[0000.061] I> MB1 (version: 0.23.0.0-t234-54845784-92215740)
[0000.066] I> t234-A01-0-Silicon (0x12347) Prod
[0000.070] I> Boot-mode : Coldboot
[0000.073] I> Emulation:
[0000.076] I> Entry timestamp: 0x00000000
[0000.080] I> last_boot_error: 0x0
[0000.083] I> BR-BCT: preprod_dev_sign: 0
[0000.086] I> rst_source: 0xb, rst_level: 0x1
[0000.091] I> Task: CRC check (0x5001cf71)
[0000.094] I> Skip CRC check as records_integrity fuse is not burned
[0000.100] I> Task: Crypto init (0x5001c0d9)
[0000.104] I> Task: Secure debug controls (0x5000cb19)
[0000.109] I> Task: strap war set (0x5000b739)
[0000.114] I> strap value(0x4000001) set to 0x4000001
[0000.118] I> Task: Initialize SOC Therm (0x5001a509)
[0000.123] I> Task: Program NV master stream id (0x5000cad1)
[0000.129] I> Task: Verify boot mode (0xd482021)
[0000.135] I> Task: Alias fuses (0x50010749)
[0000.139] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.146] I> Task: Print SKU type (0x5000fba9)
[0000.150] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.155] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.160] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.164] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.168] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.173] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.177] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.181] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.185] I> FUSE_SKU_INFO_0 = 0xd0
[0000.188] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.192] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.196] I> SKU: Prod
[0000.198] I> Task: Boost clocks (0x50013db1)
[0000.202] I> Initializing PLLC2 for AXI_CBB.
[0000.206] I> AXI_CBB : src = 35, divisor = 0
[0000.211] I> Task: Voltage monitor (0x50013dbd)
[0000.215] I> VMON: Vmon re-calibration and fine tuning done
[0000.220] I> Task: UPHY init (0x5000da39)
[0000.225] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0000.230] I> Task: Boot device init (0x50000a3d)
[0000.235] I> Boot_device: QSPI_FLASH instance: 0
[0000.240] I> Qspi clock source : pllc_out0
[0000.244] I> QSPI Flash: Macronix 64MB
[0000.247] I> QSPI-0l initialized successfully
[0000.251] I> Task: TSC init (0x5001ed35)
[0000.256] I> Task: Load membct (0x5001190d)
[0000.260] I> RAM_CODE 0x4000001
[0000.263] I> Loading MEM-BCT to SysRAM
[0000.266] I> Scratch RSV109: 0x00000001 active chain: 0
[0000.271] I> Slot: 0
[0000.273] I> Binary[0] block-0 (partition size: 0x40000)
[0000.279] I> get_binary_info: Binary name: MEM-BCT-0
[0000.283] I> Size of crypto header is 8192
[0000.287] I> BCH load address is : 0x40050000
[0000.292] I> Size of crypto header is 8192
[0000.296] I> BCH of MEM-BCT-0 read from storage
[0000.300] I> BCH address is : 0x40050000
[0000.304] I> MEM-BCT-0 header integrity check is success
[0000.309] I> Binary magic in BCH component 0 is MEM0
[0000.314] I> component binary type is 0
[0000.318] I> MEM-BCT-0 binary is read from storage
[0000.323] I> MEM-BCT-0 binary integrity check is success
[0000.328] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.335] I> RAM_CODE 0x4000001
[0000.340] I> RAM_CODE 0x4000001
[0000.344] I> Task: Load Page retirement list (0x50011139)
[0000.349] I> Task: SDRAM params override (0x50011b79)
[0000.354] I> Task: Save mem-bct info (0x50014071)
[0000.359] I> Task: Carveout allocate (0x500140d5)
[0000.363] I> RCM blob carveout will not be allocated
[0000.368] I> ECC region[0]: Start:0x0, End:0x0
[0000.372] I> ECC region[1]: Start:0x0, End:0x0
[0000.377] I> ECC region[2]: Start:0x0, End:0x0
[0000.381] I> ECC region[3]: Start:0x0, End:0x0
[0000.385] I> ECC region[4]: Start:0x0, End:0x0
[0000.389] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.395] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.400] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.405] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.409] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.419] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.426] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.433] I> allocated(CO:39) base:0x83a000000 size:0x6000000 align: 0x200000
[0000.440] I> allocated(CO:20) base:0x838000000 size:0x2000000 align: 0x2000000
[0000.447] I> allocated(CO:24) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.454] I> allocated(CO:28) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.461] I> allocated(CO:29) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.469] I> allocated(CO:43) base:0x830000000 size:0x2000000 align: 0x200000
[0000.476] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.483] I> allocated(CO:41) base:0x82f000000 size:0x1000000 align: 0x100000
[0000.490] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.497] I> allocated(CO:03) base:0x82e800000 size:0x800000 align: 0x800000
[0000.504] I> allocated(CO:06) base:0x82e000000 size:0x800000 align: 0x800000
[0000.510] I> allocated(CO:10) base:0x82d800000 size:0x800000 align: 0x800000
[0000.517] I> allocated(CO:56) base:0x82d000000 size:0x800000 align: 0x200000
[0000.524] I> allocated(CO:07) base:0x82cc00000 size:0x400000 align: 0x400000
[0000.531] I> allocated(CO:33) base:0x82c800000 size:0x400000 align: 0x200000
[0000.538] I> allocated(CO:47) base:0x82c400000 size:0x400000 align: 0x200000
[0000.545] I> allocated(CO:72) base:0x82c200000 size:0x200000 align: 0x10000
[0000.552] I> allocated(CO:01) base:0x82c100000 size:0x100000 align: 0x100000
[0000.559] I> allocated(CO:04) base:0x82c000000 size:0x100000 align: 0x100000
[0000.566] I> allocated(CO:05) base:0x82bf00000 size:0x100000 align: 0x100000
[0000.573] I> allocated(CO:08) base:0x82be00000 size:0x100000 align: 0x100000
[0000.580] I> allocated(CO:09) base:0x82bd00000 size:0x100000 align: 0x100000
[0000.587] I> allocated(CO:15) base:0x82bc00000 size:0x100000 align: 0x100000
[0000.593] I> allocated(CO:17) base:0x82bb00000 size:0x100000 align: 0x100000
[0000.600] I> allocated(CO:23) base:0x82ba00000 size:0x100000 align: 0x100000
[0000.607] I> allocated(CO:27) base:0x82b900000 size:0x100000 align: 0x100000
[0000.614] I> allocated(CO:42) base:0x82b800000 size:0x100000 align: 0x100000
[0000.621] I> allocated(CO:54) base:0x82b780000 size:0x80000 align: 0x80000
[0000.628] I> allocated(CO:26) base:0x82b740000 size:0x40000 align: 0x2000
[0000.635] I> allocated(CO:48) base:0x82b720000 size:0x20000 align: 0x10000
[0000.641] I> allocated(CO:69) base:0x82b700000 size:0x20000 align: 0x10000
[0000.648] I> allocated(CO:34) base:0x82b6f0000 size:0x10000 align: 0x10000
[0000.655] I> allocated(CO:35) base:0x82b6e0000 size:0x10000 align: 0x10000
[0000.661] I> allocated(CO:49) base:0x82b6d0000 size:0x10000 align: 0x10000
[0000.668] I> allocated(CO:50) base:0x82b6c0000 size:0x10000 align: 0x10000
[0000.675] I> allocated(CO:52) base:0x82b6b0000 size:0x10000 align: 0x10000
[0000.682] I> Task: Thermal check (0x5001fba1)
[0000.686] I> max_chip_limit = 115
[0000.689] I> min_chip_limit = -30
[0000.692] I> max temp read = 43
[0000.695] I> min temp read = 42
[0000.698] I> Task: Update FSI SCR with thermal fuse data (0x5001fc3d)
[0000.704] I> Task: Enable WDT 5th expiry (0x5001f929)
[0000.709] I> Task: Disable WDT globally (0x5001f965)
[0000.714] I> Task: I2C register (0x50000a31)
[0000.718] I> Task: Reset FSI (0x50013db9)
[0000.722] I> Task: Pinmux init (0x50013219)
[0000.726] I> Task: Prod config init (0x50013631)
[0000.731] I> Task: Pad voltage init (0x500132a5)
[0000.735] I> Task: Prod init (0x500136d5)
[0000.739] I> Task: Common rail init (0x50013bd1)
[0000.744] W> Thermal config not found in BCT
[0000.748] W> Generic i2c config not found in BCT
[0000.752] W> Platform rail config not found in BCT
[0000.758] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.767] W> MEMIO rail config not found in BCT
[0000.771] I> Task: Mem clock src (0x500119c5)
[0000.775] I> Task: Misc. board config (0x50013c29)
[0000.780] W> Platform config not found in BCT
[0000.784] I> Task: SDRAM init (0x500119c9)
[0000.791] I> SDRAM-params @ 0xd485000
[0000.794] I> MSS code-drop: NvBootSdramInit
[0000.798] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.806] I> MSS CAR: Init PLLM
[0000.809] I> MSS CAR: Init PLLHUB
[0000.813] I> Encryption: MTS: en, TX: dis, VPR: dis, GSC: en
[0000.825] I> mb1_sdram_init Done !
