Isaac Sim is launching with errors, when i open extension manager, i get a segmentation fault
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify): 5.0.0-rc.35
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA GeForce RTX 4090
  • Driver Version: 575.57.08
Topic Description
Detailed Description
So when i launch Isaac Sim i get a few errors, if i try to open the extension manager in the logs i can see a lot of extensions being shutdown, and if i try to dock the extension manager window to the main window, i get a segmentation fault, down bellow is the log after starting Isaac Sim:
Error Messages
The log after starting Isaac Sim:
2025-07-29T11:47:28Z [3,547ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.dynamic_control. Error: NumPy type info missing for N4carb6Float3E. Traceback:
File “/home/voicandrei/.cache/packman/chk/kit-kernel/107.3.1+isaac.206797.8131b85d.gl.manylinux_2_35_x86_64.release/kernel/py/omni/ext/_impl/custom_importer.py”, line 85, in import_module
return importlib.import_module(name)
File “/home/voicandrei/.cache/packman/chk/kit-kernel/107.3.1+isaac.206797.8131b85d.gl.manylinux_2_35_x86_64.release/python/lib/python3.11/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1204, in _gcd_import
File “”, line 1176, in _find_and_load
File “”, line 1147, in _find_and_load_unlocked
File “”, line 690, in _load_unlocked
File “”, line 940, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/home/voicandrei/isaacsim/_build/linux-x86_64/release/extsDeprecated/omni.isaac.dynamic_control/omni/isaac/dynamic_control/init.py”, line 18, in
from .scripts import *
File “/home/voicandrei/isaacsim/_build/linux-x86_64/release/extsDeprecated/omni.isaac.dynamic_control/omni/isaac/dynamic_control/scripts/init.py”, line 16, in
from . import conversions as conversions
File “/home/voicandrei/isaacsim/_build/linux-x86_64/release/extsDeprecated/omni.isaac.dynamic_control/omni/isaac/dynamic_control/scripts/conversions.py”, line 16, in
from omni.isaac.dynamic_control import _dynamic_control
ImportError: NumPy type info missing for N4carb6Float3E
2025-07-29T11:47:28Z [3,547ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.dynamic_control’ in ‘/home/voicandrei/isaacsim/_build/linux-x86_64/release/extsDeprecated/omni.isaac.dynamic_control’ failed to load.
At:
/home/voicandrei/.cache/packman/chk/kit-kernel/107.3.1+isaac.206797.8131b85d.gl.manylinux_2_35_x86_64.release/kernel/py/omni/ext/_impl/_internal.py(222): startup
/home/voicandrei/.cache/packman/chk/kit-kernel/107.3.1+isaac.206797.8131b85d.gl.manylinux_2_35_x86_64.release/kernel/py/omni/ext/_impl/_internal.py(337): startup_extension
PythonExtension.cpp::startup()(2):
2025-07-29T11:47:28Z [3,547ms] [Error] [omni.ext.plugin] [ext: omni.isaac.dynamic_control-2.0.7] Failed to startup python extension.
2025-07-29T11:47:32Z [7,555ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.sensors.physics. Error: NumPy type info missing for N4carb6Float3E. Traceback:
File “/home/voicandrei/isaacsim/_build/linux-x86_64/release/exts/isaacsim.sensors.physics/isaacsim/sensors/physics/init.py”, line 16, in
from .impl import *
File “/home/voicandrei/isaacsim/_build/linux-x86_64/release/exts/isaacsim.sensors.physics/isaacsim/sensors/physics/impl/init.py”, line 17, in
from .contact_sensor import ContactSensor
File “/home/voicandrei/isaacsim/_build/linux-x86_64/release/exts/isaacsim.sensors.physics/isaacsim/sensors/physics/impl/contact_sensor.py”, line 25, in
from isaacsim.sensors.physics import _sensor
2025-07-29T11:47:32Z [7,555ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.sensors.physics’ in ‘/home/voicandrei/isaacsim/_build/linux-x86_64/release/exts/isaacsim.sensors.physics’ failed to load.
At:
2025-07-29T11:47:32Z [7,555ms] [Error] [omni.ext.plugin] [ext: isaacsim.sensors.physics-0.3.27] Failed to startup python extension.
[7.721s] [ext: omni.anim.navigation.core-107.3.0] startup
2025-07-29T11:47:32Z [7,696ms] [Error] [omni.graph.core._impl.extension] OGN node registration completed with errors: generic_type: type “CsRawData” is already registered!
2025-07-29T11:47:33Z [8,258ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module omni.isaac.sensor. Error: generic_type: type “CsRawData” is already registered!. Traceback:
File “/home/voicandrei/isaacsim/_build/linux-x86_64/release/extsDeprecated/omni.isaac.sensor/omni/isaac/sensor/init.py”, line 25, in
from .impl import *
ImportError: generic_type: type “CsRawData” is already registered!
2025-07-29T11:47:33Z [8,259ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.sensor’ in ‘/home/voicandrei/isaacsim/_build/linux-x86_64/release/extsDeprecated/omni.isaac.sensor’ failed to load.
