Hi NV,
MOD_SLEEP will output low(0V) then high(1.8) when system reboot on our carrier board,
but Tx2 and Xavier don’t have the same symptom,
is it a normally behavior on Jetson Nano?
it yes,
why Tx2/Xavier doesn’t need to do that?
thanks.
Have you met any issue? What’s the behavior on your devkit with the same module and sw? You can compare to that first. And the important thing is if your sequence same as that of Design Guide?
