iray.settings.core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.layer",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.viewport_widgets_manager",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.imageview",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.livestream.native",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.audioplayer",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.filebrowser",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.tests",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.transport.server.tcp_socket",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.preferences",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.numpy.common",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.standalone",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.test",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.details",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.render_farm",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.ui",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.compatibility_checker",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.selection",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.facilities.log",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.property",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.filepicker",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.browser_bar",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.stage",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.splash",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.debug.python",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.menu.select",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.examples.cpp",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.ui",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.drop_support",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.light",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.live",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.collaboration.channel_manager",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.tutorials",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.stage",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.copy_service",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.collaboration.viewport.camera",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.rtx.settings.core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.settings",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.transport.server.https",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.livestream.webrtc",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.fast_search",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.stage_icons",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.workspace",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.controlport",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.search_core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.imageviewer",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.stage_templates",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.toolbar",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.volume",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.search_example",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.rpc",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.command.usd",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.stageviewer",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.registry",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.thumbnails.images",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.native_ext",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.graph",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.drivesim.rtdevice-sample",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.commands",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.editor-mini",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.etm.core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.menu_hook",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.debug.settings",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.quicksearch.commands",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.usda_edit",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.expression",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.content_browser",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.transport.client.idl_http_async",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.script_editor",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.splash_close_example",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.videoencoding",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.facilities.workqueue",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.extensions",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.debug.utils",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.tagging",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.debug.vscode",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.layers",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.path_field",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.profiler",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.movie_maker",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.audiorecorder",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.status_bar",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.search.service",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.audioplayer",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.stream_viewport",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.example.hello",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.facilities.config",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.about",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.bundle",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.tagging",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.menu.file",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.examples.python",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.camera",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.xr.profile.tabletar",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.example.toolbar_button",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.widget.prompt",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.progress_monitor",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.cursor",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.stats",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.graph.nodes",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.quicksearch",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.debugdraw",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.material",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.notification_manager",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.audiorecorder",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.agent.watcher",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.property.file",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.services.transport.server.base",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.capture",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/exts/omni.kit.window.cache_monitor",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.stats",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.pipapi",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.timeline",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.agent",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.renderer-ui",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.ui",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.appwindow",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.physics",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.libs",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.services.transport.client.base",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.registry.nucleus",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.services.transport.client.https_async",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.rtx",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.loop-default",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.uiapp",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.autocapture",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.services.transport.client.http_async",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.assets.plugins",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.test",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.iray",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.core.tests",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.semantics",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.services.client",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.profile_python",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.menu.utils",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.client",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.xr",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.services.facilities.base",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.test_helpers_gfx",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.ui",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.livestream.core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.renderer.core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.syntheticdata",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.audio",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.pxr",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.scene_delegate",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.services.core",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.splash",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.hydra.examples",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.window.splash",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.commands",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.material.library",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.usd_undo",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.pip_archive",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.menu.create",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.assets",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.mainwindow",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.console",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.config",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.usd.schema.anim",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.context_menu",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/carb.audio",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.renderer-rtx",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.window.viewport",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.async_engine",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.renderer.capture",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extensions/extensions-bundled",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/plugins/bindings-python",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/extscore/omni.kit.pip_archive/pip_prebundle",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python37.zip",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7/lib-dynload",
	"/home/gpu_user/.local/share/ov/pkg/isaac_sim-2021.1.1/kit/python/lib/python3.7/site-packages"
Best,
Antoine
Thanks for reporting this issue, we will provide a vscode config which should properly find these packages in the upcoming release
The .vscode workspace at the root of the package should automatically have these paths configured now.
we go into some details here:
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/manual_standalone_python.html#visual-studio-code-vscode-support
but please let me know if something does not work as expected.
你好,我也出现了同样的问题,并且按照你给出的解决方案修改了,但是没有得到预期结果
Hi everyone,
I had to do the same like antoine.richard explained in Create 2022.3.1 but I still miss the omni.kit.scripting package and do not know where to add it. Are there any suggestions?