[0000.829] I> SDRAM Size in Total 0x800000000
[0000.833] I> Task: Dram Ecc scrub (0x50011261)
[0000.837] I> Task: DRAM alias check (0x50011b71)
[0000.868] I> Task: Program NSDRAM carveout (0x50014921)
[0000.874] I> NSDRAM carveout encryption is disabled
[0000.880] I> Program NSDRAM carveout
[0000.884] I> Task: Register checker (0x50011b75)
[0000.892] I> Task: Enable clock-mon (0x5001ed25)
[0000.909] I> FMON: Fmon re-programming done
[0000.913] I> Task: Mapper init (0x5001d451)
[0000.919] I> Task: SC7 Context Init (0x5001f02d)
[0000.925] I> Task: CCPLEX IST init (0x5000d335)
[0000.931] I> Task: CPU WP0 (0x5000c635)
[0000.936] I> Loading MCE
[0000.939] I> Scratch RSV109: 0x00000001 active chain: 0
[0000.945] I> Slot: 0
[0000.947] I> Binary[8] block-0 (partition size: 0x80000)
[0000.953] I> get_binary_info: Binary name: MCE
[0000.958] I> Size of crypto header is 8192
[0000.962] I> BCH load address is : 0x4003e000
[0000.968] I> Size of crypto header is 8192
[0000.972] I> BCH of MCE read from storage
[0000.977] I> BCH address is : 0x4003e000
[0000.982] I> MCE header integrity check is success
[0000.987] I> Binary magic in BCH component 0 is MTSM
[0000.992] I> component binary type is 8
[0000.997] I> Size of crypto header is 8192
[0001.003] I> MCE binary is read from storage
[0001.008] I> MCE binary integrity check is success
[0001.013] I> Binary MCE loaded successfully at 0x40000000 (0x2c080)
[0001.021] I> Size of crypto header is 8192
[0001.035] I> Size of crypto header is 8192
[0001.040] I> Sending WP0 mailbox command to PSC
[0001.051] I> Task: MB1 fixed firewalls (0x5001e55d)
[0001.070] I> Task: Load bpmp-fw (0x5001e801)
[0001.076] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.081] I> Slot: 0
[0001.084] I> Binary[15] block-0 (partition size: 0x180000)
[0001.090] I> get_binary_info: Binary name: BPMP_FW
[0001.095] I> Size of crypto header is 8192
[0001.100] I> BCH load address is : 0x807fe000
[0001.105] I> Size of crypto header is 8192
[0001.110] I> BCH of BPMP_FW read from storage
[0001.115] I> BCH address is : 0x807fe000
[0001.120] I> BPMP_FW header integrity check is success
[0001.126] I> Binary magic in BCH component 0 is BPMF
[0001.131] I> component binary type is 15
[0001.135] I> Size of crypto header is 8192
[0001.150] I> BPMP_FW binary is read from storage
[0001.158] I> BPMP_FW binary integrity check is success
[0001.163] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xfb3c0)
[0001.171] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.177] I> Slot: 0
[0001.179] I> Binary[16] block-10000 (partition size: 0x400000)
[0001.186] I> get_binary_info: Binary name: BPMP_FW_DTB
[0001.192] I> Size of crypto header is 8192
[0001.196] I> BCH load address is : 0x807fc000
[0001.202] I> Size of crypto header is 8192
[0001.207] I> BCH of BPMP_FW_DTB read from storage
[0001.212] I> BCH address is : 0x807fc000
[0001.217] I> BPMP_FW_DTB header integrity check is success
[0001.223] I> Binary magic in BCH component 0 is BPMD
[0001.228] I> component binary type is 16
[0001.232] I> Size of crypto header is 8192
[0001.239] I> BPMP_FW_DTB binary is read from storage
[0001.245] I> BPMP_FW_DTB binary integrity check is success
[0001.250] I> Binary BPMP_FW_DTB loaded successfully at 0x807db9f0 (0x20440)
[0001.259] I> Task: Load psc-fw (0x5001ea0d)
[0001.265] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.271] I> Slot: 0
[0001.273] I> Binary[17] block-0 (partition size: 0xc0000)
[0001.279] I> get_binary_info: Binary name: PSC_FW
[0001.284] I> Size of crypto header is 8192
[0001.289] I> BCH load address is : 0x80ffe000
[0001.294] I> Size of crypto header is 8192
[0001.299] I> BCH of PSC_FW read from storage
[0001.304] I> BCH address is : 0x80ffe000
[0001.309] I> PSC_FW header integrity check is success
[0001.315] I> Binary magic in BCH component 0 is PFWP
[0001.320] I> component binary type is 17
[0001.324] I> Size of crypto header is 8192
[0001.334] I> PSC_FW binary is read from storage
[0001.340] I> PSC_FW binary integrity check is success
[0001.346] I> Binary PSC_FW loaded successfully at 0x80000000 (0x7d000)
[0001.354] I> Task: Load nvdec-fw (0x5001ea81)
[0001.360] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.366] I> Slot: 0
[0001.368] I> Binary[7] block-0 (partition size: 0x100000)
[0001.374] I> get_binary_info: Binary name: NVDEC
[0001.379] I> Size of crypto header is 8192
[0001.384] I> BCH load address is : 0x800fe000
[0001.389] I> Size of crypto header is 8192
[0001.394] I> BCH of NVDEC read from storage
[0001.398] I> BCH address is : 0x800fe000
[0001.404] I> NVDEC header integrity check is success
[0001.409] I> Binary magic in BCH component 0 is NDEC
[0001.415] I> component binary type is 7
[0001.419] I> Size of crypto header is 8192
[0001.426] I> NVDEC binary is read from storage
[0001.431] I> NVDEC binary integrity check is success
[0001.436] I> Binary NVDEC loaded successfully at 0x80000000 (0x35000)
[0001.447] I> Task: Load tsec-fw (0x5001ec6d)
[0001.452] I> TSEC-FW load support not enabled
[0001.457] I> Task: Program misc carveouts (0x5001445d)
[0001.463] I> Program IPC carveouts
[0001.470] I> Task: GPIO interrupt map (0x50013cc5)
[0001.477] I> Task: SC7 context save (0x5001f161)
[0001.483] I> NV_SC7 Context addr: 0xa0000000
[0001.488] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.494] I> Slot: 0
[0001.496] I> Binary[27] block-0 (partition size: 0x100000)
[0001.502] I> get_binary_info: Binary name: BR_BCT
[0001.507] I> Size of crypto header is 8192
[0001.512] I> Size of crypto header is 8192
[0001.517] I> BR_BCT binary is read from storage
[0001.522] I> BR_BCT binary integrity check is success
[0001.528] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.535] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.541] I> Slot: 0
[0001.544] I> Binary[13] block-0 (partition size: 0x30000)
[0001.550] I> get_binary_info: Binary name: SC7-FW
[0001.555] I> Size of crypto header is 8192
[0001.559] I> Size of crypto header is 8192
[0001.564] I> BCH load address is : 0xa0002000
[0001.569] I> Size of crypto header is 8192
[0001.574] I> BCH of SC7-FW read from storage
[0001.579] I> BCH address is : 0xa0002000
[0001.584] I> SC7-FW header integrity check is success
[0001.590] I> Binary magic in BCH component 0 is WB0B
[0001.595] I> component binary type is 13
[0001.599] I> Size of crypto header is 8192
[0001.605] I> SC7-FW binary is read from storage
[0001.611] I> SC7-FW binary integrity check is success
[0001.616] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x25460)
[0001.624] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.630] I> Slot: 0
[0001.633] I> Binary[22] block-0 (partition size: 0x30000)
[0001.639] I> get_binary_info: Binary name: PSC_RF
[0001.644] I> Size of crypto header is 8192
[0001.648] I> Size of crypto header is 8192
[0001.653] I> BCH load address is : 0xa0029460
[0001.658] I> Size of crypto header is 8192
[0001.663] I> BCH of PSC_RF read from storage
[0001.668] I> BCH address is : 0xa0029460
[0001.673] I> PSC_RF header integrity check is success
[0001.679] I> Binary magic in BCH component 0 is PSCR
[0001.684] I> component binary type is 22
[0001.688] I> Size of crypto header is 8192
[0001.694] I> PSC_RF binary is read from storage
[0001.700] I> PSC_RF binary integrity check is success
[0001.705] I> Binary PSC_RF loaded successfully at 0xa002b460 (0x1bd20)
[0001.725] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.731] I> Slot: 0
[0001.733] I> Binary[14] block-0 (partition size: 0x20000)
[0001.739] I> get_binary_info: Binary name: MB2_RF
[0001.745] I> Size of crypto header is 8192
[0001.749] I> Size of crypto header is 8192
[0001.754] I> BCH load address is : 0xa008e240
[0001.759] I> Size of crypto header is 8192
[0001.764] I> BCH of MB2_RF read from storage
[0001.769] I> BCH address is : 0xa008e240
[0001.774] I> MB2_RF header integrity check is success
[0001.779] I> Binary magic in BCH component 0 is MB2R
[0001.785] I> component binary type is 14
[0001.789] I> Size of crypto header is 8192
[0001.795] I> MB2_RF binary is read from storage
[0001.800] I> MB2_RF binary integrity check is success
[0001.806] I> Binary MB2_RF loaded successfully at 0xa0090240 (0x1bdc0)
[0001.815] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.822] I> SC7 context fuse-bypass data is empty
[0001.830] I> SC7 context save done
[0001.834] I> Task: Load MB2/Applet/FSKP (0x5000d451)
[0001.840] I> Loading MB2