At:
2025-07-29T11:47:33Z [8,259ms] [Error] [omni.ext.plugin] [ext: omni.isaac.sensor-13.0.7] Failed to startup python extension.
[8.438s] [ext: omni.isaac.surface_gripper-2.0.6] startup
2025-07-29T11:47:33Z [8,412ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-07-29T11:47:33Z [8,413ms] [Error] [omni.graph.core._impl.extension] OGN node registration completed with errors: generic_type: type “CsRawData” is already registered!
2025-07-29T11:47:33Z [9,059ms] [Error] [omni.ext._impl.custom_importer] Failed to import python module isaacsim.sensors.physics.ui. Error: generic_type: type “CsRawData” is already registered!. Traceback:
File “”, line 1126, in _find_and_load_unlocked
from .impl import *
2025-07-29T11:47:33Z [9,059ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.sensors.physics.ui’ in ‘/home/voicandrei/isaacsim/_build/linux-x86_64/release/exts/isaacsim.sensors.physics.ui’ failed to load.
At:
2025-07-29T11:47:33Z [9,059ms] [Error] [omni.ext.plugin] [ext: isaacsim.sensors.physics.ui-0.1.12] Failed to startup python extension.
[9.264s] [ext: isaacsim.sensors.physics.examples-0.1.15] startup
2025-07-29T11:47:34Z [9,239ms] [Error] [omni.graph.core._impl.extension] OGN node registration completed with errors: generic_type: type “CsRawData” is already registered!
2025-07-29T11:47:34Z [9,239ms] [Error] [omni.ext._impl._internal] Failed to import python module isaacsim.sensors.physics.examples from /home/voicandrei/isaacsim/_build/linux-x86_64/release/exts/isaacsim.sensors.physics.examples. Error: ‘isaacsim.sensors.physics’. Traceback:
File “/home/voicandrei/.cache/packman/chk/kit-kernel/107.3.1+isaac.206797.8131b85d.gl.manylinux_2_35_x86_64.release/kernel/py/omni/ext/_impl/_internal.py”, line 196, in _custom_importer
return _import_public(ext_module.path, ext_module.name, reload_enabled)
File “/home/voicandrei/.cache/packman/chk/kit-kernel/107.3.1+isaac.206797.8131b85d.gl.manylinux_2_35_x86_64.release/kernel/py/carb/profiler/init.py”, line 99, in wrapper
r = f(*args, **kwds)
File “/home/voicandrei/.cache/packman/chk/kit-kernel/107.3.1+isaac.206797.8131b85d.gl.manylinux_2_35_x86_64.release/kernel/py/omni/ext/_impl/_internal.py”, line 103, in _import_public
module = import_module(module_name)
File “”, line 1153, in _find_and_load_unlocked
KeyError: ‘isaacsim.sensors.physics’
2025-07-29T11:47:34Z [9,239ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘isaacsim.sensors.physics.examples’ in ‘/home/voicandrei/isaacsim/_build/linux-x86_64/release/exts/isaacsim.sensors.physics.examples’ failed to load.
At:
2025-07-29T11:47:34Z [9,239ms] [Error] [omni.ext.plugin] [ext: isaacsim.sensors.physics.examples-0.1.15] Failed to startup python extension.
[9.442s] [ext: isaacsim.replicator.behavior.ui-1.0.5] startup
2025-07-29T11:47:34Z [9,417ms] [Error] [omni.graph.core._impl.extension] OGN node registration completed with errors: generic_type: type “CsRawData” is already registered!
And this is the segmentation fault core dump:
2025-07-29T12:04:24Z [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-07-29T12:04:24Z [66ms] [Error] [carb.crashreporter-breakpad.plugin] ‘crashreport.gui’ exited with code 127
2025-07-29T12:04:24Z [83ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/home/voicandrei/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/6ccb932d-0400-4272-3002d7a8-7163b6a2.dmp’
2025-07-29T12:04:24Z [96ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: ‘/home/voicandrei/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/6ccb932d-0400-4272-3002d7a8-7163b6a2.dmp’
2025-07-29T12:04:24Z [111ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] dump file size is 4898536 bytes, file is readable.