    "security.workspace.trust.untrustedFiles": "open",
    "redhat.telemetry.enabled": false,
    "[python]": {
        "editor.formatOnType": true
    "python.defaultInterpreterPath": "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\python\\python.exe",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.filebrowser_column.tags",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.file",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.procedural.mesh",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.primitive.mesh",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.audio",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.thumbnails.usd",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.greet",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.filebrowser_column.acl",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.transport.server.http",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.console",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.usd",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.versioning",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.tool.collect",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.flowusd",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.etm",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.ansel",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.geometry",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.multi_app_window",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.material_swap",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.usd_paths",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.quicklayout",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.thumbnails.images",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.usd",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.rtx.window.settings",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.editor-full",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.menu.edit",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.tools",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.streamclient-mini",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.hydra_viewport",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.images",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.transform",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.provide_feedback",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.title",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.content",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.popup_dialog",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.iray.settings.core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.layer",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.viewport_widgets_manager",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.imageview",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.livestream.native",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.audioplayer",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.filebrowser",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.tests",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.transport.server.tcp_socket",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.preferences",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.numpy.common",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.standalone",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.test",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.details",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.render_farm",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.ui",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.compatibility_checker",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.selection",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.facilities.log",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.property",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.filepicker",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.browser_bar",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.stage",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.splash",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.debug.python",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.menu.select",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.examples.cpp",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.ui",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.drop_support",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.light",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.live",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.collaboration.channel_manager",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.tutorials",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.stage",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.copy_service",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.collaboration.viewport.camera",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.rtx.settings.core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.settings",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.transport.server.https",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.livestream.webrtc",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.fast_search",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.stage_icons",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.workspace",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.controlport",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.search_core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.imageviewer",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.stage_templates",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.xr",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.toolbar",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.volume",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.search_example",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.rpc",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.command.usd",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.stageviewer",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.registry",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.thumbnails.images",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.native_ext",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.graph",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.drivesim.rtdevice-sample",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.commands",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.editor-mini",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.etm.core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.menu_hook",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.debug.settings",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.quicksearch.commands",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.usda_edit",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.expression",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.content_browser",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.transport.client.idl_http_async",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.script_editor",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.splash_close_example",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.videoencoding",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.facilities.workqueue",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.extensions",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.debug.utils",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.tagging",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.debug.vscode",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.layers",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.path_field",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.profiler",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.movie_maker",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.audiorecorder",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.status_bar",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.search.service",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.audioplayer",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.stream_viewport",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.example.hello",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.facilities.config",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.about",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.bundle",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.tagging",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.menu.file",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.examples.python",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.camera",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.xr.profile.tabletar",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.example.toolbar_button",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.widget.prompt",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.progress_monitor",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.cursor",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.stats",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.graph.nodes",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.quicksearch",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.debugdraw",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.material",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.notification_manager",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.audiorecorder",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.agent.watcher",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.property.file",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.services.transport.server.base",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.capture",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\exts\\omni.kit.window.cache_monitor",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.stats",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.pipapi",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.timeline",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.agent",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.renderer-ui",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.hydra.ui",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.appwindow",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.usd.schema.physics",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.usd.libs",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.services.transport.client.base",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.registry.nucleus",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.services.transport.client.https_async",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.hydra.rtx",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.loop-default",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.uiapp",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.autocapture",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.services.transport.client.http_async",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.assets.plugins",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.test",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.hydra.iray",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.usd",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.core.tests",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.usd.schema.semantics",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.services.client",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.profile_python",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.menu.utils",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.client",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.xr",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.services.facilities.base",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.test_helpers_gfx",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.ui",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.livestream.core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.renderer.core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.syntheticdata",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.usd.schema.audio",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.hydra.pxr",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.hydra.scene_delegate",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.services.core",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.splash",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.hydra.examples",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.window.splash",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.commands",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.material.library",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.usd_undo",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.pip_archive",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.menu.create",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.assets",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.mainwindow",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.console",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.usd.config",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.usd.schema.anim",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.context_menu",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\carb.audio",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.renderer-rtx",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.window.viewport",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.async_engine",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.renderer.capture",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extensions\\extensions-bundled",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\plugins\\bindings-python",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\extscore\\omni.kit.pip_archive/pip_prebundle",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\python\\lib\\python37.zip",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\python\\lib\\python3.7",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\python\\lib\\python3.7\\lib-dynload",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\kit-104.0.0\\python\\lib\\python3.7\\site-packages",
        "C:\\Users\\AppData\\Local\\ov\\pkg\\create-2022.3.1\\extcache\\omni.kit.scripting-104.1.3+104.1.wx64.r.cp37"
Best regards,
Claudius
Hi @claudius.rimmele. You could look for the extension in the Create installation and add its path to python.analysis.extraPaths. The path is something like this:
C:\Users\bob\AppData\Local\ov\pkg\create-2022.3.3-rc.15extscache\omni.kit.scripting-104.2.2+104.2.wx64.r.cp37
Since it looks like you’re writing Python Scripting components, a better workflow would be to open the script this way:
This will open VSCode with the proper environment for completion
Hi @mati-nvidia , that’s what I tried first, but I have the problem that nothing happens when I click on “Edit Python Script”. When I create a “New Python Script (BehaviorScript)” a .vscode will be created but when I start VSCode manually in that environment all packages cannot be found.
Another way I tried was to create a complete omniverse extension. When I do this all packages can be found in the environment. But this is not a nice work around. Something is messed up here but I cannot figure out what it is.
Hi @claudius.rimmele. The PYTHONPATH is set up when you launch from “Edit Python Script”, so we do need to get that working for you. Can you reproduce the error and attach your log file here? Instructions for how to find your log files: How to Report an issue with Omniverse. Thank you!