[0001.843] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.849] I> Slot: 0
[0001.851] I> Binary[6] block-0 (partition size: 0x80000)
[0001.857] I> get_binary_info: Binary name: MB2
[0001.862] I> Size of crypto header is 8192
[0001.866] I> BCH load address is : 0x8007e000
[0001.872] I> Size of crypto header is 8192
[0001.877] I> BCH of MB2 read from storage
[0001.881] I> BCH address is : 0x8007e000
[0001.887] I> MB2 header integrity check is success
[0001.892] I> Binary magic in BCH component 0 is MB2B
[0001.897] I> component binary type is 6
[0001.901] I> Size of crypto header is 8192
[0001.910] I> MB2 binary is read from storage
[0001.916] I> MB2 binary integrity check is success
[0001.921] I> Binary MB2 loaded successfully at 0x80000000 (0x686c0)
[0001.929] I> Task: Map CCPLEX SHARED carveout (0x5000d521)
[0001.936] I> Task: Prepare MB2 params (0x5000d5dd)
[0001.945] I> MB2-params @ 0x40060000
[0001.953] I> BR-BCT Boot Chain Fields
[0001.957] I> u32_non_gpio_select_boot_chain : 0
[0001.962] I> u32_num_boot_chains : 2
[0001.967] I> bf_bl_gpio_select_boot_chain_1b : 0
[0001.973] I> Task: Dram ecc test (0x500112cd)
[0001.978] I> Task: Misc NV security settings (0x5000ced5)
[0001.985] I> NVDEC sticky bits programming done
[0001.990] I> Task: Disable/Reload WDT (0x5001f991)
[0001.996] I> Programmed SLCG global override := 0x0
[0002.001] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-e33bc3dc)
I> Emulation:
I> Entry timestamp: 0x001f1972
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x82d000000, size:0x800000]
I> Task: ARI update carveout TZDRAM (0x50001e6c)
I> Task: Enable hot-plug capability (0x50020e7c)
I> Task: PSC mailbox init (0x50011ed0)
I> Task: Crypto init (0x5000513c)
I> Task: Enable GP-SE clock (0x50001fd0)
I> Task: I2C register (0x50001e30)
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout (0x50001e18)
I> Task: Boot device init (0x50001d60)
I> Task: Partition Manager Init (0x50001d5c)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
> PARTITION_MANAGER: Failed to publish partition.
I> Found 11 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x50017428)
I> Task: Load AUXP FWs (0x50020a1c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-55040 (partition size: 0x90000), name: A_spe-fw
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-56192 (partition size: 0x100000), name: A_rce-fw
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82be00000
I> Partition name: A_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-44800 (partition size: 0x500000), name: A_dce-fw
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82bb00000
I> dce : oem authentication of header done
I> dce : meta-blob integrity check is success.
I> dce : will be decompressed at 0x838000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> dce : decompressed to 9481920 bytes
I> dce: plain binary integrity check is success
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-58240 (partition size: 0x200000), name: A_adsp-fw
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x838000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-9472 (partition size: 0x40000), name: A_xusb-fw
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x82cc00000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82bf00000
I> Task: Carveout setup (0x50019c94)
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM (0x50011da4)
I> Task: Enable FSI VMON (0x50011944)
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings (0x5001199c)
I> FSITHERM max temp = 43
I> FSITHERM min temp = 43
I> Task: Restore XUSB sec (0x50001d30)
I> Task: Enable FSI SE clock (0x5001232c)
I> Enable FSI-SE clock and 10ms delay...
I> Task: Initialize SBSA UART CAR (0x50001f34)
I> Task: Initialize CPUBL Params (0x50013384)
I> CPUBL-params @ 0x834000000
I> Task: Prepare eeprom data (0x50013140)
I> Task: OEM firewalls (0x5001df14)
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> OEM firewalls configured
I> Task: Unhalt AUXPs (0x50020c84)
I> Unhalting SPE..
I> Enabling combined UART
▒▒▒▒spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 2e3d77fae66a40ac8e7a91531ae7d9b3
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x50011f50)
I> Sending opcode 0x4d420802 to psc
▒▒INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0x848000000 SIZE:0x1000000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: e061f86-9e1f578-2508c43-dev-t234
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
▒▒I> Received ACK from psc
I> Task: Sta▒▒INFO: MONITOR: user task addr:0x848022000, blob offset:0x00020000
▒▒rt secure NOR provision (0x50014924)
I> Task: Load FSI keyblob (0x50012368)
I> Skipping FSI key blob copy
I> Task: Unhalt AUXPs (0x50020c8c)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x5001347c)
I> Task: Load TOS (0x50013b38)
I> Partition name: A_cpu-bo▒▒[ 2.340934] Camera-FW on t234-rce-safe started
TCU early console enabled.
▒▒bpmp: init
bpmp: bas▒▒INFO: MONITOR: popula▒▒e binary md5 is eac380526d68ff45ffc86d0feae98e88
bpmp: combined binary md5 is▒▒ted user images:19
INFO: mret to Supervisor!
INFO: psc supervisor init.
INF▒▒ 888a114dda6bea50b6c6bb224445ac85
bpmp: firmware tag is 888a114dda6bea50b6c6-eac380526d6
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_popu▒▒O: psc_irq_init...
INFO: enter idle task.
▒▒late_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
471 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized thermal
initialized soctherm
initialized tj_init
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
▒▒otloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-24832 (p▒▒initialized avfs_clk_platform
initialized powergate
▒▒artition size: 0x380000), name: A_cpu-bootloader
▒▒initialized dvs
initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized emc
initialized emc_mrq
initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
initialized mce_dbell
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
▒▒I> Scratch RSV109: 0x00000001 active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-32000 (partition size: 0x400000), n▒▒initialized clk_cal_late
initialized noc_late
initialized dmce
initialized cvc
▒▒ame: A_secure-os
I> MB2-params @▒▒initialized avfs_clk_mach_post
initialized pm_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable adspneon
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable mss_encrypt
enable maud
enable nvdec
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xu▒▒[ 2.576527] Camer▒▒sb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
ini▒▒a-FW on t234-rce-safe▒▒tialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized prof▒▒ ready SHA1=7a10e461 (crt 13.247 ms, total boot 258.179 ms)
▒▒ile
initialized fuse_late
initialized mrq
initialized patrol_scrubber
initialized extras_post
bpmp: init complete
▒▒ 0x40060000
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82c400000
▒▒DCE: FW Boot Done
▒▒I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x831e06000
I> Relocating OP-TEE dtb from: 0x831eff700 to 0x82b700000, size: 0x996
I> [0] START: 0x80000000, SIZE: 0x7ab600000
I> [1] START: 0x82c400000, SIZE: 0x400000
I> [2] START: 0x82d000000, SIZE: 0x800000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: A_eks
I> Binary@ device:3/0 block-44288 (partition size: 0x40000), name: A_eks
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x82d000400
I> EKB detected (length: 0x410) @ VA:0x82d000400
I> Task: Prepare TOS params (0x50013ab0)
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x82b700000
I> Task: OEM SC7 context save (0x500146bc)
I> oem sc7 context saved
I> Task: Disable MSS perf stats (0x50020d18)
I> Task: Program display sticky bits (0x50020c94)
I> Task: Storage device deinit (0x50001ed8)
I> Task: SMMU external bypass disable (0x50011eb4)
I> Task: SMMU init (0x50011dd0)
I> Task: Program CBB PCIE AMAP regions (0x50014b08)
I> Task: Program GICv3 registers (0x50020db8)
I> Task: Audit firewall settings (0x5001e1c0)
I> Task: Bootchain failure check (0x500026a4)
I> Current Boot-Chain Slot: 0
I> BR-BCT Boot-Chain is 0, and status is 1. Set UPDATE_BRBCT bit to 0
I> MB2 finished
▒▒NOTICE: BL31: v2.6(release):4fa405dbd
NOTICE: BL31: Built : 20:16:55, Aug 10 2022
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.16 (gcc version 9.3.0 (Buildroot 2020.08)) #2 Thu Aug 11 03:23:19 UTC 2022 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: WARNING: Test OEM keys are being used!
