Isaac Sim crashes when loading a demo scene (Windows 11)
Hello.
I am able to successfully launch the Isaac Sim app on my Windows desktop (OS: Windows 11).
However, whenever I try to load a demo scene on Isaac Sim, I get the following error messages and the app just abruptly crashes.
As you can see from the error messages below, I am able to load the App.
But whenever I try to do something (load a demo scene etc.) it just crashes with an error message that begins with " [Error] [carb.crashreporter-breakpad.plugin] crash detected"
[9.360s] app ready
[16.603s] RTX ready
[16.773s] Isaac Sim App is loaded.
2023-07-28 08:08:31 [25,153ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2023-07-28 08:08:31 [25,153ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-07-28 08:08:31 [25,157ms] [Warning] [carb.crashreporter-breakpad.plugin] compressing 2 files into 'C:/Omniverse/data/Kit/Isaac-Sim/2022.2\e1fc9b4b-875f-4747-9759-fe285e702b6f.dmp.zip' for upload.
2023-07-28 08:08:31 [25,835ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'C:/Omniverse/data/Kit/Isaac-Sim/2022.2\e1fc9b4b-875f-4747-9759-fe285e702b6f.dmp.zip' svr:'https://services.nvidia.com/submit'
2023-07-28 08:08:31 [25,835ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   DumpId = 'e1fc9b4b-875f-4747-9759-fe285e702b6f'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   ProductName = 'OmniverseKit'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   RetryCount = '0'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   StartupTime = '1690531685'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   UploadSuccessful = '0'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   UptimeSeconds = '26'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   Version = '104.2+release.295.529af2e4.tc'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   appName = 'Isaac-Sim'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   appState = 'started'
2023-07-28 08:08:31 [25,836ms] [Warning] [carb.crashreporter-breakpad.plugin]   appVersion = '2022.2.1'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   autoloadExts = ''
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildBranch = 'release'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildCi = 'tc'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildHash = '529af2e4'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildId = '14001708'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMajor = '104'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMinor = '2'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMr = '0'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildNumber = '295'
2023-07-28 08:08:31 [25,837ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildPatch = '0'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildVersion = '104.2.0'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   environmentName = 'default'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   experience = 'Isaac Sim'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   kitRendererDriverVersion = '528.49'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommand = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommands = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   memoryStats = '(avail/total) RAM: 16.0588/31.7721GB, Swap: 10.5974/33.7721GB, VM: 130950/131072GB'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   portableMode = '0'
2023-07-28 08:08:31 [25,838ms] [Warning] [carb.crashreporter-breakpad.plugin]   stageUrl = ''
2023-07-28 08:08:31 [25,839ms] [Warning] [carb.crashreporter-breakpad.plugin]   systemInfo = '
| Driver Version: 528.49        | Graphics API: D3D12
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 4070 Ti       | Yes: 0 |     | 12010   MB | 10de      | 145ee000.. |
|     |                                  |        |     |            | 2782      | 0          |
| 1   | Intel(R) UHD Graphics 770        |        |     | 128     MB | 8086      | 171b6000.. |
|     |                                  |        |     |            | a780      | 0          |
| 2   | Intel(R) UHD Graphics 770        |        |     | 128     MB | 8086      | 1e972000.. |
|     |                                  |        |     |            | a780      | 0          |
| OS: Windows, Version: 10.0, Build: 22621
| Processor: 13th Gen Intel(R) Core(TM) i5-13600K | Cores: 14 | Logical: 20
| Total Memory (MB): 32534 | Free Memory: 21389
| Total Page/Swap (MB): 34582 | Free Page/Swap: 19779
2023-07-28 08:08:31 [25,839ms] [Warning] [carb.crashreporter-breakpad.plugin]   telemetrySessionId = '12163497001943992499'
2023-07-28 08:08:31 [25,839ms] [Warning] [carb.crashreporter-breakpad.plugin]   userId = 'ro8v67Z_Rrxx9VYixesJn2zy0Hlv45RynPZaA2WPd_E'
2023-07-28 08:08:31 [25,839ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
2023-07-28 08:08:31 [25,839ms] [Warning] [carb.crashreporter-breakpad.plugin]   upload_file_minidump = 'C:/Omniverse/data/Kit/Isaac-Sim/2022.2\e1fc9b4b-875f-4747-9759-fe285e702b6f.dmp.zip'
What would be the cause of this crash?
Isaac Sim seems to work fine on my Ubuntu 22.04 setup but for some reason it crashes on my Windows11 machine whenever I try to load a scene or a USD file.
Thanks in advance!
Hi @jaeyeun - Can you try to reinstall the drivers as mentioned here in the official documentation? : 1. Isaac Sim Requirements — isaacsim latest documentation
Are you able to install other applications such as USD Composer, Code?
