Hi all!
I’ve just bought I Jetson Nano last november and I could not get it properly running yet.
It is hanging randomly (it seems). After burning the SD card and starting it for the first time, I can pass through the initial configuration process with no problem. Then, I had the normal system running ok, but, suddenly it hangs. The screen goes black and the board keep its energy light on.
So, I thought it was the system and tried the NVidia Linux system. When system was on everything looked ok, but when I tried to open the terminal, the hanging problem happened again.
Then, I google and read from forums and I looks like it was energy source problem, as I was using microUSB source (but it was not enough for a simple terminal opening?). So, I bought the recommended AdaFruit barel source, burned the microSD with NVidia Linux (forget about Arch) and this time I could open terminal and initiate the system update and upgrade…but (always the but), during upgrade it hanged again. I reboot, tried again, the upgrade finished successfully, I left the board on without using it for several minutes, when I got back it had hanged.
I’m downloading right now the latest version of NVidia Linux and will give another try, but I would appreciate tips, recommendations and info I could provide to help me with this situation.
Thank you very much!
Rafael
I had embbed an Archlinux OS to it so