I/TC: This is only for TZ-SE testing and should NOT be used for a shipping product!
E/TC:00 0 jetson_user_key_pta_init:700 jetson_user_key_pta_init: Failed (f0100006).
E/TC:00 0 call_initcalls:43 Initcall __text_start + 0x000dab50 failed
I/TC: Primary CPU switching to normal world boot
Jetson UEFI firmware (version 1.0-d7fb19b built on 2022-08-10T20:18:13-07:00)
** WARNING: Test Key is used. **
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
▒▒I/TC: Secondary CPU 1 initializing
I/TC: Secondary CPU 1 switching to normal world boot
I/TC: Secondary CPU 2 initializing
I/TC: Secondary CPU 2 switching to normal world boot
I/TC: Secondary CPU 3 initializing
I/TC: Secondary CPU 3 switching to normal world boot
I/TC: Secondary CPU 4 initializing
I/TC: Secondary CPU 4 switching to normal world boot
I/TC: Secondary CPU 5 initializing
I/TC: Secondary CPU 5 switching to normal world boot
I/TC: Secondary CPU 6 initializing
I/TC: Secondary CPU 6 switching to normal world boot
I/TC: Secondary CPU 7 initializing
I/TC: Secondary CPU 7 switching to normal world boot
I/TC: Secondary CPU 8 initializing
I/TC: Secondary CPU 8 switching to normal world boot
I/TC: Secondary CPU 9 initializing
I/TC: Secondary CPU 9 switching to normal world boot
I/TC: Secondary CPU 10 initializing
I/TC: Secondary CPU 10 switching to normal world boot
I/TC: Secondary CPU 11 initializing
I/TC: Secondary CPU 11 switching to normal world boot
▒▒[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.104-tegra (root@user-ZHENGJIUZHE-REN7000-28ICBR) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Mon Feb 20 15:34:37 CST 2023
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: Jetson AGX Orin
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x805401e18 MEMATTR=0x804769018 ESRT=0x804020f98 RNG=0x827905998 MEMRESERVE=0x80476ff18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000804020f98 to 0x0000000804020fd0.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000817800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000835ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000007ffffffff]
[ 0.000000] node 0: [mem 0x0000000800000000-0x00000008021bffff]
[ 0.000000] node 0: [mem 0x00000008021c0000-0x0000000803c90fff]
[ 0.000000] node 0: [mem 0x0000000803c91000-0x0000000803e0bfff]
[ 0.000000] node 0: [mem 0x0000000803e0c000-0x000000080453ffff]
[ 0.000000] node 0: [mem 0x0000000804540000-0x00000008046cffff]
[ 0.000000] node 0: [mem 0x00000008046d0000-0x000000080473ffff]
[ 0.000000] node 0: [mem 0x0000000804740000-0x000000080475ffff]
[ 0.000000] node 0: [mem 0x0000000804760000-0x000000080477ffff]
[ 0.000000] node 0: [mem 0x0000000804780000-0x00000008049effff]
[ 0.000000] node 0: [mem 0x00000008049f0000-0x0000000804a3ffff]
[ 0.000000] node 0: [mem 0x0000000804a40000-0x0000000804a4ffff]
[ 0.000000] node 0: [mem 0x0000000804a50000-0x0000000804a9ffff]
[ 0.000000] node 0: [mem 0x0000000804aa0000-0x0000000804e4ffff]
[ 0.000000] node 0: [mem 0x0000000804e50000-0x0000000804e5ffff]
[ 0.000000] node 0: [mem 0x0000000804e60000-0x0000000804ebffff]
[ 0.000000] node 0: [mem 0x0000000804ec0000-0x000000080534ffff]
[ 0.000000] node 0: [mem 0x0000000805350000-0x000000080539ffff]
[ 0.000000] node 0: [mem 0x00000008053a0000-0x000000080553ffff]
[ 0.000000] node 0: [mem 0x0000000805540000-0x00000008055dffff]
[ 0.000000] node 0: [mem 0x00000008055e0000-0x000000080568ffff]
[ 0.000000] node 0: [mem 0x0000000805690000-0x000000080572ffff]
[ 0.000000] node 0: [mem 0x0000000805730000-0x00000008057bffff]
[ 0.000000] node 0: [mem 0x00000008057c0000-0x000000080585ffff]
[ 0.000000] node 0: [mem 0x0000000805860000-0x000000080612ffff]
[ 0.000000] node 0: [mem 0x0000000806130000-0x000000080630ffff]
[ 0.000000] node 0: [mem 0x0000000806310000-0x00000008278bffff]
[ 0.000000] node 0: [mem 0x00000008278c0000-0x000000082790ffff]
[ 0.000000] node 0: [mem 0x0000000827910000-0x000000082b6affff]
[ 0.000000] node 0: [mem 0x000000082c400000-0x000000082c7fffff]
[ 0.000000] node 0: [mem 0x0000000834000000-0x0000000835ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000835ffffff]
[ 0.000000] On node 0, zone Normal: 336 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 32 pages/cpu s90136 r8192 d32744 u131072
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7925040
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=ttyAMA0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000effff000-0x00000000fffff000] (256MB)
[ 0.000000] Memory: 30995008K/32205504K available (18368K kernel code, 3170K rwdata, 7132K rodata, 3968K init, 1093K bss, 948352K reserved, 262144K cma-reserved)
[ 0.000000] random: get_random_u64 called from __kmem_cache_create+0x38/0x420 with crng_init=0
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000003] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000736] Console: colour dummy device 80x25
[ 0.000913] printk: console [tty0] enabled
[ 0.000949] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000958] pid_max: default: 32768 minimum: 301
[ 0.001016] LSM: Security Framework initializing
[ 0.001036] Yama: becoming mindful.
[ 0.001054] SELinux: Initializing.
[ 0.001136] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001182] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.003119] rcu: Hierarchical SRCU implementation.
[ 0.003213] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003805] DTS File Name: /home/user/nvidia/nvidia_sdk/JetPack_5.0.2_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/sources/Linux_for_Tegra/source/public/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.003862] DTB Build time: Feb 22 2023 15:36:51
[ 0.005246] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.005357] Remapping and enabling EFI services.
[ 0.006573] smp: Bringing up secondary CPUs ...
[ 0.035245] Detected PIPT I-cache on CPU1
[ 0.035279] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.035306] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.063915] Detected PIPT I-cache on CPU2
[ 0.063925] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.063939] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.092518] Detected PIPT I-cache on CPU3
[ 0.092526] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.092539] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.123156] Detected PIPT I-cache on CPU4
[ 0.123176] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.123202] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.151832] Detected PIPT I-cache on CPU5
[ 0.151841] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.151856] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.180461] Detected PIPT I-cache on CPU6
[ 0.180471] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.180485] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.209086] Detected PIPT I-cache on CPU7
[ 0.209096] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.209110] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.239738] Detected PIPT I-cache on CPU8
[ 0.239762] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.239788] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.268423] Detected PIPT I-cache on CPU9
[ 0.268432] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.268447] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.297660] Detected PIPT I-cache on CPU10
[ 0.297671] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.297685] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.326890] Detected PIPT I-cache on CPU11
[ 0.326901] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.326915] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.326973] smp: Brought up 1 node, 12 CPUs
[ 0.327038] SMP: Total of 12 processors activated.
