I believe the changes in FvbNorFlashStandaloneMm.c are not reflected because those sources end up in the -standalone-optee binary, and not in uefi_jetson.bin.
So I built uefi_StandaloneMmOptee_DEBUG.bin using ./edk2-nvidia/Platform/NVIDIA/StandaloneMmOptee/build.sh from the EDK2 container (including these 3 patches), used strings to confirm that the logs I added are present in the resulting binary, and then copied it to Linux_for_Tegra/bootloader/standalonemm_optee_t234.bin and re-generated the UEFI capsule. Once again that assert happens.
Digging further I found Op-Tee related question - #10 by JerryChang and it appears that tos-optee needs to be re-generated manually using the stmm optee, so I did those steps to generate tos-t234, and finally re-built the capsule with this new tos, applied it, and am now getting:
Update Progress - 100% **************************************************HandleCapsules: capsule update complete, resetting ...
����Shutdown state requested 1
Rebooting sy��
[0000.062] I> MB1 (version: 1.4.0.2-t234-54845784-08a4de08)
[0000.067] I> t234-A01-0-Silicon (0x12347) Prod
[0000.071] I> Boot-mode : Coldboot
[0000.074] I> Entry timestamp: 0x00000000
[0000.078] I> last_boot_error: 0x0
[0000.081] I> BR-BCT: preprod_dev_sign: 0
[0000.085] I> rst_source: 0xb, rst_level: 0x1
[0000.089] I> Task: SE error check
[0000.092] I> Task: Bootchain select WAR set
[0000.096] I> Task: Enable SLCG
[0000.099] I> Task: CRC check
[0000.102] I> Skip FUSE records CRC check as records_integrity fuse is not burned
[0000.109] I> Task: Initialize MB2 params
[0000.114] I> MB2-params @ 0x40060000
[0000.117] I> Task: Crypto init
[0000.120] I> Task: Perform MB1 KAT tests
[0000.124] I> Task: NVRNG health check
[0000.127] I> NVRNG: Health check success
[0000.131] I> Task: MSS Bandwidth limiter settings for iGPU clients
[0000.137] I> Task: Enabling and initialization of Bandwidth limiter
[0000.143] I> No request to configure MBWT settings for any PC!
[0000.149] I> Task: Secure debug controls
[0000.153] I> Task: strap war set
[0000.156] I> Task: Initialize SOC Therm
[0000.160] I> Task: Program NV master stream id
[0000.164] I> Task: Verify boot mode
[0000.170] I> Task: Alias fuses
[0000.173] W> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.180] I> Task: Print SKU type
[0000.184] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.189] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.193] I> FUSE_OPT_TPC_DISABLE = 0x00000000
[0000.197] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.202] I> FUSE_OPT_PVA_DISABLE = 0x00000000
[0000.206] I> FUSE_OPT_NVENC_DISABLE = 0x00000000
[0000.210] I> FUSE_OPT_NVDEC_DISABLE = 0x00000000
[0000.215] I> FUSE_OPT_FSI_DISABLE = 0x00000000
[0000.219] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.223] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.228] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.232] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.236] I> FUSE_SKU_INFO_0 = 0xd0
[0000.239] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.243] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.247] I> SKU: Prod
[0000.249] I> Task: Boost clocks
[0000.252] I> Initializing NAFLL for BPMP_CPU_NIC.
[0000.257] I> BPMP NAFLL: fll_lock = 1, dvco_min_reached = 0
[0000.263] I> BPMP NAFLL lock success.
[0000.266] I> BPMP_CPU_NIC : src = 42, divisor = 0
[0000.271] I> Initializing PLLC2 for AXI_CBB.
[0000.275] I> AXI_CBB : src = 35, divisor = 0
[0000.279] I> Task: Voltage monitor
[0000.282] I> VMON: Vmon re-calibration and fine tuning done
[0000.288] I> Task: UPHY init
[0000.292] I> HSIO UPHY init done
[0000.296] W> Skipping GBE UPHY config
[0000.299] I> Task: Boot device init
[0000.302] I> Boot_device: QSPI_FLASH instance: 0
[0000.307] I> Qspi clock source : pllc_out0
[0000.311] I> QSPI Flash: Macronix 64MB
[0000.315] I> QSPI-0l initialized successfully
[0000.319] I> Task: TSC init
[0000.322] I> Task: Load membct
[0000.325] I> RAM_CODE 0x4000001
[0000.328] I> Loading MEMBCT
[0000.331] I> Slot: 1
[0000.333] I> Binary[0] block-66816 (partition size: 0x40000)
[0000.338] I> Binary name: MEM-BCT-0
[0000.341] I> Size of crypto header is 8192
[0000.345] I> Size of crypto header is 8192
[0000.349] I> strt_pg_num(66816) num_of_pgs(16) read_buf(0x40050000)
[0000.356] I> BCH of MEM-BCT-0 read from storage
[0000.360] I> BCH address is : 0x40050000
[0000.364] I> MEM-BCT-0 header integrity check is success
[0000.369] I> Binary magic in BCH component 0 is MEM0
[0000.374] I> component binary type is 0
[0000.378] I> strt_pg_num(66832) num_of_pgs(115) read_buf(0x40040000)
[0000.384] I> MEM-BCT-0 binary is read from storage
[0000.389] I> MEM-BCT-0 binary integrity check is success
[0000.394] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.401] I> RAM_CODE 0x4000001
[0000.406] I> RAM_CODE 0x4000001
[0000.410] I> Task: Load Page retirement list
[0000.414] I> Task: SDRAM params override
