Jetson AGX orin connected to monitor, no input signal
Initially, it can be used with an external monitor,When I want to use remote desktop, I connect to Ubuntu through the remote desktop of windows, and after some operations.I’m not sure if these actions are causing the monitor not to work properly.
As soon as I start the orin, it initially shows the boot image, but after the fans spin down, the monitor starts showing no signal input.
I have already ruled out the problem of HDMI or DP cable.I’m not sure what to do next to get it to work with a monitor.
boot log.txt (92.4 KB)
I got a log of the login using putty, don’t know if this helps.
Now having this problem and can’t do anything anymore, I really hope someone can help me out with this, I would be very grateful.
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
Thanks for your reply, I’ve solved this problem by flashing orin.