2025-07-29T12:04:24Z [127ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 38584 thread 38584
2025-07-29T12:04:24Z [142ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2025-07-29T12:04:24Z [156ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] BuildGitlabJobID = ‘182268558’
2025-07-29T12:04:24Z [171ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘206.4+release.9396.3c6f8191.gl’
2025-07-29T12:04:24Z [185ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Tue Jul 29 12:04:24 2025 GMT’
2025-07-29T12:04:24Z [199ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2025-07-29T12:04:24Z [214ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘6ccb932d-0400-4272-3002d7a8-7163b6a2’
2025-07-29T12:04:24Z [228ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] LastUploadStatus = ‘0’
2025-07-29T12:04:24Z [242ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2025-07-29T12:04:24Z [257ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/home/voicandrei/.local/share/ov/data/Kit/Isaac-Sim Full/5.0/6ccb932d-0400-4272-3002d7a8-7163b6a2.py.txt’’
2025-07-29T12:04:24Z [271ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2025-07-29T12:04:24Z [277ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1753790540’
2025-07-29T12:04:24Z [282ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2025-07-29T12:04:24Z [288ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘124’
2025-07-29T12:04:24Z [294ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2025-07-29T12:04:24Z [303ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 127’
2025-07-29T12:04:24Z [307ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘107.3.1+production.206797.8131b85d.gl’
2025-07-29T12:04:24Z [314ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2025-07-29T12:04:24Z [320ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2025-07-29T12:04:24Z [325ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2025-07-29T12:04:24Z [329ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2024.1’
2025-07-29T12:04:24Z [336ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Isaac-Sim Full’
2025-07-29T12:04:24Z [342ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘started’
2025-07-29T12:04:24Z [347ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘5.0.0’
2025-07-29T12:04:24Z [352ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2025-07-29T12:04:24Z [359ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘production’
2025-07-29T12:04:24Z [364ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘gl’
2025-07-29T12:04:24Z [369ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildConfig = ‘release’
2025-07-29T12:04:24Z [374ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobName = ‘kit-build-release-linux-x86_64’
2025-07-29T12:04:24Z [381ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabJobStage = ‘kit-build’
2025-07-29T12:04:24Z [386ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildGitlabPipelineID = ‘30713850’
2025-07-29T12:04:24Z [392ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘8131b85d’
2025-07-29T12:04:24Z [397ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘107’
2025-07-29T12:04:24Z [403ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘3’
2025-07-29T12:04:24Z [409ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘206797’
2025-07-29T12:04:24Z [414ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘1’
2025-07-29T12:04:24Z [419ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘107.3.1’
2025-07-29T12:04:24Z [426ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteFrameworkVersion = ‘206.4+release.9396.3c6f8191.gl’
2025-07-29T12:04:24Z [431ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] carboniteSdkVersion = ‘206.4+release.9396.3c6f8191.gl’
2025-07-29T12:04:24Z [437ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘/home//isaacsim/_build/linux-x86_64/release/kit/kit /home//isaacsim/_build/linux-x86_64/release/apps/isaacsim.exp.full.kit’
2025-07-29T12:04:24Z [442ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuCoreLimited = ‘32’
2025-07-29T12:04:24Z [448ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 6 Model 183 Stepping 1’
2025-07-29T12:04:24Z [454ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuLogicalCoresBareMetal = ‘48’
2025-07-29T12:04:24Z [459ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘13th Gen Intel(R) Core™ i9-13900K’
2025-07-29T12:04:24Z [464ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuPhysicalCoresBareMetal = ‘24’
2025-07-29T12:04:24Z [471ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuUsageQuota = ‘-1.000000’
2025-07-29T12:04:24Z [476ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘GenuineIntel’
2025-07-29T12:04:24Z [481ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopOrigin = ‘(0, 0)’
2025-07-29T12:04:24Z [486ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] desktopSize = ‘3840x1080’
2025-07-29T12:04:24Z [493ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayCount = ‘2’
2025-07-29T12:04:24Z [499ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayRes_0 = ‘1920x1080x32bit@60Hz’
2025-07-29T12:04:24Z [504ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] displayRes_1 = ‘1920x1080x32bit@60Hz’
2025-07-29T12:04:24Z [509ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘Individual’
2025-07-29T12:04:24Z [516ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2025-07-29T12:04:24Z [521ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] extraExts = ‘omni.kit.registry.nucleus-0.0.0’
2025-07-29T12:04:24Z [527ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_0 = ‘575.57’
2025-07-29T12:04:24Z [531ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_1 = ‘0x5c02001’
2025-07-29T12:04:24Z [538ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_0 = ‘26015170560’
2025-07-29T12:04:24Z [544ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_1 = ‘101117309952’
2025-07-29T12:04:24Z [549ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_0 = ‘NVIDIA GeForce RTX 4090’
2025-07-29T12:04:24Z [554ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] gpu_1 = ‘Intel(R) Graphics (RPL-S)’
2025-07-29T12:04:24Z [560ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] kitRendererDriverVersion = ‘575.57’
2025-07-29T12:04:24Z [566ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommand = ‘SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)’
2025-07-29T12:04:24Z [571ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lastCommands = ‘SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)’
2025-07-29T12:04:24Z [576ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildBranch = ‘main’
2025-07-29T12:04:24Z [583ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildDate = ‘Wed Jul 23 11:41:56 2025 -0500’
2025-07-29T12:04:24Z [588ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildHash = ‘494347a’
2025-07-29T12:04:24Z [594ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildRepo = ‘GitHub - isaac-sim/IsaacSim: NVIDIA Isaac Sim™ is an open-source application on NVIDIA Omniverse for developing, simulating, and testing AI-driven robots in realistic virtual environments.