[0000.418] I> Task: Save mem-bct info
[0000.421] I> Task: Carveout allocate
[0000.425] I> RCM blob carveout will not be allocated
[0000.430] I> Update CCPLEX IST carveout from MB1-BCT
[0000.435] I> ECC region[0]: Start:0x0, End:0x0
[0000.439] I> ECC region[1]: Start:0x0, End:0x0
[0000.443] I> ECC region[2]: Start:0x0, End:0x0
[0000.447] I> ECC region[3]: Start:0x0, End:0x0
[0000.452] I> ECC region[4]: Start:0x0, End:0x0
[0000.456] I> Non-ECC region[0]: Start:0x80000000, End:0x880000000
[0000.462] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.466] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.471] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.476] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.486] I> allocated(CO:44) base:0x849800000 size:0x36800000 align: 0x100000
[0000.494] I> allocated(CO:31) base:0x840000000 size:0x8000000 align: 0x8000000
[0000.501] I> allocated(CO:43) base:0x83c000000 size:0x4000000 align: 0x200000
[0000.508] I> allocated(CO:39) base:0x839e00000 size:0x2200000 align: 0x10000
[0000.515] I> allocated(CO:20) base:0x836000000 size:0x2000000 align: 0x2000000
[0000.522] I> allocated(CO:24) base:0x834000000 size:0x2000000 align: 0x2000000
[0000.529] I> allocated(CO:28) base:0x832000000 size:0x2000000 align: 0x2000000
[0000.536] I> allocated(CO:29) base:0x830000000 size:0x2000000 align: 0x2000000
[0000.543] I> allocated(CO:22) base:0x848000000 size:0x1000000 align: 0x1000000
[0000.550] I> allocated(CO:35) base:0x838e00000 size:0x1000000 align: 0x100000
[0000.557] I> allocated(CO:41) base:0x82f000000 size:0x1000000 align: 0x100000
[0000.564] I> allocated(CO:02) base:0x849000000 size:0x800000 align: 0x800000
[0000.571] I> allocated(CO:03) base:0x838000000 size:0x800000 align: 0x800000
[0000.578] I> allocated(CO:06) base:0x82e800000 size:0x800000 align: 0x800000
[0000.585] I> allocated(CO:56) base:0x82e000000 size:0x800000 align: 0x200000
[0000.592] I> allocated(CO:07) base:0x838800000 size:0x400000 align: 0x400000
[0000.599] I> allocated(CO:33) base:0x82dc00000 size:0x400000 align: 0x200000
[0000.606] I> allocated(CO:19) base:0x82d980000 size:0x280000 align: 0x10000
[0000.613] I> allocated(CO:23) base:0x838c00000 size:0x200000 align: 0x200000
[0000.620] I> allocated(CO:01) base:0x82d800000 size:0x100000 align: 0x100000
[0000.627] I> allocated(CO:05) base:0x82d700000 size:0x100000 align: 0x100000
[0000.634] I> allocated(CO:08) base:0x82d600000 size:0x100000 align: 0x100000
[0000.641] I> allocated(CO:09) base:0x82d500000 size:0x100000 align: 0x100000
[0000.648] I> allocated(CO:12) base:0x82d400000 size:0x100000 align: 0x100000
[0000.655] I> allocated(CO:15) base:0x82d300000 size:0x100000 align: 0x100000
[0000.661] I> allocated(CO:17) base:0x82d200000 size:0x100000 align: 0x100000
[0000.668] I> allocated(CO:27) base:0x82d100000 size:0x100000 align: 0x100000
[0000.675] I> allocated(CO:42) base:0x82d000000 size:0x100000 align: 0x100000
[0000.682] I> allocated(CO:54) base:0x82d900000 size:0x80000 align: 0x80000
[0000.689] I> allocated(CO:34) base:0x82cff0000 size:0x10000 align: 0x10000
[0000.696] I> allocated(CO:72) base:0x82cdf0000 size:0x200000 align: 0x10000
[0000.703] I> allocated(CO:47) base:0x82c800000 size:0x400000 align: 0x200000
[0000.710] I> allocated(CO:50) base:0x82c600000 size:0x200000 align: 0x100000
[0000.717] I> allocated(CO:52) base:0x82cdc0000 size:0x30000 align: 0x10000
[0000.723] I> allocated(CO:48) base:0x82cda0000 size:0x20000 align: 0x10000
[0000.730] I> allocated(CO:69) base:0x82cd80000 size:0x20000 align: 0x10000
[0000.737] I> allocated(CO:49) base:0x82cd70000 size:0x10000 align: 0x10000
[0000.744] I> NSDRAM base: 0x80000000, end: 0x82cdf0000, size: 0x7acdf0000
[0000.750] I> Task: Thermal check
[0000.753] I> Using min_chip_limit as min_tmon_limit
[0000.758] I> Using max_chip_limit as max_tmon_limit
[0000.763] I> BCT max_tmon_limit = 105
[0000.766] I> BCT min_tmon_limit = -28
[0000.770] I> BCT max_tmon_limit = 105
[0000.773] I> BCT min_tmon_limit = -28
[0000.777] I> SKU specific max_chip_limit = 105
[0000.781] I> SKU specific min_chip_limit = -28
[0000.785] I> BCT max_chip_limit = 105
[0000.789] I> BCT min_chip_limit = -28
[0000.792] I> enable_soctherm_polling = 0
[0000.796] I> max temp read = 38
[0000.799] I> min temp read = 38
[0000.802] I> Enabling thermtrip
[0000.805] I> Task: Update FSI SCR with thermal fuse data
[0000.810] I> Task: Enable WDT 5th expiry
[0000.814] I> Task: I2C register
[0000.817] I> Task: Set I2C bus freq
[0000.820] I> Task: Reset FSI
[0000.823] I> Task: Pinmux init
[0000.826] I> Task: Prod config init
[0000.830] I> Task: Pad voltage init
[0000.833] I> Task: Prod init
[0000.836] I> Task: Program rst req config reg
[0000.840] I> Task: Common rail init
[0000.844] I> DONE: Thermal config
[0000.847] W> DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.855] I> DONE: SOC rail config
[0000.859] W> PMIC_CONFIG: Rail: MEMIO rail config not found in MB1 BCT.
