I have no network connectivity through the hard wire connection. The wifi works as expected. The activity light on my router connected to the TX2 starts activity for a few seconds and stops in a continuous cycle. The interface seemed to work previously before storms.
I connected a USB to Ethernet adapter and experienced the same behavior. I would suspect that if I am seeing the same behavior from a USB to Ethernet adapter and the RJ45 connection that it is not hardware related? I have tried multiple network configurations with static ip, dhcp, etc. to no avail. I have read in the forum that others have had trouble with memory issues causing the driver to crash. Any ideas of how to solve this issue?
[SOLVED]: The TX2 was unable to negotiate the desktop switch it was tied to. Thanks for the replies.
checksum.txt (2.81 KB)
log.txt (68.7 KB)
