Hi, is it possible to power the TX2 dev kit with either 12 or 24 VDC? Anyone tried this and seen any performance issues?
12V will work, but the max should be 19.6V. In some cases you may need to make sure the power is well regulated…startup tends to not work if very short current delivery spikes drop voltage for even a very very short time.