[0000.865] I> DONE: MEMIO rail config
[0000.869] I> DONE: GPU rail info
[0000.872] I> DONE: CV rail info
[0000.875] I> Task: Mem clock src
[0000.878] I> Task: Misc. board config
[0000.882] I> PMIC_CONFIG: Platform config not found in MB1 BCT.
[0000.888] I> Task: SDRAM init
[0000.891] I> MemoryType: 4 MemBctRevision: 10
[0000.897] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 10
[0000.905] I> MSS CAR: Init PLLM
[0000.908] I> MSS CAR: Init PLLHUB
[0000.913] I> Encryption: MTS: en, TX: en, VPR: en, GSC: en
[0000.924] I> SDRAM initialized!
[0000.927] I> SDRAM Size in Total 0x800000000
[0000.931] I> Task: Dram Ecc scrub
[0000.935] I> Task: DRAM alias check
[0000.951] I> Task: Program NSDRAM carveout
[0000.955] I> NSDRAM carveout encryption is enabled
[0000.960] I> Program NSDRAM carveout
[0000.963] I> Task: Register checker
[0000.967] I> Task: Enable clock-mon
[0000.981] I> FMON: Fmon re-programming done
[0000.985] I> Task: Mapper init
[0000.988] I> Task: SC7 Context Init
[0000.991] I> Task: CCPLEX IST init
[0000.995] I> Task: CPU WP0
[0000.998] I> Loading MCE
[0001.000] I> Slot: 1
[0001.002] I> Binary[8] block-85760 (partition size: 0x80000)
[0001.008] I> Binary name: MCE
[0001.010] I> Size of crypto header is 8192
[0001.014] I> Size of crypto header is 8192
[0001.018] I> strt_pg_num(85760) num_of_pgs(16) read_buf(0x4003e000)
[0001.025] I> BCH of MCE read from storage
[0001.028] I> BCH address is : 0x4003e000
[0001.032] I> MCE header integrity check is success
[0001.037] I> Binary magic in BCH component 0 is MTSM
[0001.042] I> component binary type is 8
[0001.045] I> Size of crypto header is 8192
[0001.049] I> strt_pg_num(85776) num_of_pgs(350) read_buf(0x40000000)
[0001.058] I> MCE binary is read from storage
[0001.062] I> MCE binary integrity check is success
[0001.067] I> Binary MCE loaded successfully at 0x40000000 (0x2baf0)
[0001.073] I> Size of crypto header is 8192
[0001.084] I> Size of crypto header is 8192
[0001.088] I> Sending WP0 mailbox command to PSC
[0001.097] I> Task: XUSB Powergate
[0001.100] I> Skipping powergate XUSB.
[0001.104] I> Task: MB1 fixed firewalls
[0001.110] W> Firewall readback mismatch
[0001.115] I> Task: Load bpmp-fw
[0001.118] I> Slot: 1
[0001.120] I> Binary[15] block-72960 (partition size: 0x180000)
[0001.126] I> Binary name: BPMP_FW
[0001.129] I> Size of crypto header is 8192
[0001.133] I> Size of crypto header is 8192
[0001.137] I> strt_pg_num(72960) num_of_pgs(16) read_buf(0x807fe000)
[0001.143] I> BCH of BPMP_FW read from storage
[0001.147] I> BCH address is : 0x807fe000
[0001.151] I> BPMP_FW header integrity check is success
[0001.156] I> Binary magic in BCH component 0 is BPMF
[0001.161] I> component binary type is 15
[0001.164] I> Size of crypto header is 8192
[0001.168] I> strt_pg_num(72976) num_of_pgs(1990) read_buf(0x80000000)
[0001.186] I> BPMP_FW binary is read from storage
[0001.192] I> BPMP_FW binary integrity check is success
[0001.197] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf8bc0)
[0001.204] I> Slot: 1
[0001.206] I> Binary[16] block-76032 (partition size: 0x400000)
[0001.212] I> Binary name: BPMP_FW_DTB
[0001.215] I> Size of crypto header is 8192
[0001.219] I> Size of crypto header is 8192
[0001.223] I> strt_pg_num(76032) num_of_pgs(16) read_buf(0x807fc000)
[0001.229] I> BCH of BPMP_FW_DTB read from storage
[0001.234] I> BCH address is : 0x807fc000
[0001.238] I> BPMP_FW_DTB header integrity check is success
[0001.243] I> Binary magic in BCH component 0 is BPMD
[0001.248] I> component binary type is 16
[0001.251] I> Size of crypto header is 8192
[0001.255] I> strt_pg_num(76048) num_of_pgs(736) read_buf(0x8079fff0)
[0001.266] I> BPMP_FW_DTB binary is read from storage
[0001.271] I> BPMP_FW_DTB binary integrity check is success
[0001.277] I> Binary BPMP_FW_DTB loaded successfully at 0x8079fff0 (0x5bf00)
[0001.283] I> Task: BPMP fw ast config
[0001.287] I> Task: Load psc-fw
[0001.290] I> Slot: 1
[0001.292] I> Binary[17] block-84224 (partition size: 0xc0000)
[0001.298] I> Binary name: PSC_FW
[0001.301] I> Size of crypto header is 8192