2025-07-29T12:04:24Z [598ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_isaacSim_buildVersion = ‘5.0.0-rc.35’
2025-07-29T12:04:24Z [605ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildBranch = ‘HEAD’
2025-07-29T12:04:24Z [611ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildDate = ‘Jul-08-2025’
2025-07-29T12:04:24Z [616ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildHash = ‘9012392’
2025-07-29T12:04:24Z [621ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildRepo = ‘gitlab-master.nvidia.com/omniverse/physics
2025-07-29T12:04:24Z [628ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] lib_physx_buildVersion = ‘107.3.15’
2025-07-29T12:04:24Z [633ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 116.625/125.564GB, Swap: 0/0GB, VM: 1.71799e+10/1.71799e+10GB’
2025-07-29T12:04:24Z [638ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = ’
==============NVSMI LOG==============
Timestamp : Tue Jul 29 15:02:20 2025
Driver Version : 575.57.08
CUDA Version : 12.9
Attached GPUs : 1
GPU 00000000:01:00.0
Product Name : NVIDIA GeForce RTX 4090
Product Brand : GeForce
Product Architecture : Ada Lovelace
Display Mode : Requested functionality has been deprecated
Display Attached : Yes
Display Active : Enabled
Persistence Mode : Enabled
Addressing Mode : None
MIG Mode
Current : N/A
Pending : N/A
Accounting Mode : Disabled
Accounting Mode Buffer Size : 4000
Driver Model
Current : N/A
Pending : N/A
Serial Number : N/A
GPU UUID : GPU-b881fdeb-99ed-a882-ae4b-1c1fe984ab31
Minor Number : 0
VBIOS Version : 95.02.18.80.5F
MultiGPU Board : No
Board ID : 0x100
Board Part Number : N/A
GPU Part Number : 2684-300-A1
FRU Part Number : N/A
Platform Info
Chassis Serial Number : N/A
Slot Number : N/A
Tray Index : N/A
Host ID : N/A
Peer Type : N/A
Module Id : 1
GPU Fabric GUID : N/A
Inforom Version
Image Version : G002.0000.00.03
OEM Object : 2.0
ECC Object : 6.16
Power Management Object : N/A
Inforom BBX Object Flush
Latest Timestamp : N/A
Latest Duration : N/A
GPU Operation Mode
Current : N/A
Pending : N/A
GPU C2C Mode : N/A
GPU Virtualization Mode
Virtualization Mode : None
Host VGPU Mode : N/A
vGPU Heterogeneous Mode : N/A
GPU Reset Status
Reset Required : Requested functionality has been deprecated
Drain and Reset Recommended : Requested functionality has been deprecated
GPU Recovery Action : None
GSP Firmware Version : 575.57.08
IBMNPU
Relaxed Ordering Mode : N/A
PCI
Bus : 0x01
Device : 0x00
Domain : 0x0000
Base Classcode : 0x3
Sub Classcode : 0x0
Device Id : 0x268410DE
Bus Id : 00000000:01:00.0
Sub System Id : 0x40BF1458
GPU Link Info
PCIe Generation
Max : 4
Current : 1
Device Current : 1
Device Max : 4
Host Max : 5
Link Width
Max : 16x
Current : 16x
Bridge Chip
Type : N/A
Firmware : N/A
Replays Since Reset : 0
Replay Number Rollovers : 0
Tx Throughput : 8400 KB/s
Rx Throughput : 9350 KB/s
Atomic Caps Outbound : N/A
Atomic Caps Inbound : N/A
Fan Speed : 0 %
Performance State : P8
Clocks Event Reasons
Idle : Active
Applications Clocks Setting : Not Active
SW Power Cap : Not Active
HW Slowdown : Not Active
HW Thermal Slowdown : Not Active
HW Power Brake Slowdown : Not Active
Sync Boost : Not Active
SW Thermal Slowdown : Not Active
Display Clock Setting : Not Active
Clocks Event Reasons Counters
SW Power Capping : 0 us
Sync Boost : 0 us
SW Thermal Slowdown : 0 us
HW Thermal Slowdown : 0 us
HW Power Braking : 0 us
Sparse Operation Mode : N/A
FB Memory Usage
Total : 24564 MiB
Reserved : 487 MiB
Used : 471 MiB
Free : 23608 MiB
BAR1 Memory Usage
Total : 256 MiB
Used : 13 MiB
Free : 243 MiB
Conf Compute Protected Memory Usage
Total : 0 MiB
Used : 0 MiB
Free : 0 MiB
Compute Mode : Default
Utilization
GPU : 8 %
Memory : 1 %
Encoder : 0 %
Decoder : 0 %
JPEG : 0 %
OFA : 0 %
Encoder Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
FBC Stats
Active Sessions : 0
Average FPS : 0
Average Latency : 0
DRAM Encryption Mode
Current : N/A
Pending : N/A
ECC Mode
Current : Disabled
Pending : Disabled
ECC Errors
Volatile
SRAM Correctable : N/A
SRAM Uncorrectable Parity : N/A
SRAM Uncorrectable SEC-DED : N/A
DRAM Correctable : N/A
DRAM Uncorrectable : N/A
Aggregate
SRAM Threshold Exceeded : N/A
Aggregate Uncorrectable SRAM Sources
SRAM L2 : N/A
SRAM SM : N/A
SRAM Microcontroller : N/A
SRAM PCIE : N/A
SRAM Other : N/A
Retired Pages
Single Bit ECC : N/A
Double Bit ECC : N/A
Pending Page Blacklist : N/A
Remapped Rows
Correctable Error : 0
Uncorrectable Error : 0
Pending : No
Remapping Failure Occurred : No
Bank Remap Availability Histogram
Max : 192 bank(s)
High : 0 bank(s)
Partial : 0 bank(s)
Low : 0 bank(s)
None : 0 bank(s)
Temperature
GPU Current Temp : 45 C
GPU T.Limit Temp : 39 C
GPU Shutdown T.Limit Temp : -7 C
GPU Slowdown T.Limit Temp : -2 C
GPU Max Operating T.Limit Temp : 0 C
GPU Target Temperature : 84 C
Memory Current Temp : N/A
Memory Max Operating T.Limit Temp : N/A
GPU Power Readings
Average Power Draw : 30.99 W
