Isaac Sim 4.2.0 container won't start on Nucleus server; GPU/driver works in all other tests
TLDR: issue with Isaac Sim start-up was due more to the Secure Boot BIOS flag than the Nvidia driver version.
Thanks for the advice on the driver version: stable is better for me!
I started with a fresh Ubuntu installation and followed just the process in the Isaac Sim installation process (i.e. without the Nucleus server) and using Nvidia driver version 550.144.03.
https://docs.isaacsim.omniverse.nvidia.com/latest/installation/install_container.html
  • Changing the driver version to 550.144.03 didn’t immediately help: Isaac Sim container startup still failed.
  • The issue turned out to be Secure Boot not allowing the Nvidia drivers to work correctly.
    This was surprising because I had followed the process from the forum post below to get the Nvidia driver signed and so allowed under Secure Boot. I was fooled by the successful running of nvidia-smi and the Nucleus server container, thinking that indicated the Nvidia driver was successfully loaded on boot, but that was apparently naive… :)
    Secure Boot on Linux post: NVIDIA drivers not working while Secure Boot is enabled after updating to Ubuntu 24.04 - #2 by mohammad.vazirpanah1
  • With Secure Boot enabled in the BIOS, with driver 550.144.03, the docker run command to start the Isaac Sim container produced the same error as before: nvidia-container-cli: mount error: stat failed: /dev/nvidia-modeset: no such file or directory: unknown.
  • With Secure Boot disabled in the BIOS, the docker run command for Isaac Sim started up the image correctly, and I was able to ./runheadless and connect to the Isaac Sim image with the Isaac Sim WebRTC Streaming client. Through that I was able to try the first Isaac Sim Quickstart trials. The HUD in Isaac Sim confirmed the GPU was available and being used.
Thanks for your help with this troubleshooting!
