Jetson Orin NX 16gb is not booting up due to a physical damage
Hii,
I have been using the Jetson Orin Nx 16 GB with custom carrier board (A603 Seeed studio) for more than a year for an application in DRONE. We mount this orin Nx on a drone to test the flight for computational purposes. But during our flight test, the drone got hit very badly. After this, Orin NX does not boot up. I have checked that Orin is heating up, but it is not booting. The next thing I tried was flashing the jetpack for the orin, but I could see no signs of power in the carrier board. Since I have two Nvidia orin Nx 16 GB boards, I have replaced the new orin with it, and the carrier board is functioning properly and booting with the new board. I have attached the images of the damaged item to this thread. If someone can help in debugging this, it would be of great help.
You can try RMA for broken module. Jetson FAQ | NVIDIA Developer
Thank you for the reply. I will update this thread once I have the live chat for the RMA and any possible solution has popped out at the earliest.