[0001.305] I> Size of crypto header is 8192
[0001.308] I> strt_pg_num(84224) num_of_pgs(16) read_buf(0x80ffe000)
[0001.315] I> BCH of PSC_FW read from storage
[0001.319] I> BCH address is : 0x80ffe000
[0001.323] I> PSC_FW header integrity check is success
[0001.328] I> Binary magic in BCH component 0 is PFWP
[0001.332] I> component binary type is 17
[0001.336] I> Size of crypto header is 8192
[0001.340] I> strt_pg_num(84240) num_of_pgs(591) read_buf(0x80fb4200)
[0001.350] I> PSC_FW binary is read from storage
[0001.355] I> PSC_FW binary integrity check is success
[0001.359] I> Binary PSC_FW loaded successfully at 0x80fb4200 (0x49df0)
[0001.366] I> Task: Load nvdec-fw
[0001.369] I> Slot: 1
[0001.371] I> Binary[7] block-69376 (partition size: 0x100000)
[0001.377] I> Binary name: NVDEC
[0001.380] I> Size of crypto header is 8192
[0001.383] I> Size of crypto header is 8192
[0001.387] I> strt_pg_num(69376) num_of_pgs(16) read_buf(0x800fe000)
[0001.394] I> BCH of NVDEC read from storage
[0001.398] I> BCH address is : 0x800fe000
[0001.402] I> NVDEC header integrity check is success
[0001.406] I> Binary magic in BCH component 0 is NDEC
[0001.411] I> component binary type is 7
[0001.415] I> Size of crypto header is 8192
[0001.419] I> strt_pg_num(69392) num_of_pgs(560) read_buf(0x80000000)
[0001.428] I> NVDEC binary is read from storage
[0001.433] I> NVDEC binary integrity check is success
[0001.438] I> Binary NVDEC loaded successfully at 0x80000000 (0x46000)
[0001.444] I> Size of crypto header is 8192
[0001.455] I> Task: Load tsec-fw
[0001.458] I> TSEC-FW load support not enabled
[0001.463] I> Task: GPIO interrupt map
[0001.466] I> Task: SC7 context save
[0001.470] I> Slot: 1
[0001.472] I> Binary[27] block-0 (partition size: 0x100000)
[0001.477] I> Binary name: BR_BCT
[0001.480] I> Size of crypto header is 8192
[0001.484] I> Size of crypto header is 8192
[0001.488] I> Size of crypto header is 8192
[0001.492] I> strt_pg_num(0) num_of_pgs(16) read_buf(0xa0000000)
[0001.498] I> BR_BCT binary is read from storage
[0001.502] I> BR_BCT binary integrity check is success
[0001.507] I> Binary BR_BCT loaded successfully at 0xa0000000 (0x2000)
[0001.513] I> Slot: 1
[0001.515] I> Binary[13] block-86784 (partition size: 0x30000)
[0001.521] I> Binary name: SC7-FW
[0001.524] I> Size of crypto header is 8192
[0001.528] I> Size of crypto header is 8192
[0001.532] I> Size of crypto header is 8192
[0001.536] I> Size of crypto header is 8192
[0001.540] I> strt_pg_num(86784) num_of_pgs(16) read_buf(0xa0002000)
[0001.546] I> BCH of SC7-FW read from storage
[0001.550] I> BCH address is : 0xa0002000
[0001.554] I> SC7-FW header integrity check is success
[0001.559] I> Binary magic in BCH component 0 is WB0B
[0001.564] I> component binary type is 13
[0001.567] I> Size of crypto header is 8192
[0001.571] I> strt_pg_num(86800) num_of_pgs(349) read_buf(0xa0004000)
[0001.580] I> SC7-FW binary is read from storage
[0001.584] I> SC7-FW binary integrity check is success
[0001.589] I> Binary SC7-FW loaded successfully at 0xa0004000 (0x2b920)
[0001.596] I> Slot: 1
[0001.598] I> Binary[22] block-87168 (partition size: 0x30000)
[0001.603] I> Binary name: PSC_RF
[0001.606] I> Size of crypto header is 8192
[0001.610] I> Size of crypto header is 8192
[0001.614] I> Size of crypto header is 8192
[0001.618] I> Size of crypto header is 8192
[0001.622] I> strt_pg_num(87168) num_of_pgs(16) read_buf(0xa002f920)
[0001.628] I> BCH of PSC_RF read from storage
[0001.632] I> BCH address is : 0xa002f920
[0001.636] I> PSC_RF header integrity check is success
[0001.641] I> Binary magic in BCH component 0 is PSCR
[0001.646] I> component binary type is 22
[0001.650] I> Size of crypto header is 8192
[0001.654] I> strt_pg_num(87184) num_of_pgs(224) read_buf(0xa0031920)
[0001.661] I> PSC_RF binary is read from storage
[0001.666] I> PSC_RF binary integrity check is success
[0001.671] I> Binary PSC_RF loaded successfully at 0xa0031920 (0x1be60)
[0001.680] I> Task: Save WP0 payload to SC7 ctx
[0001.684] I> Task: Load MB2rf binary to SC7 ctx
[0001.689] I> Slot: 1
