Hello, as the title says, I switched the AGX Orin to 30W mode and after attempting to reboot, it would not power on. I have tried supplying it with more power (30W Power Adapter) but am still not getting any results. Any help would be highly appreciated.
Can it enter recovery mode? How about to reflash it? Is it possible to read the input current from power supply? Looks like some components are broken, the input current value might be able to show that.
It does not enter recovery mode, I have tried by holding the middle button, pressing the right button then pressing the left button as instructed but nothing happens.
Reading the current it shows only small amounts of current passing through at the moment that I press the button (0.02 A, 0.05 A) but then immediately goes back to zero.
I have not tried reflashing it, how would I do that?
You mean after holding the recovery button and power on, there is no recovery usb device coming out and can’t flash the board? If so, the devkit might be damaged.
