I’m new to the Tk1. I finally got the Jetpack to install.
When I try to run some of the Cuda examples, like when I tried to run randomFog, it says:
./randomFog: error while loading shared libraries: libcurand.so.6.5: cannot open shared object file: No such file or directory
In the cuda-l4t directory, if I run cuda-l4t, I get:
dpkg-split: error: error reading /home/ubuntu/cuda-l4t/: Is a directory
dpkg: error processing archive /home/ubuntu/cuda-l4t/ (–install):
subprocess dpkg-split returned error exit status 2
Errors were encountered while processing:
Ign file: InRelease
Ign file: InRelease
Ign http://ports.ubuntu.com trusty/multiverse Translation-en_US
Ign http://ports.ubuntu.com trusty/restricted Translation-en_US
Ign http://ports.ubuntu.com trusty/universe Translation-en_US
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package cuda-toolkit
Did something not get installed properly?
Is there some way to kick off a rebuild of the libraries on the device?
When I run run_gameworks_sample.sh, it seems like it is working but doesn’t display anything other than the counters in the top right corner and the control in the top left.