[0001.691] I> Binary[14] block-87552 (partition size: 0x20000)
[0001.696] I> Binary name: MB2_RF
[0001.699] I> Size of crypto header is 8192
[0001.703] I> Size of crypto header is 8192
[0001.707] I> Size of crypto header is 8192
[0001.711] I> Size of crypto header is 8192
[0001.715] I> strt_pg_num(87552) num_of_pgs(16) read_buf(0xa00d5d10)
[0001.721] I> BCH of MB2_RF read from storage
[0001.726] I> BCH address is : 0xa00d5d10
[0001.729] I> MB2_RF header integrity check is success
[0001.734] I> Binary magic in BCH component 0 is MB2R
[0001.739] I> component binary type is 14
[0001.743] I> Size of crypto header is 8192
[0001.747] I> strt_pg_num(87568) num_of_pgs(224) read_buf(0xa00d7d10)
[0001.754] I> MB2_RF binary is read from storage
[0001.759] I> MB2_RF binary integrity check is success
[0001.764] I> Binary MB2_RF loaded successfully at 0xa00d7d10 (0x1bf30)
[0001.770] I> Task: Save fuse alias data to SC7 ctx
[0001.775] I> Task: Save PMIC data to SC7 ctx
[0001.779] I> Task: Save Pinmux data to SC7 ctx
[0001.783] I> Task: Save Pad Voltage data to SC7 ctx
[0001.788] I> Task: Save controller prod data to SC7 ctx
[0001.793] I> Task: Save prod cfg data to SC7 ctx
[0001.797] I> Task: Save I2C bus freq data to SC7 ctx
[0001.802] I> Task: Save SOCTherm data to SC7 ctx
[0001.807] I> Task: Save FMON data to SC7 ctx
[0001.811] I> Task: Save VMON data to SC7 ctx
[0001.815] I> Task: Save TZDRAM data to SC7 ctx
[0001.819] I> Task: Save GPIO int data to SC7 ctx
[0001.824] I> Task: Save clock data to SC7 ctx
[0001.828] I> Task: Save debug data to SC7 ctx
[0001.832] I> Task: Save MBWT data to SC7 ctx
[0001.840] I> SC7 context save done
[0001.843] I> Task: Load MB2/Applet/FSKP
[0001.847] I> Loading MB2
[0001.849] I> Slot: 1
[0001.851] I> Binary[6] block-71424 (partition size: 0x80000)
[0001.857] I> Binary name: MB2
[0001.860] I> Size of crypto header is 8192
[0001.864] I> Size of crypto header is 8192
[0001.868] I> strt_pg_num(71424) num_of_pgs(16) read_buf(0x8007e000)
[0001.874] I> BCH of MB2 read from storage
[0001.878] I> BCH address is : 0x8007e000
[0001.882] I> MB2 header integrity check is success
[0001.886] I> Binary magic in BCH component 0 is MB2B
[0001.891] I> component binary type is 6
[0001.895] I> Size of crypto header is 8192
[0001.899] I> strt_pg_num(71440) num_of_pgs(844) read_buf(0x80000000)
[0001.910] I> MB2 binary is read from storage
[0001.915] I> MB2 binary integrity check is success
[0001.919] I> Binary MB2 loaded successfully at 0x80000000 (0x696a0)
[0001.925] I> Task: Map CCPLEX SHARED carveout
[0001.930] I> Task: Prepare MB2 params
[0001.933] I> Task: Dram ecc test
[0001.936] I> Task: Misc NV security settings
[0001.941] I> NVDEC sticky bits programming done
[0001.945] I> Successfully powergated NVDEC
[0001.949] I> Task: Disable/Reload WDT
[0001.953] I> Task: Program misc carveouts
[0001.956] I> Program IPC carveouts
[0001.960] I> Task: Disable SCPM/POD reset
[0001.964] I> SLCG Global override status := 0x0
[0001.968] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-af79ed0a)
I> Emulation:
I> Entry timestamp: 0x001e79ed
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0x82e000000, size:0x800000]
I> Task: MB2 Params integrity check
I> Task: Enable CCPLEX WDT 5th expiry
I> Task: ARI update carveout TZDRAM
I> Task: Configure OEM set LA/PTSA values
I> Task: Check MC errors
I> Task: Enable hot-plug capability
I> Task: PSC mailbox init
I> Task: Enable clock for external modules
I> Task: Measured Boot init
I> Task: fTPM silicon identity init
I> fTPM is not enabled.
I> Task: OEM SC7 context save init
I> Task: Map CCPLEX_INTERWORLD_SHMEM carveout
I> Task: Program CBB PCIE AMAP regions
I> Secondary storage device: QSPI_FLASH instance: 0
I> Secondary storage device: SDMMC_USER instance: 3
I> sdmmc HS400 mode enabled
I> Task: Partition Manager Init
I> strt_pg_num(130592) num_of_pgs(1) read_buf(0x82e001000)
I> strt_pg_num(130560) num_of_pgs(32) read_buf(0x82e001200)
I> Found 60 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
W> PARTITION_MANAGER: Failed to publish partition.