Instantaneous Power Draw : 32.38 W
Current Power Limit : 450.00 W
Requested Power Limit : 450.00 W
Default Power Limit : 450.00 W
Min Power Limit : 10.00 W
Max Power Limit : 600.00 W
GPU Memory Power Readings
Average Power Draw : N/A
Instantaneous Power Draw : N/A
Module Power Readings
Current Power Limit : N/A
Requested Power Limit : N/A
Default Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Smoothing : N/A
Workload Power Profiles
Requested Profiles : N/A
Enforced Profiles : N/A
Clocks
Graphics : 315 MHz
SM : 315 MHz
Memory : 405 MHz
Video : 1185 MHz
Applications Clocks
Graphics : N/A
Memory : N/A
Default Applications Clocks
Graphics : N/A
Memory : N/A
Deferred Clocks
Memory : N/A
Max Clocks
Graphics : 3120 MHz
SM : 3120 MHz
Memory : 10501 MHz
Video : 2415 MHz
Max Customer Boost Clocks
Graphics : N/A
Clock Policy
Auto Boost : N/A
Auto Boost Default : N/A
Voltage
Graphics : Requested functionality has been deprecated
Fabric
State : N/A
Status : N/A
CliqueId : N/A
ClusterUUID : N/A
Health
Bandwidth : N/A
Route Recovery in progress : N/A
Route Unhealthy : N/A
Access Timeout Recovery : N/A
Processes
GPU instance ID : N/A
Compute instance ID : N/A
Process ID : 2026
Type : G
Used GPU Memory : 139 MiB
Process ID : 2220
Type : G
Used GPU Memory : 41 MiB
Process ID : 6174
Type : G
Used GPU Memory : 224 MiB
Capabilities
EGM : disabled
2025-07-29T12:04:24Z [644ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
2025-07-29T12:04:24Z [651ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘22.04.5 LTS (Jammy Jellyfish)’
2025-07-29T12:04:24Z [656ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘22.04.5’
2025-07-29T12:04:24Z [662ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
2025-07-29T12:04:24Z [668ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = ‘1920x1080x32bit@60Hz’
2025-07-29T12:04:24Z [674ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2025-07-29T12:04:24Z [679ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] runningInContainer = ‘0’
2025-07-29T12:04:24Z [685ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_debugSymbols = ‘0’
2025-07-29T12:04:24Z [690ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIncludeOverrides = ‘0’
2025-07-29T12:04:24Z [696ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIntermediates = ‘0’
2025-07-29T12:04:24Z [701ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_obfuscateCode = ‘1’
2025-07-29T12:04:24Z [707ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_optimizationLevel = ‘1’
2025-07-29T12:04:24Z [712ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| Driver Version: 575.57.08 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4090 | Yes: 0 | | 24810 MB | 10de | 0 |
| | | | | | 2684 | b881fdeb.. |
| | | | | | 1 | |
| 1 | Intel(R) Graphics (RPL-S) | | | 96432 MB | 8086 | 0 |
| | | | | | a780 | 868080a7.. |
| | | | | | 0 | |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-64-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: 13th Gen Intel(R) Core™ i9-13900K
| Bare Metal Cores: 24 | Bare Metal Logical Cores: 48
Available Cores: 32
Total Memory (MB): 128577
Total Page/Swap (MB): 0
2025-07-29T12:04:24Z [719ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘5062867764148156741’
2025-07-29T12:04:24Z [723ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2025-07-29T12:04:24Z [729ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamBareMetalMB = ‘128577’
2025-07-29T12:04:24Z [734ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalRamLimitedMB = ‘128577’
2025-07-29T12:04:24Z [741ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapBareMetalMB = ‘0’
2025-07-29T12:04:24Z [745ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] totalSwapLimitedMB = ‘0’
2025-07-29T12:04:24Z [750ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
2025-07-29T12:04:24Z [756ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/home//isaacsim/_build/linux-x86_64/release’
2025-07-29T12:04:24Z [763ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 38584 backtrace follows:
2025-07-29T12:04:24Z [825ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2025-07-29T12:04:24Z [836ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libusd_tf.so!pxrInternal_v0_24__pxrReserved__::Tf_NoticeRegistry::Deliver(pxrInternal_v0_24__pxrReserved_::TfNotice const&, pxrInternal_v0_24__pxrReserved__::TfType const&, pxrInternal_v0_24__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&, std::vector<pxrInternal_v0_24__pxrReserved__::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::TfNotice::Probe>, std::allocator<pxrInternal_v0_24__pxrReserved__::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::TfNotice::Probe> > > const&, std::pair<std::cxx11::list<pxrInternal_v0_24__pxrReserved::TfNotice::DelivererBase*, std::allocator<pxrInternal_v0_24__pxrReserved_::TfNotice::DelivererBase*> >*, std::List_iterator<pxrInternal_v0_24__pxrReserved::TfNotice::_DelivererBase*> > const&)+0xce (??:?)