[ 0.327043] CPU features: detected: Privileged Access Never
[ 0.327046] CPU features: detected: LSE atomic instructions
[ 0.327049] CPU features: detected: User Access Override
[ 0.327052] CPU features: detected: 32-bit EL0 Support
[ 0.327055] CPU features: detected: Common not Private translations
[ 0.327057] CPU features: detected: RAS Extension Support
[ 0.327060] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.327064] CPU features: detected: CRC32 instructions
[ 0.327066] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.360391] CPU: All CPU(s) started at EL2
[ 0.362636] devtmpfs: initialized
[ 0.377966] Registered cp15_barrier emulation handler
[ 0.377979] Registered setend emulation handler
[ 0.377984] KASLR enabled
[ 0.378099] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.378113] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.379697] pinctrl core: initialized pinctrl subsystem
[ 0.380176] DMI not present or invalid.
[ 0.380411] NET: Registered protocol family 16
[ 0.381212] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.381413] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.381611] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.381638] audit: initializing netlink subsys (disabled)
[ 0.381720] audit: type=2000 audit(0.380:1): state=initialized audit_enabled=0 res=1
[ 0.381865] thermal_sys: Registered thermal governor 'step_wise'
[ 0.381867] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.381872] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.384007] cpuidle: using governor menu
[ 0.384115] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.384231] ASID allocator initialised with 32768 entries
[ 0.384318] Serial: AMBA PL011 UART driver
[ 0.385924] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.385947] Tegra reboot handler registered.
[ 0.403693] mc: mapped MMIO address: 0xffff8000111f0000 -> 0x2c10000
[ 0.403707] mc: mapped MMIO address: 0xffff800011210000 -> 0x2c20000
[ 0.403715] mc: mapped MMIO address: 0xffff800011230000 -> 0x2c30000
[ 0.403722] mc: mapped MMIO address: 0xffff800011250000 -> 0x2c40000
[ 0.403728] mc: mapped MMIO address: 0xffff800011270000 -> 0x2c50000
[ 0.403735] mc: mapped MMIO address: 0xffff800011290000 -> 0x2b80000
[ 0.403741] mc: mapped MMIO address: 0xffff8000112b0000 -> 0x2b90000
[ 0.403747] mc: mapped MMIO address: 0xffff8000112d0000 -> 0x2ba0000
[ 0.403753] mc: mapped MMIO address: 0xffff8000112f0000 -> 0x2bb0000
[ 0.403759] mc: mapped MMIO address: 0xffff800011310000 -> 0x1700000
[ 0.403767] mc: mapped MMIO address: 0xffff800011330000 -> 0x1710000
[ 0.403774] mc: mapped MMIO address: 0xffff800011350000 -> 0x1720000
[ 0.403780] mc: mapped MMIO address: 0xffff800011370000 -> 0x1730000
[ 0.403787] mc: mapped MMIO address: 0xffff800011390000 -> 0x1740000
[ 0.403793] mc: mapped MMIO address: 0xffff8000113b0000 -> 0x1750000
[ 0.403799] mc: mapped MMIO address: 0xffff8000113d0000 -> 0x1760000
[ 0.403806] mc: mapped MMIO address: 0xffff8000113f0000 -> 0x1770000
[ 0.403814] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.403835] mc-err: mcerr ops are set to t23x
[ 0.404107] tegra234-cbb 13a00000.cbb-fabric: secure_irq = 21
[ 0.404165] tegra234-cbb c600000.aon-fabric: secure_irq = 22
[ 0.404205] tegra234-cbb d600000.bpmp-fabric: secure_irq = 23
[ 0.404241] tegra234-cbb de00000.dce-fabric: secure_irq = 24
[ 0.404274] tegra234-cbb be00000.rce-fabric: secure_irq = 25
[ 0.404313] tegra234-cbb b600000.sce-fabric: secure_irq = 26
[ 0.404521] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 65, base_baud = 0) is a SBSA
[ 1.655806] printk: console [ttyAMA0] enabled
[ 1.664013] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.670726] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 1.677428] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 1.684128] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 1.692575] ACPI: Interpreter disabled.
[ 1.697642] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 1.702536] vbusA-cvb: supplied by vdd-5v-sys
[ 1.707009] vbusB-cvb: supplied by vdd-5v-sys
[ 1.711494] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 1.716397] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 1.721471] iommu: Default domain type: Translated
[ 1.726390] eventlib_kernel: keventlib is initialized, test id: 0
[ 1.732640] SCSI subsystem initialized
[ 1.736452] usbcore: registered new interface driver usbfs
[ 1.741949] usbcore: registered new interface driver hub
[ 1.747273] usbcore: registered new device driver usb
[ 1.752498] mc: Linux media interface: v0.10
[ 1.756775] videodev: Linux video capture interface: v2.00
[ 1.762400] pps_core: LinuxPPS API ver. 1 registered
[ 1.767364] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.776500] PTP clock support registered
[ 1.780606] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 1.787767] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 1.795401] Registered efivars operations
[ 1.799856] FPGA manager framework
[ 1.803281] Advanced Linux Sound Architecture Driver Initialized.
[ 1.809607] Bluetooth: Core ver 2.22
[ 1.813188] NET: Registered protocol family 31
[ 1.817630] Bluetooth: HCI device and connection manager initialized
[ 1.823987] Bluetooth: HCI socket layer initialized
[ 1.828865] Bluetooth: L2CAP socket layer initialized
[ 1.833921] Bluetooth: SCO socket layer initialized
[ 1.839277] camchar: rtcpu character device driver loaded
[ 1.844887] clocksource: Switched to clocksource arch_sys_counter
[ 2.010068] VFS: Disk quotas dquot_6.6.0
[ 2.014030] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 2.021028] pnp: PnP ACPI: disabled
[ 2.026314] la/ptsa driver initialized.
[ 2.030200] NET: Registered protocol family 2
[ 2.034755] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.044440] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 2.053182] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 2.061471] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 2.069309] TCP: Hash tables configured (established 262144 bind 65536)
[ 2.076006] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.082938] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 2.090378] NET: Registered protocol family 1
[ 2.094980] RPC: Registered named UNIX socket transport module.
[ 2.100913] RPC: Registered udp transport module.
[ 2.105614] RPC: Registered tcp transport module.
[ 2.110316] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.116764] PCI: CLS 0 bytes, default 64
[ 2.120800] Trying to unpack rootfs image as initramfs...
[ 2.235356] Freeing initrd memory: 8196K
[ 2.241505] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 2.249502] kvm [1]: IPA Size Limit: 48 bits
[ 2.253939] kvm [1]: VHE mode initialized successfully
[ 2.259745] Initialise system trusted keyrings
[ 2.264272] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 2.272744] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.278833] NFS: Registering the id_resolver key type
[ 2.283896] Key type id_resolver registered
[ 2.288078] Key type id_legacy registered
[ 2.292116] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.298821] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 2.306224] ntfs: driver 2.1.32 [Flags: R/W].
[ 2.322214] NET: Registered protocol family 38
[ 2.326661] Key type asymmetric registered
[ 2.330757] Asymmetric key parser 'x509' registered
[ 2.335646] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 2.343097] io scheduler mq-deadline registered
[ 2.347631] io scheduler kyber registered
[ 2.355409] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 2.361009] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 2.366597] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 2.372184] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 2.380145] tegra_dc_assign_hw_data: no matching compatible node
[ 2.386161] tegradccommon module_init failed
[ 2.390430] tegradc module_init failed
[ 2.394414] EINJ: ACPI disabled.
[ 2.399107] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 2.405996] tegra-pmc: ### PMC reset source: MAINSWRST
[ 2.411134] tegra-pmc: ### PMC reset level: L1
[ 2.415576] tegra-pmc: ### PMC reset status reg: 0x2d
[ 2.421773] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.435553] random: fast init done
[ 2.437690] printk: console [ttyTCU0] enabled
[ 4.072888] arm-smmu 12000000.iommu: probing hardware configuration...
[ 4.080887] arm-smmu 12000000.iommu: SMMUv2 with:
[ 4.085723] arm-smmu 12000000.iommu: stage 1 translation
[ 4.091267] arm-smmu 12000000.iommu: stage 2 translation
[ 4.096794] arm-smmu 12000000.iommu: nested translation
[ 4.102249] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 4.109669] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 4.118418] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 4.125111] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.131792] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.139270] arm-smmu 10000000.iommu: probing hardware configuration...