I> Found 10 partitions in SDMMC_USER (instance 3)
I> Task: Pass DRAM ECC PRL Flag to FSI
I> Task: Load and authenticate registered FWs
I> Task: Load AUXP FWs
I> Successfully register SPE FW load task with MB2 loader
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Successfully register PVA FW load task with MB2 loader
I> Partition name: B_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-118016 (partition size: 0x90000), name: B_spe-fw
I> strt_pg_num(118016) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(118032) num_of_pgs(512) read_buf(0x82d600000)
I> Partition name: B_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-119168 (partition size: 0x100000), name: B_rce-fw
I> strt_pg_num(119168) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(119184) num_of_pgs(880) read_buf(0x82d200000)
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0x82d600000
I> Partition name: B_dce-fw
I> Size of partition: 5242880
I> Binary@ device:3/0 block-107776 (partition size: 0x500000), name: B_dce-fw
I> strt_pg_num(107776) num_of_pgs(16) read_buf(0x40066880)
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0x82d200000
I> Successfully register RCE FW context save task with MB2 loader
I> dce : oem authentication of header done
I> strt_pg_num(107792) num_of_pgs(1) read_buf(0x82e1403d8)
I> strt_pg_num(107792) num_of_pgs(8) read_buf(0x82e1403d8)
I> dce : meta-blob integrity check is success.
I> strt_pg_num(107800) num_of_pgs(512) read_buf(0x82e0003c0)
I> strt_pg_num(108312) num_of_pgs(512) read_buf(0x82e0403c0)
I> dce : will be decompressed at 0x836000000
I> version 1 Bin 1 BCheckSum 0 content_size 0 Content ChkSum 1 reserved_00 0
I> Reserved10 0 BlockMaxSize 5 Reserved11 0
I> strt_pg_num(108824) num_of_pgs(512) read_buf(0x82e0803c0)
I> dce : decompressed to 12062400 bytes
I> dce: plain binary integrity check is success
I> Partition name: B_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-121216 (partition size: 0x200000), name: B_adsp-fw
I> strt_pg_num(121216) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(121232) num_of_pgs(800) read_buf(0x838800000)
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0x836000000
I> Partition name: B_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-72448 (partition size: 0x40000), name: B_xusb-fw
I> strt_pg_num(72448) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(72464) num_of_pgs(312) read_buf(0x82d700000)
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0x838800000
I> Successfully register APE FW context save task with MB2 loader
I> Partition name: B_pva-fw
I> Binary@ device:3/0 block-125312 (partition size: 0x40000), name: B_pva-fw
I> strt_pg_num(125312) num_of_pgs(16) read_buf(0x40066880)
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0x82d700000
I> Successfully register XUSB FW context save task with MB2 loader
I> pva-fw : oem authentication of header done
I> strt_pg_num(125328) num_of_pgs(1) read_buf(0x82e1403d8)
I> strt_pg_num(125328) num_of_pgs(8) read_buf(0x82e1403d8)
I> pva-fw : meta-blob integrity check is success.
I> strt_pg_num(125336) num_of_pgs(512) read_buf(0x82e0003c0)
I> pva-fw : will be decompressed at 0x82d980000
I> pva-fw : decompressed to 2156512 bytes
I> pva-fw: plain binary integrity check is success
I> pva-fw: Authentication Finalize Done
I> Binary pva-fw loaded successfully at 0x82d980000
I> Successfully register PVA FW context save task with MB2 loader
I> Task: Carveout setup
I> Program remaining OEM carveouts
I> Task: Enable FSITHERM
I> Task: Enable FSI VMON
I> FSI VMON: FSI Vmon re-calibration and fine tuning done
I> Task: Validate FSI Therm readings
I> Task: Restore XUSB sec
I> Task: Enable FSI SE clock
I> Enable FSI-SE clock...
I> Task: Initialize SBSA UART CAR
I> Task: Initialize CPUBL Params
I> CPUBL-params @ 0x832000000
I> Task: Ratchet update
W> Skip ratchet update - OPTIN fuse not set
I> Task: Prepare eeprom data
I> Task: FSI padctl context save
I> Task: Unpowergate APE
W> mb2_unpowergate_ape: skip! APE is in unpowergated state
I> Task: Memctrl reconfig pending clients
I> Task: OEM firewalls
I> OEM firewalls configured
I> Task: Powergate APE
I> Powergating APE
I> Powergate done
I> Task: OEM firewall restore saved settings
I> Task: Unhalt AUXPs
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
����vic initialized
����tsc initialized
����aon lic initialized
����spe: tag is 5243985d1b1eb3f06fac6d36bd7e74ac
����spe: SafeRTOS v8.4
����spe: init
����scheduler initialized
����aon hsp initialized
����tag initialized
����tcu initialized
����bpmp ipc initialized
����spe: late init
����cpu_nic clock initialized
����apb clock initialized
����pm initialized
����bpmp hsp initialized
����top1 hsp initialized
����ccplex ipc initialized
����spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit
I> Sending opcode 0x4d420802 to psc
I> Received ACK from psc
I> Task: Start secure NOR provision
I> Skip Secure NOR provisioning
I> Task: Trigger load FSI keyblob
I> Skipping FSI key blob copy
I> Task: Complete load FSI keyblob
I> Task: MB2-PSC_FW Key Manager Init
I> Sending opcode OP_PSC_KEY_MANAGER to psc-fw
I> Sending opcode 0x4b45594d to p��
hwwdt_init: WDT boot cfg 0x710010 sts 0x10
bpmp: socket 0
bpmp: base binary md5 is 3b0e1a33cf85c7f62a7e8b93c2af97ed
bpmp: combined binary md5 is 2aafe334513692db071cfc4bbbaf4115
bpmp: firmware tag is 2aafe334513692db071c-3b0e1a33cf8
initialized vwdt
initialized mail_early
initialized fuse
initialized vfrel
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
initialized pm
465 clocks registered
initialized clk_mach
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
��sc
I> Task: Unhalt FSI
I> FSI unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> Unhalting DCE
I> DCE unhalt successful
I> APE unhalt skipped
I> Task: Load HV/CPUBL
I> Task: Load TOS
I> Task: Trigger load��initialized avfs_clk_platform
initialized powergate
��[ 2.578833] Camera-FW on t234-rce-safe started
TCU early console enabled.