2025-07-29T12:04:24Z [845ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libusd_tf.so!pxrInternal_v0_24__pxrReserved__::Tf_NoticeRegistry::Send(pxrInternal_v0_24__pxrReserved_::TfNotice const&, pxrInternal_v0_24__pxrReserved__::TfType const&, pxrInternal_v0_24__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&)+0x2a5 (??:?)
2025-07-29T12:04:24Z [862ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libusd_tf.so!pxrInternal_v0_24__pxrReserved__::TfNotice::Send(pxrInternal_v0_24__pxrReserved_::TfWeakBase const*, void const*, std::type_info const&) const+0x5e (??:?)
2025-07-29T12:04:24Z [882ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libusd_usd.so!pxrInternal_v0_24__pxrReserved__::UsdStage::_ProcessPendingChanges()+0x447 (??:?)
2025-07-29T12:04:24Z [903ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libusd_usd.so!pxrInternal_v0_24__pxrReserved__::UsdStage::HandleLayersDidChange(pxrInternal_v0_24__pxrReserved_::SdfNotice::LayersDidChangeSentPerLayer const&)+0x10ca (??:?)
2025-07-29T12:04:24Z [923ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libusd_usd.so!pxrInternal_v0_24__pxrReserved__::TfNotice::StandardDeliverer<pxrInternal_v0_24__pxrReserved_::TfNotice::Deliverer<pxrInternal_v0_24__pxrReserved_::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::UsdStage>, pxrInternal_v0_24__pxrReserved__::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::SdfLayer>, void (pxrInternal_v0_24__pxrReserved__::UsdStage::)(pxrInternal_v0_24__pxrReserved__::SdfNotice::LayersDidChangeSentPerLayer const&), pxrInternal_v0_24__pxrReserved__::SdfNotice::LayersDidChangeSentPerLayer> >::SendToListener(pxrInternal_v0_24__pxrReserved_::TfNotice const&, pxrInternal_v0_24__pxrReserved__::TfType const&, pxrInternal_v0_24__pxrReserved__::TfWeakBase const, void const*, std::type_info const&, std::vector<pxrInternal_v0_24__pxrReserved__::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::TfNotice::Probe>, std::allocator<pxrInternal_v0_24__pxrReserved__::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::TfNotice::Probe> > > const&)+0x7c (??:?)
2025-07-29T12:04:24Z [942ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libusd_tf.so!pxrInternal_v0_24__pxrReserved__::Tf_NoticeRegistry::Deliver(pxrInternal_v0_24__pxrReserved_::TfNotice const&, pxrInternal_v0_24__pxrReserved__::TfType const&, pxrInternal_v0_24__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&, std::vector<pxrInternal_v0_24__pxrReserved__::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::TfNotice::Probe>, std::allocator<pxrInternal_v0_24__pxrReserved__::TfWeakPtr<pxrInternal_v0_24__pxrReserved__::TfNotice::Probe> > > const&, std::pair<std::cxx11::list<pxrInternal_v0_24__pxrReserved::TfNotice::DelivererBase*, std::allocator<pxrInternal_v0_24__pxrReserved_::TfNotice::DelivererBase*> >*, std::List_iterator<pxrInternal_v0_24__pxrReserved::TfNotice::_DelivererBase*> > const&)+0xd1 (??:?)
2025-07-29T12:04:25Z [961ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libusd_tf.so!pxrInternal_v0_24__pxrReserved__::Tf_NoticeRegistry::Send(pxrInternal_v0_24__pxrReserved_::TfNotice const&, pxrInternal_v0_24__pxrReserved__::TfType const&, pxrInternal_v0_24__pxrReserved__::TfWeakBase const*, void const*, std::type_info const&)+0x3f5 (??:?)
2025-07-29T12:04:25Z [980ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libusd_tf.so!pxrInternal_v0_24__pxrReserved__::TfNotice::Send(pxrInternal_v0_24__pxrReserved_::TfWeakBase const*, void const*, std::type_info const&) const+0x5e (??:?)