[ 4.145971] arm-smmu 10000000.iommu: SMMUv2 with:
[ 4.150786] arm-smmu 10000000.iommu: stage 1 translation
[ 4.156325] arm-smmu 10000000.iommu: stage 2 translation
[ 4.161861] arm-smmu 10000000.iommu: nested translation
[ 4.167312] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 4.174726] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 4.183392] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 4.190085] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.196779] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.203880] arm-smmu 8000000.iommu: probing hardware configuration...
[ 4.210490] arm-smmu 8000000.iommu: SMMUv2 with:
[ 4.215237] arm-smmu 8000000.iommu: stage 1 translation
[ 4.220678] arm-smmu 8000000.iommu: stage 2 translation
[ 4.226117] arm-smmu 8000000.iommu: nested translation
[ 4.231478] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 4.238803] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 4.247393] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 4.254007] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 4.260613] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 4.267885] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 4.278199] tegra_profiler: version: 1.147, samples/io: 49/28
[ 4.284167] tegra_profiler: auth: init
[ 4.288288] nvsciipc: loaded module
[ 4.292756] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 4.298910] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 4.305428] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 4.312846] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 4.320435] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 4.326975] tegra23x-qspi 3270000.spi: Failed to get reset control: -517
[ 4.334410] tun: Universal TUN/TAP device driver, 1.6
[ 4.340036] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 4.347445] hns3: Copyright (c) 2017 Huawei Corporation.
[ 4.352909] e1000e: Intel(R) PRO/1000 Network Driver
[ 4.357993] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.364077] igb: Intel(R) Gigabit Ethernet Network Driver
[ 4.369609] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.375479] PPP generic driver version 2.4.2
[ 4.379894] PPP BSD Compression module registered
[ 4.384725] PPP Deflate Compression module registered
[ 4.389916] PPP MPPE Compression module registered
[ 4.394860] usbcore: registered new interface driver r8152
[ 4.400495] usbcore: registered new interface driver asix
[ 4.406043] usbcore: registered new interface driver ax88179_178a
[ 4.412304] usbcore: registered new interface driver cdc_ether
[ 4.418291] usbcore: registered new interface driver net1080
[ 4.424107] usbcore: registered new interface driver cdc_subset
[ 4.430186] usbcore: registered new interface driver zaurus
[ 4.435921] usbcore: registered new interface driver cdc_ncm
[ 4.441726] usbcore: registered new interface driver aqc111
[ 4.447548] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 4.453900] ohci-pci: OHCI PCI platform driver
[ 4.458476] ohci-platform: OHCI generic platform driver
[ 4.464107] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 4.470348] usbcore: registered new interface driver uas
[ 4.475829] usbcore: registered new interface driver usb-storage
[ 4.482127] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 4.488209] mousedev: PS/2 mouse device common for all mice
[ 4.493947] usbcore: registered new interface driver xpad
[ 4.501308] tegra_rtc c2a0000.rtc: registered as rtc1
[ 4.506790] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:25 UTC (25)
[ 4.515016] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.521415] i2c /dev entries driver
[ 4.525095] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 4.530968] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 4.536691] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 4.542386] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 4.548079] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 4.553765] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 4.559440] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 4.565122] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 4.572860] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.581441] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 4.590754] device-mapper: uevent: version 1.0.3
[ 4.595591] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 4.605377] sdhci: Secure Digital Host Controller Interface driver
[ 4.611735] sdhci: Copyright(c) Pierre Ossman
[ 4.616211] Synopsys Designware Multimedia Card Interface Driver
[ 4.622455] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.628450] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 4.628636] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 4.628733] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 4.629562] tegra-bpmp bpmp: firmware: 888a114dda6bea50b6c6-eac380526d6
[ 4.630903] nvvrs_pseq 4-003c: NVVRS Vendor ID: 0x9
[ 4.631642] nvvrs_pseq 4-003c: NVVRS Model Rev: 0x81
[ 4.635404] nvvrs_pseq 4-003c: CAUTION: interrupt status reg:0x10 set to 0x1
[ 4.671378] nvvrs_pseq 4-003c: Clearing interrupts
[ 4.676631] nvvrs-pseq-rtc nvvrs-pseq-rtc: registered as rtc0
[ 4.682552] nvvrs_pseq 4-003c: NVVRS PSEQ probe successful
▒▒debugfs initialized
▒▒[ 5.915503] hid: raw HID events driver (C) Jiri Kosina
[ 5.921231] usbcore: registered new interface driver usbhid
[ 5.926975] usbhid: USB HID core driver
[ 5.931643] tegra-dce d800000.dce: Adding to iommu group 6
[ 5.938511] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 5.947622] tegra234-aon c000000.aon: Adding to iommu group 7
[ 5.953830] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 5.962814] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [0]. Ignored...
[ 5.971615] dce: dce_admin_send_cmd_ver:413 version : [0x2] err : [0x0]
[ 5.972475] c000000.aon:hsp: probed
[ 5.982422] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [1] ...
[ 5.982429] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [1]. Ignored...
[ 5.990859] dce: dce_admin_setup_clients_ipc:518 Get queue info failed for [2]
[ 5.991225] tegra234-aon c000000.aon: init done
[ 5.991591] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 5.991950] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 5.991954] tegra23x-psc e860000.psc: init done
[ 5.992135] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 5.992726] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 6.004701] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 6.007547] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 6.011900] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 6.017764] dce: dce_admin_setup_clients_ipc:542 Channel Reset Complete for Type [3] ...
[ 6.017765] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignored...
[ 6.017779] dce: dce_admin_ipc_handle_signal:89 Spurious signal on channel: [3]. Ignored...
[ 6.024490] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 6.029251] dce: dce_start_boot_flow:100 DCE_BOOT_DONE
[ 6.035779] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 6.127446] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 6.140033] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 6.152873] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 6.164857] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (116)
[ 6.171683] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 6.179960] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=7a10e4613e151d2bf1df37dd80d456800f5b94d0
[ 6.179964] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 6.193431] t19x_cache tegra-cache: probed
[ 6.198326] tegra-hsp b950000.tegra-hsp: Try increasing MBOX_TX_QUEUE_LEN
[ 6.202726] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 6.224070] optee: probing for conduit method.