�� TS��initialized dvs
initialized clk_mach_config
suspend progress: 0x0
initialized suspend
initialized strap
initialized mce_dbell
��EC leyblob
��I> Sending opcode 0x53535452 to psc
I> Sent opcode to psc
I> Partition name: B_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-87808 (partition size: 0x380000), name: B_cpu-bootloader
��DCE Started
��I> strt_pg_num(87808) num_of_pgs(16) read_buf(0x40066880)
I> cpubl : oem authentication of header done
I> strt_pg_num(87824) num_of_pgs(1) read_buf(0x82e143f98)
��DCE_R5_Init
��I> strt_pg_num(87824) num_of_pgs(8) read_buf(0x82e143f98)
I> cpubl : meta-blob integrity check��initialized emc
initialized emc_mrq
�� is success.
��MPU enabled
��I> strt_pg_num(��initialized clk_cal
initialized uphy_dt
initialized uphy_mrq
HSIO UPHY reset has been de-asserted 0x0
��878��initialized uphy
��32) num_of_pgs(512) read_bu��initialized pg_late
initialized pg_mrq_init
swdtimer_init: reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized oc_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
��DCE_SW_Init
��f(0x82e003f80)
I> strt_pg_num(88344) num_of_pgs(��initialized clk_cal_late
initialized noc_late
initialized cvc
��512) read_buf(0x82e043f80)
I> cpubl : w��initialized avfs_clk_mach_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized rm
initialized console_late
handling unreferenced clks
enable can1_core
enable can1_host
enable can2_core
enable can2_host
enable pwm3
enable mss_encrypt
enable maud
enable pllg_ref
enable dsi_core
enable aza_2xbit
enable pllc4_muxed
enable sdmmc4_axicif
enable xusb_ss
enable xusb_fs
enable xusb_falcon
enable xusb_core_mux
enable dsi_lp
enable sdmmc_legacy_tm
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
��[ 2.777231] Camer��initialized mrq
initialized patrol_scrubber
initialized cactmon
initialized extras_post
bpmp: init complete
��a-FW on t234-rce-safe ready SHA1=e2238c99 (crt 12.421 ms, total boot 211.892 ms)
��ill be decompressed at 0x82c800000
I> strt_pg_num(88856) num_of_pgs(512) read_buf(0x82e083f80)
I> strt_pg_num(89368) num_of_pgs(512) read_buf(0x82e0c3f80)
I> strt_pg_num(89880) num_of_pgs(512) read_buf(0x82e103f80)
I> strt_pg_num(90392) num_of_pgs(512) read_buf(0x82e003f80)
I> strt_pg_num(90904) num_of_pgs(512) read_buf(0x82e043f80)
I> strt_pg_num(91416) num_of_pgs(512) read_buf(0x82e083f80)
I> strt_pg_num(91928) num_of_pgs(512) read_buf(0x82e0c3f80)
I> strt_pg_num(92440) num_of_pgs(512) read_buf(0x82e103f80)
��Admin Task Init
Admin Task Init complete
Print Task Init
RM Task Init
SHA Task Init
Admin Task Started
��I> strt_pg_num(92952) num_of_pgs(512) read_buf(0x82e003f80)
��DCE SC7 SHA Enabled
RM Task Started
RM Task Running
Print Task Started
Print Task Running
��I> strt_pg_num(93464) num_of_pgs(512) read_buf(0x82e043f80)
��SHA Task Started
DCE: FW Boot Complete
Admin Task Running
SHA Task Running
��I> strt_pg_num(93976) num_of_pgs(512) read_buf(0x82e083f80)
I> cpubl : decompressed to 3649664 bytes
I> cpubl: plain binary integrity check is success
I> Partition name: B_secure-os
I> Size of partition: 4194304
I> Binary@ device:3/0 block-94976 (partition size: 0x400000), name: B_secure-os
I> strt_pg_num(94976) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(94992) num_of_pgs(3104) read_buf(0x83fd7c000)
I> NSDRAM carveout base: 0x80000000, size: 0x7acdf0000
I> cpubl_params: nsdram: carveout: 1, encryption: 1
I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0x82c800000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0x83fd7c000
I> Relocating OP-TEE dtb from: 0x83feff0f0 to 0x83c040020, size: 0x2889
I> [0] START: 0x80000000, SIZE: 0x7acdf0000
I> [1] START: 0x832000000, SIZE: 0x2000000
I> Setting NS memory ranges to OP-TEE dtb finished.
I> Partition name: B_eks
I> Binary@ device:3/0 block-107264 (partition size: 0x40000), name: B_eks
I> strt_pg_num(107264) num_of_pgs(16) read_buf(0x40066880)
I> strt_pg_num(107280) num_of_pgs(8) read_buf(0x83c020000)
I> eks: Authentication Finalize Done
I> Binary eks loaded successfully at 0x83c020000
I> EKB detected (length: 0x410) @ VA:0x83c020000
I> Task: Add cpubl params integrity check
I> Added cpubl params digest.