2025-07-29T12:04:25Z [998ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libusd_sdf.so!pxrInternal_v0_24__pxrReserved__::Sdf_ChangeManager::SendNotices(pxrInternal_v0_24__pxrReserved_::Sdf_ChangeManager::_Data*)+0x7cb (??:?)
2025-07-29T12:04:25Z [1,016ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libusd_sdf.so!void pxrInternal_v0_24__pxrReserved__::SdfLayer::PrimSetField<pxrInternal_v0_24__pxrReserved_::SdfAbstractDataConstValue>(pxrInternal_v0_24__pxrReserved__::SdfPath const&, pxrInternal_v0_24__pxrReserved__::TfToken const&, pxrInternal_v0_24__pxrReserved__::SdfAbstractDataConstValue const&, pxrInternal_v0_24__pxrReserved__::VtValue*, bool)+0x16f (??:?)
2025-07-29T12:04:25Z [1,035ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libusd_sdf.so!pxrInternal_v0_24__pxrReserved__::SdfLayer::SetField(pxrInternal_v0_24__pxrReserved__::SdfPath const&, pxrInternal_v0_24__pxrReserved__::TfToken const&, pxrInternal_v0_24__pxrReserved__::SdfAbstractDataConstValue const&)+0xe2 (??:?)
2025-07-29T12:04:25Z [1,057ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libusd_usd.so!bool pxrInternal_v0_24__pxrReserved__::UsdStage::SetValueImpl<pxrInternal_v0_24__pxrReserved_::SdfAbstractDataConstValue>(pxrInternal_v0_24__pxrReserved__::UsdTimeCode, pxrInternal_v0_24__pxrReserved__::UsdAttribute const&, pxrInternal_v0_24__pxrReserved__::SdfAbstractDataConstValue const&)+0x4cf (??:?)
2025-07-29T12:04:25Z [1,081ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libusd_usd.so!std::enable_if<!pxrInternal_v0_24__pxrReserved__::UsdStage::_IsEditTargetMappable::value, bool>::type pxrInternal_v0_24__pxrReserved__::UsdStage::SetValue(pxrInternal_v0_24__pxrReserved_::UsdTimeCode, pxrInternal_v0_24__pxrReserved__::UsdAttribute const&, int const&)+0x40 (??:?)
2025-07-29T12:04:25Z [1,102ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.usd-abi.plugin.so!carbOnPluginStartup+0x4068 (??:?)
2025-07-29T12:04:25Z [1,118ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.usd-abi.plugin.so!carbOnPluginStartup+0x5dff (??:?)
2025-07-29T12:04:25Z [1,132ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.hydratexture.plugin.so!carbOnPluginPreStartup+0x7f20 (??:?)
2025-07-29T12:04:25Z [1,145ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: _hydra_texture.cpython-311-x86_64-linux-gnu.so!std::__detail::_Map_base<std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, void*>, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, void*> >, std::__detail::_Select1st, std::equal_to<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >, std::hash<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, false, true>, true>::operator(std::__cxx11::basic_string<char, std::char_traits, std::allocator >&&)+0xeeab (??:?)
2025-07-29T12:04:25Z [1,161ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: _hydra_texture.cpython-311-x86_64-linux-gnu.so!std::__detail::_Map_base<std::__cxx11::basic_string<char, std::char_traits, std::allocator >, std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, void*>, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, void*> >, std::__detail::_Select1st, std::equal_to<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >, std::hash<std::__cxx11::basic_string<char, std::char_traits, std::allocator > >, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, false, true>, true>::operator(std::__cxx11::basic_string<char, std::char_traits, std::allocator >&&)+0x809c (??:?)
2025-07-29T12:04:25Z [1,178ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libpython3.11.so.1.0!PyBuffer_ToContiguous+0x9a7 (??:?)
2025-07-29T12:04:25Z [1,197ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libpython3.11.so.1.0!_PyObject_MakeTpCall+0x95 (??:?)
2025-07-29T12:04:25Z [1,217ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libpython3.11.so.1.0!_PyEval_EvalFrameDefault+0x8b8c (??:?)
2025-07-29T12:04:25Z [1,238ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libpython3.11.so.1.0!PyEval_EvalFrameEx+0xfa (??:?)
2025-07-29T12:04:25Z [1,257ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libpython3.11.so.1.0!PyObject_Vectorcall+0x33 (??:?)
2025-07-29T12:04:25Z [1,274ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libpython3.11.so.1.0!PyComplex_AsCComplex+0x1426 (??:?)
2025-07-29T12:04:25Z [1,293ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libpython3.11.so.1.0!_PyObject_GenericSetAttrWithDict+0x78 (??:?)
2025-07-29T12:04:25Z [1,310ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libpython3.11.so.1.0!PyObject_SetAttr+0x4f (??:?)
2025-07-29T12:04:25Z [1,326ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libpython3.11.so.1.0!_PyUnicode_IsAlpha+0x1199 (??:?)
2025-07-29T12:04:25Z [1,344ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libpython3.11.so.1.0!PyObject_SetAttr+0x4f (??:?)