[ 6.228668] optee: revision 3.16 (65cc2218)
[ 6.229395] optee: dynamic shared memory is enabled
[ 6.238833] optee: initialized driver
[ 6.255080] nvpmodel: initialized successfully
[ 6.259852] tegra_hv: get_hvd: not initialized yet
[ 6.264796] user_ivc_mempool: hypervisor not present
[ 6.270699] usbcore: registered new interface driver snd-usb-audio
[ 6.277762] u32 classifier
[ 6.280548] input device check on
[ 6.284325] Actions configured
[ 6.287958] Initializing XFRM netlink socket
[ 6.292689] NET: Registered protocol family 10
[ 6.298419] Segment Routing with IPv6
[ 6.302233] NET: Registered protocol family 17
[ 6.306826] NET: Registered protocol family 15
[ 6.311451] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 6.325860] Bluetooth: RFCOMM socket layer initialized
[ 6.331190] Bluetooth: RFCOMM ver 1.11
[ 6.335074] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 6.341179] Bluetooth: HIDP socket layer initialized
[ 6.347262] 9pnet: Installing 9P2000 support
[ 6.351731] Key type dns_resolver registered
[ 6.357041] registered taskstats version 1
[ 6.361290] Loading compiled-in X.509 certificates
[ 6.370316] Loaded X.509 cert 'Build time autogenerated kernel key: 3092fec2fe2d83fa7018c6f409f60ac80f562bff'
[ 6.380830] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 6.392659] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.399702] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 6.411317] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.418123] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 6.429229] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.456846] tegra-soc-hwpm f100000.tegra_soc_hwpm: Adding to iommu group 13
[ 6.466742] host1x 13e40000.host1x: Adding to iommu group 14
[ 7.483056] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 7.501451] host1x 13e40000.host1x: initialized
[ 7.506481] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 15
[ 7.514583] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 7.526622] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 16
[ 7.534677] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 7.546635] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 17
[ 7.554703] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 7.566660] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 18
[ 7.574696] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 7.586649] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 19
[ 7.594669] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 7.606640] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 20
[ 7.614722] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 7.626666] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 21
[ 7.634740] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 7.646710] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 22
[ 7.654765] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 7.666746] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 23
[ 7.674800] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 7.686751] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 24
[ 7.694829] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 7.706818] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 25
[ 7.714863] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 7.726806] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 26
[ 7.734886] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 7.746844] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 27
[ 7.754906] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 7.766861] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 28
[ 7.774918] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 7.786876] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 29
[ 7.794909] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 7.806855] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 30
[ 7.814901] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 7.826880] falcon 15340000.vic: Adding to iommu group 31
[ 7.840696] falcon 15340000.vic: initialized
[ 7.845344] falcon 15380000.nvjpg: Adding to iommu group 32
[ 7.856643] falcon 15380000.nvjpg: initialized
[ 7.861344] falcon 15540000.nvjpg1: Adding to iommu group 33
[ 7.872141] falcon 15540000.nvjpg1: initialized
[ 7.876931] falcon 154c0000.nvenc: Adding to iommu group 34
[ 7.890099] falcon 154c0000.nvenc: initialized
[ 7.894789] falcon 15a50000.ofa: Adding to iommu group 35
[ 7.905710] falcon 15a50000.ofa: initialized
[ 7.910231] nvdec 15480000.nvdec: Adding to iommu group 36
[ 7.926284] nvdec 15480000.nvdec: initialized
[ 7.930885] tsec 15500000.tsec: Adding to iommu group 37
[ 7.944321] tsec 15500000.tsec: initialized
[ 7.952281] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 7.968210] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 7.982910] gpio-394 (camera-control-output-low): hogged as output/low
[ 7.989664] gpio-397 (camera-control-output-low): hogged as output/low
[ 7.996430] gpio-487 (camera-control-output-low): hogged as output/low
[ 8.003195] gpio-486 (camera-control-output-low): hogged as output/low
[ 8.010812] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 8.017936] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 8.024915] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 8.031344] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 8.037744] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 8.043933] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 8.052086] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 8.060651] tegra194-isp5 14800000.isp: Adding to iommu group 38
[ 8.069700] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 8.079224] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 8.085783] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 39
[ 8.093848] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 40
[ 8.101810] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 8.111671] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 8.118472] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 8.128301] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 8.135082] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 8.144936] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 8.151756] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: Adding to iommu group 41
[ 8.160447] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx0: initialized (streamid=18, iommu=smmu.0x0000000008000000)
[ 8.171828] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: Adding to iommu group 42
[ 8.180555] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx1: initialized (streamid=19, iommu=smmu.0x0000000008000000)
[ 8.191929] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: Adding to iommu group 43
[ 8.200627] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx2: initialized (streamid=20, iommu=smmu.0x0000000008000000)
[ 8.211994] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: Adding to iommu group 44
[ 8.220683] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx3: initialized (streamid=21, iommu=smmu.0x0000000008000000)
[ 8.232056] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: Adding to iommu group 45
[ 8.240763] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx4: initialized (streamid=22, iommu=smmu.0x0000000008000000)
[ 8.252130] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: Adding to iommu group 46
[ 8.260802] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx5: initialized (streamid=23, iommu=smmu.0x0000000008000000)
[ 8.272186] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: Adding to iommu group 47
[ 8.280877] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx6: initialized (streamid=24, iommu=smmu.0x0000000008000000)
[ 8.292266] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: Adding to iommu group 48
[ 8.300992] pva_iommu_context_dev 16000000.pva0:pva0_niso1_ctx7: initialized (streamid=25, iommu=smmu.0x0000000008000000)
[ 8.301097] random: crng init done
[ 8.312375] pva 16000000.pva0: Adding to iommu group 49
[ 8.339993] pva 16000000.pva0: initialized
[ 8.351427] nvdla 15880000.nvdla0: Adding to iommu group 50
[ 8.365687] nvdla 15880000.nvdla0: initialized
[ 8.371847] nvdla 158c0000.nvdla1: Adding to iommu group 51
[ 8.386114] nvdla 158c0000.nvdla1: initialized
[ 8.392265] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 8.399254] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 8.406720] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 8.413366] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 8.420081] serial-tegra 3100000.serial: Adding to iommu group 3
[ 8.426718] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 8.436328] serial-tegra 3130000.serial: Adding to iommu group 3
[ 8.442841] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 8.452370] tegra23x-qspi 3270000.spi: Node prod has invalid entries
[ 8.458930] tegra23x-qspi 3270000.spi: Node prod: Child has not proper setting
[ 8.466386] tegra23x-qspi 3270000.spi: Node spi: Faild to read the Prod Setting.
[ 8.474007] tegra23x-qspi 3270000.spi: Prod settings list not found
[ 8.508045] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 8.517838] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.523422] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 8.532035] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 8.541655] tegra-xusb 3610000.xhci: irq 234, io mem 0x03610000
[ 8.548049] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.556566] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.564006] usb usb1: Product: xHCI Host Controller
[ 8.569026] usb usb1: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.575302] usb usb1: SerialNumber: 3610000.xhci
[ 8.580940] hub 1-0:1.0: USB hub found
[ 8.584842] hub 1-0:1.0: 4 ports detected
[ 8.589258] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 8.594822] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 8.602629] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 8.610148] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.618669] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.626108] usb usb2: Product: xHCI Host Controller
[ 8.631127] usb usb2: Manufacturer: Linux 5.10.104-tegra xhci-hcd
[ 8.637398] usb usb2: SerialNumber: 3610000.xhci
[ 8.642560] hub 2-0:1.0: USB hub found
[ 8.646443] hub 2-0:1.0: 4 ports detected
[ 8.680412] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2000000 KHz, changing to: 2035200 KHz
[ 8.693825] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2014000 KHz, changing to: 2035200 KHz
[ 8.708131] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 8.720953] tegra194-cpufreq e000000.ccplex: probed with ICC
[ 8.728843] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 8.730559] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 8.739520] mmc0: CQHCI version 5.10
[ 8.740655] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 8.749422] irq: IRQ301: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.751102] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 8.758785] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 301
[ 8.767424] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 8.767427] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 8.805354] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 8.904953] mmc0: Command Queue Engine enabled
[ 8.909537] mmc0: periodic cache flush enabled
[ 8.914122] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 8.921147] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 8.925868] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (511:0)
[ 8.943946] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 9.898326] tegra194-pcie 14100000.pcie: Phy link never came up
[ 9.904495] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 9.911318] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 9.916961] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 9.926808] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 9.937650] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 9.945581] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 9.951919] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 9.965105] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 9.970508] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 9.979449] pcieport 0001:00:00.0: Adding to iommu group 10
[ 9.985438] pcieport 0001:00:00.0: PME: Signaling with IRQ 51
[ 9.991716] pcieport 0001:00:00.0: AER: enabled with IRQ 51
[ 9.997666] pci_bus 0001:01: busn_res: [bus 01-ff] is released
[ 10.003755] pci 0001:00:00.0: Removing from iommu group 10
[ 10.009415] pci_bus 0001:00: busn_res: [bus 00-ff] is released
[ 10.017192] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 10.024615] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 10.031800] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 10.040497] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 10.049189] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 11.159801] tegra-xusb 3610000.xhci: entering ELPG done
[ 11.166456] tegra194-pcie 14160000.pcie: Phy link never came up
[ 11.172618] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 11.179448] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 11.185089] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 11.195194] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 11.206037] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 11.213965] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 11.220302] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 11.233266] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 11.238667] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 11.247596] pcieport 0004:00:00.0: Adding to iommu group 11
[ 11.253557] pcieport 0004:00:00.0: PME: Signaling with IRQ 53
[ 11.259839] pcieport 0004:00:00.0: AER: enabled with IRQ 53
[ 11.265784] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 11.271864] pci 0004:00:00.0: Removing from iommu group 11
[ 11.277516] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 11.285060] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 11.291612] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 11.296639] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 11.301573] vdd-dp: supplied by vdd-3v3-sys
[ 11.306023] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 11.311107] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 11.317028] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.319043] tegra194-isp5 14800000.isp: initialized
[ 11.327271] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.327273] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.327276] [RCE] WARNING: core/hsp/hsp-vm.c:283 [camrtc_hsp_full_ss_isr] "VM0 issued IVC in inactive state."