I> Task: Prepare TOS params
I> Setting EKB blob info to OPTEE dtb finished.
I> Setting OPTEE arg3: 0x83c040020
I> OEM sc7 context saved
I> Task: Disable MSS perf stats
I> Task: Program display sticky bits
I> Task: Storage device deinit
I> Task: SMMU external bypass disable
I> Task: SMMU init
I> Task: Program GICv3 registers
I> Task: Audit firewall settings
I> Task: Bootchain failure check
I> Current Boot-Chain Slot: 1
I> BR-BCT Boot-Chain is 1, and status is 1. Set UPDATE_BRBCT bit to 0
I> Task: Burn RESERVED_ODM0 fuse
I> Task: Lock fusing
I> Task: Clear dec source key
I> MB2 finished
��NOTICE: BL31: v2.8(release):
NOTICE: BL31: Built : 18:49:22, Jun 25 2024
I/TC:
I/TC: Non-secure external DT found
I/TC: OP-TEE version: 3.22 (gcc version 11.3.0 (Buildroot 2022.08)) #2 Tue Jun 25 15:48:24 UTC 2024 aarch64
I/TC: WARNING: This OP-TEE configuration might be insecure!
I/TC: WARNING: Please check https://optee.readthedocs.io/en/latest/architecture/porting_guidelines.html
I/TC: Primary CPU initializing
I/TC: Test OEM keys are being used. This is insecure for shipping products!
I/TC: Primary CPU switching to normal world boot
Unhandled Exception from EL1
x0 = 0xdbe304275a3235eb
x1 = 0x25df610eb3ca152f
x2 = 0x00000000000f4240
x3 = 0x0000000081000000
x4 = 0x0000000000000001
x5 = 0x000000083c1ead38
x6 = 0xffffffffffffffff
x7 = 0x000000083c261ef0
x8 = 0x0000000000000020
x9 = 0x000000083c261ef0
x10 = 0x00000000000010c0
x11 = 0x0000000000000000
x12 = 0x00000000ffffffd8
x13 = 0x000000083c10e755
x14 = 0x000000083c261f94
x15 = 0x0000000842240020
x16 = 0x000000083c0af1c8
x17 = 0x0000000000000000
x18 = 0x000000083c261f44
x19 = 0x0000000000000000
x20 = 0x000000083c040020
x21 = 0x000000083c278b10
x22 = 0x000000083c1eb520
x23 = 0x0000000000000000
x24 = 0x0000000000000000
x25 = 0x0000000000000000
x26 = 0x0000000000000000
x27 = 0x0000000000000000
x28 = 0x0000000000000000
x29 = 0x0000000000000000
x30 = 0x000000083c080170
scr_el3 = 0x0000000000000e34
sctlr_el3 = 0x0000000030cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x0000000080823518
daif = 0x00000000000002c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000600003c4
elr_el3 = 0x000000083c08017c
ttbr0_el3 = 0x0000000050023e01
esr_el3 = 0x0000000062320802
far_el3 = 0x0000000000000000
spsr_el1 = 0x0000000000000000
elr_el1 = 0x0000000000000000
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000030d8180d
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000000000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x000000083c1eb520
esr_el1 = 0x0000000000000000
ttbr0_el1 = 0x000000083c24b000
ttbr1_el1 = 0x0000000000000000
mair_el1 = 0x00000000ff00ff04
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000280803f1a
tpidr_el1 = 0x0000000000000000
tpidr_el0 = 0x0000000000000000
tpidrro_el0 = 0x0000000000000000
par_el1 = 0xff0000083c22e980
mpidr_el1 = 0x0000000081000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x000000083c083000
cntp_ctl_el0 = 0x0000000000000000
cntp_cval_el0 = 0x0000000000000000
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x0000000000000000
sp_el0 = 0x0000000050016bf0
isr_el1 = 0x0000000000000000
cpuectlr_el1 = 0xa000000b40543000
gicd_ispendr regs (Offsets 0x200 - 0x278)
Offset: value
0000000000000200: 0x0000000000000000
0000000000000204: 0x0000000000000000
0000000000000208: 0x0000000000000000
000000000000020c: 0x0000000000000000
0000000000000210: 0x0000000000000000
0000000000000214: 0x0000000000000000
0000000000000218: 0x0000000000000000
000000000000021c: 0x0000000000020000
0000000000000220: 0x0000000000000000
0000000000000224: 0x0000000000000000
0000000000000228: 0x0000000000000000
000000000000022c: 0x0000000000000000
0000000000000230: 0x0000000000000000
0000000000000234: 0x0000000000000000
0000000000000238: 0x0000000000000000
000000000000023c: 0x0000000000000000
0000000000000240: 0x0000000000000000
0000000000000244: 0x0000000000000000
0000000000000248: 0x0000000000000000
000000000000024c: 0x0000000000000000
0000000000000250: 0x0000000000000000
0000000000000254: 0x0000000000000000
0000000000000258: 0x0000000000000000
000000000000025c: 0x0000000000000000
0000000000000260: 0x0000000000000000
0000000000000264: 0x0000000000000000
0000000000000268: 0x0000000000000000
000000000000026c: 0x0000000000000000
0000000000000270: 0x0000000000000000
0000000000000274: 0x0000000000000000
0000000000000278: 0x0000000000000000
000000000000027c: 0x0000000000000000
Any help here is much appreciated @KevinFFF . Thanks