2025-07-29T12:04:25Z [1,358ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libpython3.11.so.1.0!_PyEval_EvalFrameDefault+0x2dc1 (??:?)
2025-07-29T12:04:25Z [1,377ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libpython3.11.so.1.0!PyEval_EvalFrameEx+0xfa (??:?)
2025-07-29T12:04:25Z [1,398ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libpython3.11.so.1.0!PyCell_Set+0x6d6 (??:?)
2025-07-29T12:04:25Z [1,416ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libpython3.11.so.1.0!_PyObject_Call+0x9d (??:?)
2025-07-29T12:04:25Z [1,485ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libomni.ui.so!omni::ui::Window::_draw(char const*, float)+0xc24 (??:?)
2025-07-29T12:04:25Z [1,503ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libomni.ui.so!omni::ui::ColorWidget::setComputedContentHeight(float)+0xa4 (??:?)
2025-07-29T12:04:25Z [1,520ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libomni.kit.imgui_renderer.plugin.so!std::vector<unsigned int, std::allocator >::_M_default_append(unsigned long)+0xcc9 (??:?)
2025-07-29T12:04:25Z [1,537ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: libomni.kit.imgui_renderer.plugin.so!std::pair<std::_Rb_tree_iterator<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape> >, bool> std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape>, std::_Select1st<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape> >, std::less<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const>, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape> > >::_M_emplace_unique<std::pair<char const*, carb::windowing::CursorStandardShape> >(std::pair<char const*, carb::windowing::CursorStandardShape>&&)+0x52f6 (??:?)
2025-07-29T12:04:25Z [1,556ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: libomni.kit.imgui_renderer.plugin.so!std::pair<std::_Rb_tree_iterator<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape> >, bool> std::_Rb_tree<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape>, std::_Select1st<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape> >, std::less<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const>, std::allocator<std::pair<std::__cxx11::basic_string<char, std::char_traits, std::allocator > const, carb::windowing::CursorStandardShape> > >::_M_emplace_unique<std::pair<char const*, carb::windowing::CursorStandardShape> >(std::pair<char const*, carb::windowing::CursorStandardShape>&&)+0x5612 (??:?)
2025-07-29T12:04:25Z [1,578ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: libcarb.eventdispatcher.plugin.so!carbOnPluginRegisterEx+0x3441 (??:?)
2025-07-29T12:04:25Z [1,600ms] [Fatal] [carb.crashreporter-breakpad.plugin] 043: libomni.kit.renderer.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::erase(std::__detail::_Node_const_iterator<void*, true, false>)+0x8f58 (??:?)
2025-07-29T12:04:25Z [1,616ms] [Fatal] [carb.crashreporter-breakpad.plugin] 044: libomni.kit.renderer.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::erase(std::__detail::_Node_const_iterator<void*, true, false>)+0xad45 (??:?)
2025-07-29T12:04:25Z [1,634ms] [Fatal] [carb.crashreporter-breakpad.plugin] 045: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x5ee4 (??:?)
2025-07-29T12:04:25Z [1,649ms] [Fatal] [carb.crashreporter-breakpad.plugin] 046: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x6803 (??:?)
2025-07-29T12:04:25Z [1,669ms] [Fatal] [carb.crashreporter-breakpad.plugin] 047: libcarb.eventdispatcher.plugin.so!carbOnPluginRegisterEx+0x3441 (??:?)
2025-07-29T12:04:26Z [2,365ms] [Fatal] [carb.crashreporter-breakpad.plugin] 048: libomni.kit.loop-isaac.plugin.so!omni::kit::RunLoopThread::update()+0x108e (/home/voicandrei/isaacsim/_compiler/gmake2/omni.kit.loop-isaac.plugin/../../../source/extensions/omni.kit.loop-isaac/plugins/omni.kit.loop/RunLoopRunner.cpp:348)
2025-07-29T12:04:26Z [2,382ms] [Fatal] [carb.crashreporter-breakpad.plugin] 049: libomni.kit.app.plugin.so!+0x235e1
2025-07-29T12:04:26Z [2,395ms] [Fatal] [carb.crashreporter-breakpad.plugin] 050: libomni.kit.app.plugin.so!carbOnPluginPreStartup+0x1fa0 (??:?)
2025-07-29T12:04:26Z [2,399ms] [Fatal] [carb.crashreporter-breakpad.plugin] 051: kit!+0x3cd3
2025-07-29T12:04:26Z [2,464ms] [Fatal] [carb.crashreporter-breakpad.plugin] 052: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2025-07-29T12:04:26Z [2,505ms] [Fatal] [carb.crashreporter-breakpad.plugin] 053: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2025-07-29T12:04:26Z [2,512ms] [Fatal] [carb.crashreporter-breakpad.plugin] 054: kit!_start+0x25 (??:?)
Additional Information
What I’ve Tried
I tried to reinstall isaac sim but its the same.
I am not able to reproduce this issue. Please try launching with the --reset-user option.
Hello!
Best regards,