[ 11.339709] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 11.369401] (NULL device *): fops function table already registered
[ 11.377161] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 11.384004] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 11.384097] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 11.409072] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 301
[ 11.499660] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 11.506853] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 11.515547] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 11.524237] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 12.455098] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 12.642456] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 12.648622] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 12.655455] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 12.661098] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 12.671211] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 12.682057] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 12.689991] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 12.696328] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 12.709337] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 12.714732] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 12.723675] pcieport 0005:00:00.0: Adding to iommu group 12
[ 12.729642] pcieport 0005:00:00.0: PME: Signaling with IRQ 55
[ 12.735916] pcieport 0005:00:00.0: AER: enabled with IRQ 55
[ 12.741858] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 12.747937] pci 0005:00:00.0: Removing from iommu group 12
[ 12.753587] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 12.761240] nvethernet 2310000.ethernet: Adding to iommu group 52
[ 12.767719] nvethernet 2310000.ethernet: failed to read skip mac reset flag, default 0
[ 12.772726] mmc1: new ultra high speed SDR104 SDXC card at address 1388
[ 12.775896] nvethernet 2310000.ethernet: failed to read MDIO address
[ 12.783078] mmcblk1: mmc1:1388 Stora 58.9 GiB
[ 12.789278] nvethernet 2310000.ethernet: setting to default DMA bit mask
[ 12.789285] nvethernet 2310000.ethernet: max-platform-mtu DT entry missing, setting default 1500
[ 12.931694] mmcblk1: p1
[ 13.053886] ether_get_mac_address_dtb: bad mac address at /chosen/nvidia,ether-mac0: NULL.
[ 13.062429] nvethernet 2310000.ethernet: No MAC address in local DT!
[ 13.068971] nvethernet 2310000.ethernet: failed to get MAC address
[ 13.076585] nvethernet: probe of 2310000.ethernet failed with error -22
[ 13.083807] irq: IRQ303: trimming hierarchy from :pmc@c360000
[ 13.089783] irq: IRQ304: trimming hierarchy from :interrupt-controller@f400000-1
[ 13.097471] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 13.103439] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 13.111017] tegra-se-nvhost 15810000.se: Adding to iommu group 53
[ 13.117640] tegra-se-nvhost 15810000.se: initialized
[ 13.132820] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 13.139191] tegra-se-nvhost 15820000.se: Adding to iommu group 54
[ 13.145746] tegra-se-nvhost 15820000.se: initialized
[ 13.152973] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 13.159338] tegra-se-nvhost 15840000.se: Adding to iommu group 55
[ 13.165896] tegra-se-nvhost 15840000.se: initialized
[ 13.174733] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 13.181543] tegra_actmon d230000.actmon: in actmon_register()...
[ 13.187879] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 13.193895] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 13.202274] hvc_sysfs: hypervisor is not present
▒▒WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpusysclk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc1clk
WARNING: clock_disable: clk_power_ungate on gated domain 35 for gpc0clk
▒▒[ 13.340598] ALSA device list:
[ 13.343659] No soundcards found.
[ 13.347725] Freeing unused kernel memory: 3968K
[ 13.352436] Run /init as init process
[ 13.368132] Root device found: mmcblk0p1
[ 13.372652] Found dev node: /dev/mmcblk0p1
[ 13.404693] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 13.413847] Rootfs mounted over mmcblk0p1
[ 13.432838] Switching from initrd to actual rootfs
[ 13.543666] systemd[1]: System time before build time, advancing clock.
[ 13.565025] x_tables: module verification failed: signature and/or required key missing - tainting kernel
[ 13.599513] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 13.623099] systemd[1]: Detected architecture arm64.
[ 13.661633] systemd[1]: Set hostname to <nvidia-agx-orin>.
[ 13.838710] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 13.851766] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 13.861311] systemd[1]: Created slice system-modprobe.slice.
[ 13.867494] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 13.874201] systemd[1]: Created slice User and Session Slice.
[ 13.880226] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 13.888327] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 13.898102] systemd[1]: Reached target User and Group Name Lookups.
[ 13.904613] systemd[1]: Reached target Slices.
[ 13.909237] systemd[1]: Reached target Swap.
[ 13.913909] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 13.920786] systemd[1]: Listening on Syslog Socket.
[ 13.925949] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 13.932967] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 13.939925] systemd[1]: Listening on Journal Audit Socket.
[ 13.945706] systemd[1]: Listening on Journal Socket (/dev/log).
[ 13.951965] systemd[1]: Listening on Journal Socket.
[ 13.957232] systemd[1]: Listening on udev Control Socket.
[ 13.962909] systemd[1]: Listening on udev Kernel Socket.
[ 13.969401] systemd[1]: Mounting Huge Pages File System...
[ 13.976083] systemd[1]: Mounting POSIX Message Queue File System...
[ 13.983437] systemd[1]: Mounting RPC Pipe File System...
[ 13.989863] systemd[1]: Mounting Kernel Debug File System...
[ 13.996587] systemd[1]: Mounting Kernel Trace File System...
[ 14.003559] systemd[1]: Starting Journal Service...
[ 14.009763] systemd[1]: Starting Set the console keyboard layout...
[ 14.017174] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 14.026040] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 14.035352] systemd[1]: Starting NVIDIA specific first-boot udev script...
[ 14.043579] systemd[1]: Started Nameserver information manager.
[ 14.050424] systemd[1]: Reached target Network (Pre).
[ 14.056820] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 14.066207] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 14.078096] systemd[1]: Starting Load Kernel Modules...
[ 14.084473] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 14.092231] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 14.092442] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 14.092485] systemd[1]: Starting udev Coldplug all Devices...
[ 14.110656] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x000000082f000000,16777216
[ 14.112236] systemd[1]: Started Journal Service.
[ 14.120248] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 14.120255] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x0000000849800000,914358272
[ 14.120256] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 14.120260] nvmap_page_pool_init: Total RAM pages: 7817329
[ 14.120261] nvmap_page_pool_init: nvmap page pool size: 977166 pages (3817 MB)
[ 14.120309] nvmap_background_zero_thread: PP zeroing thread starting.
[ 14.120388] misc nvmap: created heap vpr base 0x0000000849800000 size (892928KiB)
[ 14.123337] misc nvmap: created heap fsi base 0x000000082f000000 size (16384KiB)
[ 14.211922] systemd-journald[305]: Received client request to flush runtime journal.
[ 16.351413] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 16.351413]
[ 16.424562] nvidia: loading out-of-tree module taints kernel.
[ 16.437614] nv_platform 13800000.display: Adding to iommu group 56
[ 16.448502] platform 13800000.display:nvdisplay-niso: Adding to iommu group 57
[ 16.456688] spi-tegra114 3210000.spi: Adding to iommu group 3
[ 16.462198] NVRM: loading NVIDIA UNIX Open Kernel Module for aarch64 35.1.0 Release Build (buildbrain@mobile-u64-5273-d7000) Wed Aug 10 20:32:39 PDT 2022
[ 16.464158] spi-tegra114 3230000.spi: Adding to iommu group 3
[ 16.485496] cpu-throttle-alert cooling device registered.
[ 16.491225] gpu-throttle-alert cooling device registered.
[ 16.492169] irq: IRQ306: trimming hierarchy from :pmc@c360000
[ 16.497173] cv0-throttle-alert cooling device registered.
[ 16.501011] nvadsp 2993000.adsp: Adding to iommu group 58
[ 16.501175] nvadsp 2993000.adsp: in probe()...
[ 16.507063] nct1008_nct72 4-004c: starting parse dt
[ 16.508870] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 16.514291] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[ 16.515898] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
[ 16.525761] cv1-throttle-alert cooling device registered.
[ 16.529368] nct1008_nct72 4-004c: success parsing dt
[ 16.536468] cv2-throttle-alert cooling device registered.
[ 16.543475] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[ 16.567602] soc0-throttle-alert cooling device registered.
[ 16.567802] qspi_mtd spi6.0: MX25U51279G (65536 Kbytes)
[ 16.573696] soc1-throttle-alert cooling device registered.
[ 16.578825] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x4000000 (64MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 16.596499] nct1008_nct72 4-004c: LOC shutdown limit 107
[ 16.665504] 1 fixed-partitions partitions found on MTD device spi6.0
[ 16.672083] Creating 1 MTD partitions on "spi6.0":
[ 16.677202] 0x000000000000-0x000004000000 : "Whole_flash0"
[ 16.698352] ucsi_ccg 1-0008: i2c_transfer failed -121
[ 16.703973] ucsi_ccg 1-0008: ucsi_ccg_init failed - -121
[ 16.712635] ucsi_ccg: probe of 1-0008 failed with error -121
[ 16.818609] using random self ethernet address
[ 16.823221] using random host ethernet address
[ 18.518513] using random self ethernet address
[ 18.523193] using random host ethernet address
[ 38.041412] CPU8: shutdown
[ 38.171962] CPU9: shutdown
[ 38.301538] CPU10: shutdown
[ 38.384788] IRQ 121: no longer affine to CPU11
[ 38.390113] CPU11: shutdown
