Integrating Lidar SLAM(GEMS) with Isaac Sim
I have a mobile robot with a Lidar attached to it, and a ROS Lidar through which I get laser_scan and point_cloud topics as the output. I want to use the Lidar readings for SLAM, and I am not able to find suitable documentation to link Isaac Sim with NVIDIA GEMS. Most of the documentation for NVIDIA GEMS pertains to integration with Isaac SDK. Please point me to a way I can use GEMS with my Isaac Sim simulation?
By NVIDIA GEMS, I believe you mean Isaac SDK GEMs, correct?
Yes, correct. I want to integrate it with my Isaac Sim simulation. How do I go about it?
then Isaac SDK bridge (Robot engine bridge) is how Isaac SDK and Isaac Sim are connected.
Have you check out this :
https://docs.omniverse.nvidia.com/app_isaacsim/app_isaacsim/ext_omni_isaac_robot_engine_bridge.html
That confused me a little. I have Isaac Sim up and running. I should first install Isaac SDK too if I want to run GEMS? Since the Bridge is a connect between Isaac Sim and SDK
If your Gems are Isaac SDK Gems, you need to run Isaac SDK to connect with Isaac Sim
