IMU Sensor hz setting problem using ros2 in Isaac Simulator
@Ayush_G I saw the below page that you answered about imu issue.
Is method “Standalone workflow” the only way to control IMU hz ?
Or Is there any way to control the imu hz (up to 100) using ros2 ?
I’m so desperate to solve this problem…
So I take the liberty of tagging you in this page…
I’m really sorry and thank you so much for reading this issue.
